Question about Brother Multi-Function Center MFC-3360c All-In-One InkJet Printer
Brother MFC-3360C cyan ink cartridge replace ment
Replaced ink cartridge but message keeps saying "no cartridge, reinstall cartridge". Shut off printer and tried several times to re-install cartridge but problem keeps repeating itself
  • 5 more comments
  • beef19 Jun 30, 2008
  • mattcroatia Aug 13, 2008
    mine is with a black cartridge. it is not a brother product. is there some sort of tripwire to weed out non Brother products? happy enough on the other three colors.
  • Anonymous Oct 21, 2008
    Brand new unit. Printed a few times then left unused for months. Tried to print but unit complains of no Cyan cartridge. Reseated cartridges and powered unit off and back on, but no positive change.
  • Anonymous Jan 28, 2009
    Brother MFC 240 c keeps showing cyan ink cartridge nees replacement. It is new. Copier does NOT work.
  • Anonymous Mar 01, 2009
    after I replace my black ink cartridge the message " install cyan..." comes up. I don't know what is cyan is. My printer is a Brother Multi-fuction center mfc-3360 c
    I am only replacing my black ink and not my color ink
  • Anonymous Mar 16, 2009
    we reinstalled the magenta cartridge and itstill says magenta out of ink. replace.what should i do ?
  • Anonymous May 08, 2009
    replaced the black cartridge and it said cyan out, replace cyan and it says no cartridge. have turned off and reset several times, removed and reset cartridges several times
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Posted on Oct 21, 2009
Big hammer
Posted on Jul 15, 2008
After I replace my black ink cartridge the message " install cyan..." comes up. I don't know what is cyan is. My printer is a Brother Multi-fuction center mfc-3360 c I am only replacing my...
Possibly at the time of release catrid black ink, color ink catrid position slightly annoyed and thought catrid sofwear printer cyan ink has been removed so that the request to install cyan. But it could also be due cyan ink has run out and ask to be replaced as new. Please check the contents of cyan ink may have run out, if still a full release catrid cyan and black, then attach it again, then go into maintance, and do head celean and do nozzle check or test printing
Aug 23, 2011 | Brother Multi-Function Center MFC-3360c...
Have replaced old black ink caartridge plus the other 3 ink colors and machine still says replace black ink cartridge which i now have 3 times now and it still repeats the same message. whats wrong?
Probably the printhead of black cartridge side in the printer is damaged in the worst scenario.Else,just clean the contacts where the black cartridge connects after snapping into the printer,with some cleaning liquid (Nephtha,CCL4)etc.I hope this solves the issue.
Aug 21, 2010 | Brother Multi-Function Center MFC-3360c...
After installing new cyan cartridge, display reads No Cartridge
look at the ink cartridge and and first see if the ink covers the top of the cartridge. there is a little part of the ink cartridge the best way to explain it, is there is a tab,. that tab goes into a sensor. if the tab has ink on it, then you mostly like have a problem with the sensor itself. but if there is no ink, the printer is correct. i have had several people bring printers with those type of problems, and when they bring the cartridge i look at it, and they are practically empty.
thanks
Jun 26, 2009 | Brother MFC-5440CN All-In-One InkJet...
Cyan ink won't print on Brother MFC-665
talked to Brother, cost to much to fix, replaced the printer.
Dec 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Borhers does not print
printer says cyan cartridge needs replacement, however when I replaced it, it says that there is no cartridge.
Betty
Nov 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
Ink problems....
Take all carts out of the machine. Have a look into the cart holder. Is there ink swapping beneath the white plastic? (You might shake the machine ;-)
If yes, the cart holder leaks and needs replacement.
If not (your lucky!) it could be that the automatic cleaning procedure which starts when a cart is changed has soaked the carts empty.
Do set machine with date and time and NEVER unplug NOR use a power switch which breaks the power supply.
Do use constant power and switch off machine by pressing stand-by-fax-button!
Everytime when machine comes to (new) power contact it runs an extensive ink cleaning procedure. thats why your carts are always near empty....
The stand-by will prevent this and machine does some cleaning procedures which consumes only a few drops(!) of ink!
The display asks you if you have changed the carts. Do answer this question by pressing 1 for YES or 2 for NO.
This will reset the built-in inkcountermanagement to the correct settings
Jan 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Will not accept new yellow ink cartridge.
Do you use generic carts?
If yes try another cart (always best: original brother carts)
http://welcome.solutions.brother.com/bsc/public/us/ca/en/faq/faq_list.html?reg=us&c=ca&lang=en&prod=mfc210c_all&Cat=11
Dec 23, 2007 | Brother MFC 210C All-In-One InkJet Printer
Changed blk ink cartridge and it says NO CARTRIDGE
see/search brother faQ:
http://www.brother-usa.com/FAQs/faq.aspx?Model=990&ProductGroup=5
Nov 09, 2007 | Brother Multi-Function Center MFC-3360c...
Brother Multi-Function Center  MFC-3360c All-In-One InkJet Printer Logo
1,403 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
