Question about Nintendo DS Lite
Broken ds lite. the games were inserted into slot 1 the wrong way round. the pins are bent.
  • sxi6 Dec 27, 2008
    pins are totally bent can i get a part to replace it if so does any1 know what it is called?
  • 210 Answers
The part with the damaged pins is the slot-1 port. I know it seems rediculous, but this part is too impractical for most people to attempt a repair.
However, if you are savvy enough to attempt the repair of the damaged pins on your DS Lite, here are my recommendations:
1) Cut a flap in the slot-1 port cover and straighten pins.
2) Replace the main board.
3) Remove the slot-1 port cover and straighten pins.
4) Remove the damaged pins from the slot-1 port and straighten.
5) Replace the slot-1 port.
All of these recommendations require disassembling the DS Lite using a specialized triwing (or Y) screwdriver and a lot of patience. The following video will help in disassembly: http://www.youtube.com/watch?v=HQlTpTLUyFQ.
Recommendations 3 to 5 all require solder work. Recommendation 3 requires solder work for 4 solder joints, 1 at each corner. Recommendation 4 requires solder work for up to 17 solder joints, one for each damaged pin. Recommendation 5 requires solder work for all 21 solder joints.
Posted on Jul 10, 2009
"there is no ds card inserted" error appears even
Check for broken or bent contact pins on the card slot. If all seems fine in there, try cleaning it up.
Jul 12, 2011 | Nintendo DS Lite
When i insert in a game in my nintendo ds lite it says there is no game inserted and when i insert a gba game into it it works please help me! thx
Check the SLOT 1 for bent pins. You will need to look inside the slot, preferably with a torch and see if any pins are bent out of shape. If you see any bent pins, use a small screwdriver to gently bend the pin back to where it should be. Check also for any foreign items in the slot which may prevent correct contact.
Mar 10, 2011 | Video Game Consoles & Games
My daughters ds lite has a few problems. The calibration is out and wont fix when i calibrate it. It wont play ds games but will play gameboy games. Please could you tell me if these problems cn be fixed?
The touch screen may be faulty but can be replaced. The SLOT 1 game slot may have bent pins or broken pins. Bent pins can be easily fixed (with care and patience) but replacing the SLOT 1 or the touch screen is quite difficult. It is probably repairable but only by someone who knows what they are doing.
Feb 15, 2011 | Nintendo DS Lite Console
My ds slot does not show up on my choose games even though i put the games in it says 'no ds card inserted" please help me i have my ds but only the gba slot works
There is probably one or more bent pins inside the top slot (SLOT 1). Remove the battery by removing the battery cover on the bottom (held ny a screw). Shine a small torch into SLOT 1 and look inside to see if any of the pins are bent differently to the rest of the pins. If any pins are bent they can be bent back to their correct positions by using a suitable small tool such as a precision screwdriver. If a pin is actually broken then the complete slot will need to be replaced.
If it is not a bent or broken pin, there may be some other type of blockage inside SLOT 1.
If there is nothing wrong with the pins and there is no blockage inside the slot, then there may be a dry joint where the slot is soldered to the PCB inside the DS. This kind of fault will require the DS to be opened with a special tri-wing screwdriver and the use of a multimeter to check all the connections. If you have soldering experience (and tools) then you can try re-soldering the connections.
Be advised that opening the DS is much easier than putting it back together again!
Feb 14, 2011 | Nintendo DS Lite Console
My Ds Lite isn't recognizing the ds game/ says there is no ds card inserted. Please help.
check the connector where you plug the game it maybe dirty or some pins broken
Nov 04, 2010 | Nintendo DS Lite Console
Have two ds lites they wont load the games it just says to insert the game but they r in ,any ideas?.Thanks
There are possibly 3 things wrong.
1.) Your games are bad, since this is happening on both DS Lites.
2.) Check your pins inside of the DS. If they are bent, they wont read, but if they are slightly bent, you could actually straighten them yourself with a long skinny tool.
3.) The memory on both your ds lites are blown.
My solution: I ask that you place alcohol on all of your games and insert them and remove them 5 times to lubricate the pins, then on the 6th insertion, cut the game on to see if it reads.
I hope this helps :)
Apr 05, 2010 | Nintendo DS Lite Console
DS Lite no longer recognizes games when they are inserted
My best suggestions for resolving the bent/ broken slot-1 pins are:
1) If under warranty then send it off to them for repair.
2) Find a local repair place and give it to them to repair it.
3) If you have good soldering skills and fancy a bit of DIY repair you can have a go at sorting it yourself.
To be honest its far easier to just replace the entire slot-1 part than it is to take the part apart and repair it, the cost of the slot- 1 is very reasonable from ebay.
I have a few guides written up to help you if you do decide to take the DIY option, they are as follows:
DS lite slot-1 replacement guide
DS lite dismantle guide
Hope this helps, any further help or advice you may need then feel free to contact me.
Regards,
SOD69
Mar 13, 2010 | Nintendo DS Lite Console
Nintendo ds lite not reading games says no game inserted sent it back to be repaired and problem not sorted
Look down in the game slot and see if all of the pins are intact. Sometimes one of the pins will get bent or broken which doesn't allow the unit to read the game. A new game slot can be purchased off of ebay, but if you dont' have any experience soldering, I would recommend finding someone that is or take it to a repair shop.
Nov 08, 2009 | Nintendo DS Lite Console
How come my DS is not playing my new game?
If that is happening with all the games then its like your slot1 is broken.
Check for bent or broken pins in the DS slot. If anything wrong you might need to send it for repair the slot1.
At last resort you can try inserting a piece of cardboard soaked in alcohol carefully in the slot to clean the pins (if not broken) or open the console and try to lift the pins a bit to allow it to make good contact.
Regards
Oct 17, 2008 | Nintendo DS Lite Console
Nintendo ds lite won't read card
had this problem, i looked into where the game goes and one of the little metal teeth was bent, so i took a long toothpick and gently pushed it back over now it works fine. Be careful that you dont break it off though.
Feb 08, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Logo
769 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
