Question about Intel Motherboard
Bios i work on my com. after 2weeks.then i found that com. restarts regularly when windows is loading.after some restrarts amsg come on the monitor that"boot block compatible version ver .003,bad bios checksum.starting bios recovery".now the monitor didn't turn on. please help
    Problem Solver:
  • 9 Answers
Try to go to safe mode choose system restore. If you cant get through it. Unplug your power cable.Then its time to open your pc ground yourself with anti static pad b4 touching it to the computer. Take the cmos battery, return it after 30 seconds or more then put back battery again. Plug your pc turn it on. If is not working try to update your bios.
Posted on Jun 29, 2008
Suddenly my computer is shut down i dont know how but when i try to restart its not working so i download window 7 then i restrart but when i buy my computer its window vista so i want same like before...
Kanwalpreet, you can go to Microsoft solutions web site for vista and with a little searching you can download vista fully onto you computer. Although I don't know why you would want to do so since you have Windows 7, because the technical name for vista is Windows 6, so you have already upgraded your system. Well to each his own, good luck .
Jul 13, 2011 | Compaq Presario CQ60-220US PC Laptop
I defragged my computer, restarted, and now my monitor won't come on. When on button pushed, get a green power light but the monitor stays black - cannot get anything on screen :( Helllllpppp!
Please try booting with your windows DVD and see if you screen loads, on that boot DVD you should see an option to repair install, try that. But if after booting to your DVD you see your screen come up, just try a regular restart again before doing a system repair.
Feb 28, 2011 | Impression Products 7LSP Monitor
My computer was infected with Security Shield before the problem started. I was trying to remove it when my desktop shut down and only restarts with a black screen with a cursor. When I shut it down and...
That arrow is the way in which the BIOS is telling you tat it can't load any files - your Windows has been completely corrupted. The only thing left for you to do is to reinstall it using the recovery disk that came with it when you bought it.
Dec 13, 2010 | Dell Dimension E520 PC Desktop
Monitor fine with 1 PC, no RGB input after windows load on other?
Lower the resolution on the computer to 800 x 600 and then hook up that monitor see if it at least accepts that and doesn't go black. You may have to go into safe mode to do it plus then go back into regular mode.
May 07, 2010 | HP mx705 17" CRT Monitor
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
TDLR
When you first turn on your computer keep pressing F8 to bring up the startup menu. Choose the option that says "safe mode". If you can get into safe mode, then try to do a system restore back to the last date you have available and then reboot and you should be okay.
If you can't get into safe mode and you get the same error message then you have corrupt system files and you'll need to wipe out the drive and start over.
Feb 08, 2009 | SuperMicro SUPER TDLR (MBD-P3TDLR-O)...
Touch screen frozen
Try restrarting your mp4 touchscreen. If that does not work then hold the off botton or restart botton. If that does not work email me ASAP at abdalmohamad@gmail.com
Dec 29, 2008 | Digital Mind Corporation iQ Sound...
Will not display output from Computer
Probably the video resolution or the monitor Refresh Rate (eg: 50/60/75 Hertz) is set too high in the operating system, which over-drives the monitor electronics and it is unable to display anything.
If you restart the computer manually (hold in the power button for 5 seconds, the computer will shut off, turn it back on again) you will see the normal BIOS and Windows startup display on the monitor, but then as Windows completes it's startup it returns to the error message you see.
To fix this, restart the computer manually and start the computer in Safe Mode. To do this press F8 just before the computer starts to load Windows, and choose Safe Mode. Once in Safe Mode, you should see the monitor working correctly.
Now restart the computer in Normal Mode and everything should be fine.
Dec 23, 2008 | Westinghouse LCM-19v1 Monitor
'input not supported'
just had this problem and just fixed it. all you need to do is unplug it directly from the outlet then turn on it worked for us so hiopefully it will work for ya'll
Sep 07, 2008 | Computers & Internet
Emachines 2792
pull the power plug as soon as the emacines logo comes on
and if that doesn't work pull out the power as soon as the first windows logo screen comes on. it should then come on and give you the option to start in safe mode or regular mode, choose safe mode then after it comes on in safe mode restart the cpu
then it should come on in regular mode i don't know why it works for my emachines cpu but it does . i'm looking at downloading a error fixing program because i'm doing this almost when ever i turn off my cpu hope this helps if not reformat your hard drive andput windows on again it worked last time i had this problem.
Apr 29, 2008 | E-Machines T2792 PC Desktop
Intel Motherboard Logo
102 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
