I would check all electrical connections on battery and motor and clean as needed. I really think that you probably are going to need a new battery as it sounds like this one is not holding a charge when it is being used. It should dischargeslowly with use but as the battery gets weak it will discharge at a much faster rate. I hope this helps you, Thanks
Hello dvaldez. The problem is not with the scooter but the battery. When a battery no longer takes a full charge you generally have to replace it. Any auto parts store will test that battery for you to see if it is indeed the problem. This is a free service. Joe
Thanks for choosing Fixya!
My batteries have been tested, they good. I need to know why after they have been charge to full I use the scooter and within an hour they die?
