Question about Kenmore 70088 Air Conditioner
Kenmore room a/c not model 70088
Is the temperature control on my room air set for cool setting at 9 or cool setting at 1
are the numbers 1-9 hot to cool or vice versa
i lost my manual
  • 958 Answers
You can test it by running it first at 9 and observe the compressor if it is continously running and cools the room. if it does, then 9 is the coldest and 1 is the hottest setting. but if the compressor would just run a little bit and stop at thermostat setting of 9, then its the reverse. i hope i was able to help.
Posted on Jun 27, 2008
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
My Kenmore 70088 Air Conditioner have mold
Hello, the coils can be cleaned with coil cleaner that is sold at any heating and cooling store, usually in a aerosol can. The inside of the AC can be cleaned with soap and water. They also sell a cleaner for mold at heating and cooling stores that can be used to get rid of the mold.
May 15, 2012 | Kenmore 70088 Air Conditioner
My Kenmore 70088 a/c turns on and off by itself. It is on cool mode not the energy saving on off power mode.....is this perhaps a short on the power digital panel?
If the unit is cooling as it should and it turns OFF after the temperature you have it set for is reached and then turns back ON once the temp drops 3 to 5 degrees, it's working as it should. There is no reason for it to run constantly if it's cooling and reaching the set temperature.
If the above is not the case, tan yes, there may be a problem with the control panel, as well as the air intake filter may need to removed and cleaned.
Hope this helps you and thanks for choosing FixYa.
Sep 19, 2011 | Kenmore 70088 Air Conditioner
The freezer on my Kenmore Elite Trio has stopped freezing. All my food is thawing. How do I set the freezer temperture at the coldest setting?
If the temperature is the problem this could be the solution
Problems with Temperature
If the refrigerator or freezer is not cooling properly, check temperature settings and air vents and ensure there is adequate room for proper airflow. Factory-recommended temperature settings are 0 degrees Fahrenheit (-18 degrees Celsius) for the refrigerator; and 37 degrees Fahrenheit (3 degrees Celsius) for the freezer.
If you need to adjust the temperature, do it one degree at a time and wait 24 hours before making additional adjustments. Check the air vents and make sure nothing is blocking them. Finally, if your refrigerator or freezer is too full, there will not be adequate room for air to circulate and cool properly. If these all check out, the problem could be with one or more compressor components and will require professional repair.
Hope this will help you.
Thanks for using FixYa : )
Sep 08, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
I have an old Kenmore window unit that looks like a 72055 (control panel on top left). Although I have it set at 90 degrees and the room temperature is 75, the fan cycles on and off. How can I set it so...
most have a 'continious mode' that operates the air moving fan whenever the unit is on, or a 'cycling mode' that operates from a temp sensor usually near the input over the evaporator coil.
Look for the instruction for setting the mode you want.
I suspect the unit compressor is not starting and it just keeps retrying when the overload switch cools off from the previous attempt to start.
Jun 09, 2010 | Heating & Cooling
How do i turn it on for the first time
hi there'
turning ac on,there are two switch on control panel of ac.find the thermostat control this signifies the room temperature you want,set this first to a maximum setting.another switch is for the motor compressor and fun motor.rotate the switch to fun first after a couple 15 second rotate again the switch to lo cool setting w8 for 10 to 15 sec. then rotae it again to hi cool there will be a sudden heavy change of blwing air and cooling effect then rotate set the thermosat switch to temperature comfortable to your feeling,observe the cycling process,because the compressor motor stop if the room temperature reached the set up temperature.stopping or switching off just rotate the switch of the compressor motor on off position.have a nice day fix my rate thank s a lot.
May 14, 2010 | Amana PBE12 Wall/Window Air Conditioner
The window unit is turned on, but doesnt seem to be very strong with blowing cold air . is there something that can be checked on the unit? something that can be replaced on the unit-like a filter? since...
first make sure the filter and coils are clean, then be sure you have it set for recirculate and not outside air allowance, and if ou wait til the room is very hot it will take a while to cool that room down to a comfort level. the fan and temperature control should both be at maximum if the room is very hot.
Jun 25, 2009 | Heating & Cooling
Lost Remote
go here: http://www.partlinx.com/haier.asp
andsearch for the part. You have to start with your state, and then gofrom there. For my area, the remote is 19.99, plus shipping and tax.Also, try eBay. You can find a lot of things there!
Aug 24, 2008 | Haier hwr10xc6 Air Conditioner
Kenmore 70088 Air Conditioner Logo
264 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
