Question about Gestetner DSm645 Digital Imaging System
Making black copies
Copies are black . is this due to scanner problems?
  • Gestetner Master
  • 2,794 Answers
Depends on how you scanned it by having the lid opened and no paper on the scanner. Are they totally black?
Posted on Jun 27, 2008
Why does lines appear in my printed copy?
If you're getting lines, especially when making copies or scanning, it could be due to some dirt on the scanner glass. Wipe your scanner glass with a lint free cloth. Then try scan or make a copy again to verify that the problem is fixed.
Mar 04, 2012 | Lexmark X1150 All-In-One InkJet Printer
When i make copies on the machine, there is a wide black strip vertically on the copy
The one solution to ur problem is clean the scanner or optics of ur machine, here's the procedures lift the top potion of the control panel and u will see the scanner, then clean the optics with cleaned cloth be sure that there is no patch or any foreign object in optics area. Second solution is check is the drum life is due or check the surface of the drum if there is a vertical line in the surface that is the one caused of ur problem. It is necessarily to purchase the new drum unit. Hopefull this will help u.
Aug 02, 2011 | Brother IntelliFax-4100e Fax
The printer is streaking black streaks through the copies. What can I do to fix this problem?
If printing from your computer prints clear pages with no streaks, then the problem could be due to some dirt on the scanner bed. Grab a moistened soft cloth and gently wipe the scanner glass to clean it. Try to make a copy again.
Jul 12, 2011 | Lexmark X2600 InkJet Printer
Black pages received when faxing to others
Your scanner array is bad. This is a light "bar" that lights up to scan your originals before they are sent out. You can test for this by making a copy with your machine. The same scanning function is used to make a copy as it is when you scan to send a fax. If you make a copy and it comes out black then your scanner is bad. This is especially true as when you say that the problem goes away for a short time after turning the machine off. This allows the circuit to cool and the solder connections to shrink and make contact. As the board heats up the metal contacts expand and "open up", causing the scanner to fail.
Not a cheap fix unfortunately.
Good Luck and Thank You for using Fixya.
Mar 16, 2010 | HP LaserJet 3050 All-In-One Printer
Scanner will not initialize properly, can make
If the scanner is not positioned correctly ,indiferent to make a copy to use the ADF or make to the original glass the copy problems is identical.Clean the scanner glass,original glass and the white level band,the erase lamp and check the OPC drum.If the problem persist need to perform the FD and CD adjust for the paper tray.Make someone copies use the A4R tray,and A3,and see the different.
Please answer to help you.You need the position correctly the problem source.
Aug 21, 2009 | Sharp Office Equipment & Supplies
WHEN I MAKE COPIES THE PAPER HAS BLACK STREAKS
Problem is ambiguious but print out a report from your machine and if it comes out black, it is likey a toner cartridge problem. But if its OK make sure your scanner lamp comes on when reading the original
Mar 20, 2009 | Brother IntelliFax-2820 Laser Fax
Problem with using the printer copy feature
Please make sure you are positioning the page to be copied on the scanner bed correctly. There is usually one corner of the scanner where you should place the page.
Most scanners mark the "home" corner with either some obvious tic marks or even painted arrows.
Mar 05, 2009 | Lexmark X6170 All-In-One InkJet Printer
Outgoing faxes are black.
just copy a paper if copy is black ur scanner is dirty or dead .first clean scanner with tissue other wise change it.if copy is ok result not black that is due to telephone line.by mian jee
Dec 15, 2008 | Brother IntelliFAX 5750e Laser Fax
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Unusual noise
scanner unit initialises on power on condition. scanner unit moves to right extreem end and makes banging noise. This problem is due to scanner unable to find the home position. open the flat bed glass unit . one end of there will be black colure with white stip. apply black marker ink on black colour and fix the blass back to griginal position. scanner will work.
May 06, 2007 | HP PSC 1610 All-In-One InkJet Printer
Gestetner DSm645 Digital Imaging System Logo
42 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
