Hello,this is simply caused by the compressor,you will have to get it serviced,but if the problem persist,then i would advice you replace it.
you can as well check the following,because below is the translator of the H16 error code,
H16 Outdoor Current Transformer open circuit
• Outdoor PCB
• IPM (Power transistor) module
take care.
Oncce the fridge was shut off and left for a while the cooling had come back . If frost is seen it is a good indication as the compressor is working with sufficient gas within.
If after about 6 hours you observe cooling it is possible that the defrost timer is faulty.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
replace the defrost timer, heater or thermostat one you have confirmed to eliminate one by one.
Yes this solution confirmed my first thyinking
