Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Problem with my remote
My remote is locked out and it shows dvd2. I have been unable to get into the correct setup menu to rectify this problem. The item is new and and this happened when I was trying to set it up for the first time. Please can you help.  (bobhg2000@hotmail.com) Bob.
Sounds like it needs to be reprogrammed get hold of manufacturer
as its new they owe you one
Posted on Jul 06, 2008
I accidentally changed the settings on my remote control using the on screen menu from dvd1 to dvd2
I'm not sure the question - perhaps your TV is set to the DVD2 input and it's not a DVD issue.
If so, using your TV remote, push the "input" button until you reach your desired input.
Apr 07, 2015 | Televison & Video
Sony dvd recorder rdr-gxd310
Click here to get the user guide and go to page # 21.
May 23, 2008 | Televison & Video
Panasonic dmrez27 dvd recorder stuck on dvd2 setting
If you point the remote towards sensor, simultaneously hold down the number (1, 2, etc) you want AND the enter button for 5 or more seconds it should switch to the number pressed. Remember if you have a second one, make sure it's off or put towel over its remote sensor. Sue
Feb 20, 2010 | Panasonic DMREZ27 DVD Recorder
DvdRDR-GX360
It´s is easy to solve. Your DVD was seted to DVD1. Push enter button plus 1 no remote control.
Now you are able to commnad your DVD and go to System Menu and change to DVD3 again.
After it, don´t forget to backup your remoto control to DVD3. Push enter button plus 3
Dec 13, 2008 | Sony RDR-GX300 DVD Recorder
Can not get my sony dvd to get off of dvd1 and it is now locked u
Go to your DVR and manually turn the DVR off. Press the STOP button for
two or three seconds. The DVR COMMAND MODE setting will display in the
DVR window. (DVD1, DVD2 or DVD3)
Set the remote to the COMMAND MODE setting that was diaplayed by depressing
both the remote ENTER key and the desired number key (1, 2 or 3) and holding
them both at the same time for 3 seconds.
You can now use the remote to set the DVR to the desired COMMAND MODE.
To do this depress SYSTEM MENU on the remote and go to SETTINGS and then
COMMAND MODE. Select either DVD1, DVD2 or DVD3. Once you delect a setting
that is different from what was set, your remote will stop working again.
Reset your remote to the desired COMMAND MODE by depressing the remote ENTER
key and the desired number key (1, 2 or 3) and holding them both at the same
time for 3 seconds. The remote should now control the DVR.
Nov 14, 2008 | Televison & Video
Remote control not working
Look into your manual that came with your dvd recorder for DMR-E80H, Page 46, Changing the Remote Control Code. My child played with a remote control as well and reconfigured it as well. In the manual, you have explanation how to configure your remote control again to work.
Nov 17, 2007 | Panasonic DMR-E80H DVD Recorder
Panasonic DMR-E55 DVD recorder - 'remote DVD2' command
I had the Exact same problem, after finding nothing on the net I called Panasonic customer-Support and they gave me the information which led to the solution:
If your DVD screen reads 'remote DVD2':
Press and hold simultaneously the "2" & "Enter" buttons (for more than 20 seconds)
If the screen said remote DVD3 then you would hold "3" & "Enter"
What I found happens when this command is accepted, the DVD screen changes to display the channel & counter
e.g. "A2 0:00.26"
If the screen changes back to "Remote DVD2" this means that the signal from the remote control has been interrupted (you stopped pressing, or the batteries have become weak.)
Providing the batteries have power, try again remembering to hold the "Enter" and number displayed after DVD.
The first time I did this it seemed to take forever (more than 30secs.), but other times it's been accepted in 6 secs.
Oct 28, 2007 | Alesis MasterLink ML-9600
Unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Aug 02, 2007 | Sony RDR-VX555
I had the problem where when i would try to use my remote, it would say "check remote2". I've got a DMR-E55. I called panasonic and they told me to hold down the "enter" and "2" button for about 10 seconds. then it worked. hope it works for you too.
Jul 09, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
59 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
