Question about Fossil CH2331 Wrist Watch
Mans fossil blue watch
How do you take out the links when arrows are pointing both sides
  • 3 Answers
The arrows mean that the pins can come out both ways.
Posted on Aug 23, 2008
I need instructions on removing links from a Fossil Stella watch
you will need some sort of tool for a pin pusher to actually remove the pin from watch . It can be a strong needle of some sorts but I suggest getting an actual pin pusher to prevent from damaging the watch or hurting yourself.
if you look inside the watch band itself you will see on the links an arrow pointing one direction. That is the direction you need to push the pin since the pin head is larger and cannot be pushed the opposite direction .
On the side of the watch links you will see a small circle endented with a pin head. That is the link pin. Place your pin pusher or other similar sized object and with a small or jeweler hammer slowly and lightly hit the pin pusher down until pin comes out of opposite side , you can use tweezers or needle nose pliers to pull pin all the way out
There are some pin removers that screw also or just push down to pop pin .
Once out repeat process until you have removed enough links that watch fits comfortably. Then slide pins with head of pin entering the side where the arrow on back of link is pointing to. Once all the way in gently hammer rest of pin till flush with link .
Oct 17, 2010 | Fossil FS2919 Wrist Watch
How do i install additional links to this model watch? the company mailed me 2 additional links but no installation instructions Fossil model ES1967
  • Turn your watch on its side so the links are vertical. On the inside of the links closest to the clasp you can see arrows, which point in the direction that the pins must be pushed out. Only about four links on either side of the clasp have arrows, because these are the only links with removable pins. On the edge of the links on the opposite end from where the arrow is pointing you will see a small circle where the pin is inserted.
  • Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • Insert the new pin into the watchband. You will need to insert two pins, the pin you removed in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Aug 18, 2010 | Watches
    I have a Fossil analog / date watch and need to remove a couple of links. The arrows on each link point in opposite directions. I tryed pulling the ends the respective directions to no success
    There are some instructions on the Fossil web site but they are not too easy to find.
    Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care" and then look under "Product Info" on the left and you will see "watch instructions"
    Go down the list to the bottom and under "Phillipe Stark" there is an item "bracelet instructions".
    Feb 13, 2010 | Fossil AM3726 Wrist Watch
    I bought a fossil ss blue am3733 on a cruise ship. It has worked perfectly untill the battery died a momnyh later. No one i Dothan ,Al knows **** nabout fossils. I lost my casio in the keys and had a rolex...
    All I can say is: RELAX. You are tooooooooo winded, so, need some RUSSIAN lads to calm you down. For a while take a sauna. If you can withstand 110C, you are the man. If you can beat me (175C) you are out of this world. Good luck.
    Feb 05, 2010 | Fossil AM3733 Wrist Watch
    Fossil AM4200 shorten band
    Depending on the age of the watch you will see indicators of pin direction on the inside of the band. Little arrows that point the direction the pins should come out. If there are no arrows you can look at the edge of the band. You are looking for a split in the pin that makes it look like a screw. The opposite side will be solid. You want to push on the side that is solid so the side that looked split comes out. This is a cotter pin and the split side is bigger and needs to come out first. Use a small punch to push the pins out. Make sure you take links from the band evenly on either side.
    Jun 09, 2009 | Fossil AM 3688 Wrist Watch
    Trying to remove links on a fossil watch w/arrrows pointing out
    Are you pushing the links in the same direction as the arrow is pointing? If so, are you using a tool specifically made for removing watch links? If the answer to both of the above is "yes" then look closely at your watch. The pin will look different on both sides. One side will look like the head of a "screw" and the other will look rounded and just come to a point. You always want to use the watch link remover tool on the ROUNDED end and push the "screw" looking end out. It could be that your watch was assembled w/the pin facing the wrong direction.
    If you appreciate me solving this for you then please rank this solution as "fixya" or at least "helpful", thanks!
    Jan 08, 2009 | Fossil AM3726 Wrist Watch
    Trouble sizing Fossil Watch CH-2506
    Those arrows inside of the watch band are showing direction for pins or clips to come out. If you have two arrows in opposite directions on one link, that means there are two pins or clips and each one must be extracted from arrow pointing side.
    If there is only one arrow on the link- there is only one clip or pin and must be extracted the arrow pointing way.
    Some watch bands are held together by very specificly made clips or pins. In this case you will need a special tool to extract them.
    Jan 02, 2009 | Fossil Chronograph Urban White Dial CH2506...
    Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
    Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
    To shorten the band you have to:
    Extract the pins.
    Take link(s) off.
    Join the rest of band together and drive pins back.
    Jan 01, 2009 | Fossil JR8096 Wrist Watch
    I need to know how to remove links from a Fossil watch with a metal band that has arrows pointing the opposite directions. Can you help?
    That means you can take the links out either way. Take a small pin that fits in the hole and lightly tap on the pin. If you find you have problems, add a LITTLE oil in the whole, this should make it easier, though a little messy.
    Aug 03, 2008 | Fossil Watches
    Trying to shorten the band on a fossil watch. removable links have arrows which point outward on both sides of the link.
    You need a small, (smaller than the pin hole) punch to force the pins out of the band. Since the arrows point in both directions you can push from either direction. Push enough of the pin out to be able to grasp it with a pair of small pliers and remove it. Do that on both sides of the link, replace the extra with a small hammer and you're done.
    Sarvadrk
    Jun 18, 2008 | Fossil Watches
    Fossil CH2331 Wrist Watch Logo
    1,179 people viewed this question
    Top Fossil Watches Experts
    Ansel Alberto
    Ansel Alberto
    Lyle Siemens
    Lyle Siemens
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
