Had new mixer taps fitted on sink and bath (water pressure was fine hot and cold before) but now have very low pressure on hot water. can anyone please help, as its taking 35 mins to run a bath.??????
  • sabr Jun 27, 2008
    yes pressure downstairs in kichen is fine. seems strange that it is in both sink and bath taps. could it be an air lock? if so do you know how to fix it?
  • 958 Answers
Can you check some other source of hot water? if the pressure there is ok?..if it is, then the problem is on the new tap that you fitted.
Posted on Jun 27, 2008
  • francis rivero Jun 28, 2008
    open the hot water line going to the sink. see if the pressure is low . then check also the hot water line going to the tub, see if the pressure is low too , if both pressure are low, then check the pipes that separated the line that goes to the kitchen and the one that goes to the bathroom. there is probably a valve there or a part that could have lessen the pressure going to the bath tub.
    i hope i was able to help. please rate me..tnx.
I have a Vaillant Combi boiler, recently serviced by British Gas, given all clear. Problem we are having is the downstairs hot water tap it is a mixer tap, the cold water is fine but the hot water is
Boilers are inherently dangerous for the average DIY for so many reasons, contact British Gas and have them come back and fix it, tell them it was fine before the "service". They may simply have a control valve shut off.
Sep 23, 2014 | Water Heaters
Oliveri mixer taps
turn off the hot and cold water supply, place a container under the sink where the hose meets the Sink mixer.
release the pressure from the tap by opening the tap to let the water out.
use a suitable tool to undo the flexible hose from the underside of the tap, there should be a small "O" ring on it which you will have to replace as the "O" ring is possibly the cause of the leak.
Oct 01, 2013 | Home
I have a mixer tap in the kitchen sink. The hot water tap runs fine but I am not getting any cold water. I also have a bath downstairs and the cold water tap there is fine
You will have to turn off your water mains and strip your mixer tap. It is possible that the seal (if it is an older tap with a rubber seal) has become stuck or the threaded part that turns it has gone faulty. If it is a modern tap with ceramic seals, check the operation of the mechanism and see why the ceramic seal is not being opened.
Mar 26, 2011 | Microwave Ovens
Low pressure from immersion heater to mixer taps on bath can i fit a pump on the pipe work leading to the bath
You need to have an higher head of water on the tank that feeds the cylinder that the immersion heater is fitted to. Put the tank on a framework say 3 foot above its present level.
Regards
Alan Hood
ami-man
UK
May 10, 2010 | Plumbing
Hi! My hot water taps from the wash hand basin and mixer bath has low pressure. I`ve got a combi boiler in the first floor. Can I install a single impeller pump connected from the hot water outlet from the...
In a word no. Combi boilers work on balanced pressure.ie the mains cold supply to the boiler should be around 1 bar minimum which would give a hot water pressure of the same 1 bar. Assuming the cold water pressure is fine, it sounds like you have a restricted flow on the hot side. If you live in an area with water problems the hot water systems pipework calcify over time effectively reducing water flow. Unless any flexi hoses are kinked, check if there are any filters in the appliances that may be blocked.Also check all valves are fully open and if possible check if there are any restrictions at the valves. Failing all that and the taps are in good order it is possible to fit a pump before the boiler but this may only be a temporary fix overall.
Apr 04, 2010 | Plumbing
I have mixer taps on my bath, hot water tap doesn't work
you may just have to replace the hot/cold stem
Mar 11, 2010 | Home
I have mixer taps on my bath, cold water tap works
Remove the tap outer cover. Take out the barrel & inside there is the washer on the end of a screw which slides in and out when the tap is turned. This could have been turned too far out and will not go back in. Clean both the screw thread and inside the barrel, lubricate with petroleum jelly or similar and reassemble & test before replacing the barrel. Again lubricate all threads.
Alternatively buy a new barrel
Mar 11, 2010 | Home
New Price Pfister Ashfield Bath Faucet - Hot H20 pressure is weak
I had the same problem. I simply removed the small brass fitting that the water supply screws onto.i removed the screen that is inside the brass fitting. Now the pressure is fine.
Feb 15, 2010 | Price Pfister Pfister Ashfield Wide Satin...
Water pressure in master bath/shower very low. Sink ok. Could it be the hot/cold mixer?
Yes, if the rest of the house is ok, then the point of failure is more likely the control at that point.
Nov 08, 2009 | Cars & Trucks
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Heating & Cooling Logo
156 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
