Question about Acer Computers & Internet
Acer 3680-2682 laptop---key cover for #5 fell off--other than gluing-which I don't think will hold-do they sell just a key number to replace?
  • 405 Answers
You would have to replace the whole keyboard as one piece, as they don't sell the keys separate.
Good Luck
Posted on Jun 27, 2008
The front glass of the oven door fell off, didn't break....but, how do I put it back on? Was it just glued?
Hello. Notice in pic 2 of the exploded diagram of the door, part 359 which is the bottom door trim, part# WB07K0379. I believe this holds the glass in the door if I'm thinking of the right model oven. The glass door steel cover (designation 314) is WB57K10049. I'm not sure if your glass panel was glued to the steel cover--that's why I gave the part number for it--just in case it can't be repaired. If you need more info or part numbers, leave a comment and I'll be glad to help you further!
Sep 21, 2015 | GE Profile Spectra JGBP90 Gas Kitchen...
Replace key to keyboard
Learn how to remove and replace keyboard key of Acer laptop - http://imgur.com/a/asQTR Simple Steps to Replace Acer Laptop Key
Mar 19, 2013 | Acer Computers & Internet
Keys 5, 6, r, t, f, g, v don't work on Aspire 4720z. What should I do?
1.Power off the Acer laptop and flip the unit over. Slide the battery release lever over and lift the battery out of the laptop.
2.Turn the laptop back over and open the lid. Look inside the open area on the keyboard where the key would normally go. Check to see if the plastic retaining clip is still inside the hole.
3Locate the plastic retaining clip if it fell off the keyboard along with the key. Use a pair of tweezers to set the clip back inside the hole. Line up the holes on the clip with the four raised nodules inside the keyboard hole.
4.Set the key back onto the plastic clip. Push the key down until it clicks into place.
5.Flip the laptop back over if there are keys that are not working properly. Use the Phillips-head screwdriver to remove the three screws on the left side of the case that hold the keyboard in place. Turn the laptop back over so that you can see the LCD screen.
6.Push the thin end of a flat-head screwdriver under the LED indicator strip above the keyboard. Pop the strip upward and pull it off the laptop.
7.Lift the keyboard up towards you until the long ribbon cable running from the bottom of the keyboard to the motherboard comes into view. Unplug the cable from the port on the motherboard and then pull the keyboard and its ribbon cable off the case. Spray out the underside of the keys and the inside of the Acer laptop case with canned air.
8.Reassemble the keyboard, LED indicator strip and battery.
Sep 28, 2011 | Acer Aspire 4520-5582 Notebook
I can't seem to find a straight answer without
Manufacturer warranty is typically 1 year limited parts. This means if a hardware, NOT software goes bad within 1 year of purchase date you can contact acer to get a RMA number and ship them the laptop for a part replacement. This does not cover accidental damage, ie you drop the laptop, split something on it or drop something on it.
Places like best buy will sell two types of extended warranties, and are typically 3 years. The cheaper will cover the same thing as the manufacturer but for 3 years. They also sell a more expensive warranty which will cover accidental damage as well. None of these warranties will cover acts of god, theft or software problems
These extended warranties will be the same thing if purchased from acer or any other computer retailer. Also sometimes they are longer periods of time like 5 years.
If you need further assistance please comment back.
Aug 09, 2011 | Acer Aspire AS7551G5056 173Inch Notebook...
Laptop button fell off my lenovo y510
I have the same problem on my lenovo laptop. Apparently it needs a new keyboard completely which is £70 dianogis charge, £212 labour charge plus parts plus vat as a keyboard is not covered by warranty!!!
Oct 10, 2009 | Computers & Internet
Keys popped off
look at the bottom of the keyboard for a model or part number then try searching by that. You can usually find replacement keyboards on ebay.
Aug 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
Spacebar replacement
Crazy Glue. Individual keys are not available for resale at reasonable price. You could replace entire keyboard cheaper. That is an option for you. Contact local pc shop.
Dec 28, 2008 | Acer Aspire 3680 Laptop
Cant find the number lock key on my acer 6920 laptop
I think for your laptop the number lock key is a second function... Try holding down the function (Fn) key and pressing the F11 key, hopefully that will turn your number lock on/off.
Nov 23, 2008 | Acer Aspire 5100 Notebook
Where can I get laptop key?
Ebay is the best place, or a small computer shop that sells used laptops. On Ebay there are several vendors that sell individual keys, however, you may be able to get a good deal on an entire keyboard, then you will have many keys for future mishaps.
Jul 21, 2008 | Acer Aspire 5500 5570-2609 Laptop
KEY PAD OF LAPTOP
This link may help:
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
Dont forget a fixya rating if this solution helped :)
May 11, 2008 | Dell Inspiron 630M Notebook
Computers & Internet Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
