Question about Refrigerators
Side by Side Freezer/Refridgerator - Frididaird Gallery Series Model #FRS26ZGH
Freezer working but Refridge is too warm (it is a little cool but dairy products going bad) - wondering if there are a few steps I can take to help trouble shoot or what are the parts most likely that need to be replaced.
  • madmaz08 Jun 27, 2008
    my daowoo refrigertor as the red liht on and is not cold the light should be green
  • 87 Answers
SOURCE: DEFROST SEEMS STUCK
Do you have ice at the back of the freezer section. If you do defrost the unit and see if this makes a difference to the performance. If it behaves you probably have a defrost heater or defrost thermostat fault. If it fails to pull down you possibly have a fan motor gone or a problem with the defrost circuit. I would suggest if it behaves monitor closely and if it fails contact a good fridge guy who should be able to diagnose which fault it is. Hope this is of some help.
Posted on Sep 15, 2007
  • 52 Answers
SOURCE: Ice Maker
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Posted on Jul 17, 2008
  • 2976 Answers
SOURCE: dairy products are seperating
Time & temperature. Even if kept at the proper temperature, dairy products will separate in time. Bacteria will also do it. If you drink from the bottle, the enzymes in your saliva will infest and break down the whole container. It's being digested in the container, like feeding baby food from the jar. The food in the jar becomes watery, because it's being digested.
Posted on Aug 01, 2009
SOURCE: maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Posted on Sep 05, 2009
  • 523 Answers
SOURCE: How do I remove the drip tray on ice/water
pull striaght out
Posted on Dec 18, 2009
Frs26zgh-frigidaire/ gallery,frig is'nt cooling at all- freezer is cold,but not freezing.
Wow I hate to see that because I have one. You must have a defrost issue. Look on the backside of the freezer for noticable frost. That is an indication of something in the defrost system failing. Defrost system consists of a defrost heater, a defrost heater termination thermostat, and a defrost control. The most likely suspect is the defrost heater termination thermostat. It's job is to shut down the heater when the area is warmed enough to melt frost on the evaporation coils. I fixed one today with a defrost problem just like yours
Feb 07, 2013 | Frigidaire FRS26R4A Side by Side...
Freezer ices up and fridge part warm, timer changed worked well for 2 weeks model frt 163ag no frost fridge
Hello Claire Trancoso - If the refrigeration side is the one with the issue, you need to check the damper door/switch that is between both doors. In side by side units this damper controls the cool air from the freezer to come over to the refrigeration side to cool it. Contact a professional technician to diagnose if the unit has a floating restriction, an issue with the evaporator fan or a possible air leak.
Dec 17, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refridge. light went out. Bulb is good. Indicator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How many cubic inches? Frigidaire GAllery Powersource Pluse FRS26zgh purchased 6/00
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that tells you how to figure out how big your refrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Sep 10, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidair Gallery fridge/freezer... Freezer is
change the control board in the rear lower left corner of unit part# 4334000 2 appliance parts pros
Oct 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
May 22, 2008 | Frigidaire Refrigerators
DEFROST SEEMS STUCK
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Sep 13, 2007 | Frigidaire FRS266ZDSB Side by Side...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
