My laptop Lenovo G550 2958 boots up but then the display is not working. I tried connecting the same to a external monitor but still i dont have any display.
Its a new laptop and i dont know wats the problem. Could somebody help.
There could be several reasons why the Lenovo ThinkVision monitor T27h-2L is not working with the Thinkpad P50 laptop. Here are some possible solutions:
1. Check the connections: Make sure that the USB-C cable is properly connected to both the laptop and the monitor. Try using a different USB-C cable to see if that resolves the issue. Also, check if the USB-C port on your laptop is functioning properly.
2. Update drivers: Ensure that you have installed the latest drivers for both your laptop and monitor. You can download the latest drivers from Lenovo's website.
3. Change display settings: Sometimes, changing the display settings can help resolve issues with external monitors. Go to "Display Settings" on your laptop and select "Extend desktop" or "Duplicate desktop" to see if that helps.
4. Reset monitor settings: If none of the above solutions work, try resetting your monitor to its default settings. To do this, press the "Menu" button on your monitor and navigate to "Factory Reset."
If none of these solutions work, it's possible that there may be a hardware issue with either your laptop or monitor. In this case, you may need to contact Lenovo support for further assistance.
Download and install the display driver from the link below:
http://support.lenovo.com/us/en/products/laptops-and-netbooks/lenovo-g-series-laptops/lenovo-g550-notebook
Virtually all IBM and Lenovo ThinkPad and ThinkCenter laptops allow you to hook up an additional monitor or projector to the computer. When you add an external monitor or projector to your notebook, you can choose to view the display on the computer, on the external device, or on both the laptop and the external monitor or projector at the same time. Toggling between viewing devices is as simple as pressing a couple of keys on the keyboard.
Shut down the laptop. Plug the VGA monitor cable from the external monitor or projector into the blue VGA port on the back of the computer. Turn on the external monitor or projector first, and then the Lenovo laptop. Allow the notebook to boot into Windows normally. Press the "Fn" and "F7" keys at the same time to switch the display from the laptop to the external monitor or projector. Press the "Fn" and "F7" keys again to enable the display on both the laptop and the external display device. Press the "Fn" and "F7" keys again to display screen contents only on the laptop LCD. choose support you need http://www-307.ibm.com/pc/support/site.wss/MIGR-54305.htmlhttp://www-307.ibm.com/pc/support/site.wss/MIGR-4YQHUC.html enable tv out on thinkpad http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58625
So Power is on but no display. Does it look like the laptop booted all the way? Does it look like the laptop is running but there is no display?
If the laptop is running, you hear the fans running, the hard drive running, etc. but the display is black, try the steps below: Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
my LENOVE G570 screen just got broke last time while im watchin dvd.a crazy RGB shown-up and i dont know why!! then i start looking for "how to open a Lenovo G570 screen" then i came up with this
http://www.youtube.com/watch?v=3FwSoAzEXsw
then i start cleaning the surface using pressured air from my balloon maker. .then i remove the "jack" or whatever you call that. . and erase it with a pencil eraser then put it back!!
Sounds like you already have LCD problem. Try to test the issue further. Use an external monitor and plug it to your laptop. If you get a display using the external monitor then the problem is the LCD. If there is no display coming out then the problem is the motherboard.
connect an external monitor to your laptop and check if you get display on the external monitor. if there is display than the issue is with the laptop monitor and you should replace the monitor screen, if the problem still remains the same when you connect the external monitor than it could be a software related issue. check and see if you get any display in BIOS mode. if you do then it could mean the OS is corrupted and you should reinstall the OS
