Question about Pioneer Elite VSX-9100TX Receiver
VSX-94THX 7.1 Remote and Face Controls Fail Often
I have this problem repeat often like every day. The manual says unplug and replug and this is the only way to get it working again. I'm beginning to think this thing is not worth the Beer Cans it must be made of.
  • atgjdr Jun 27, 2008
    I must say the suggestion was an absolute fix for my problem. Even though I couldn't understand exactly what "mains" were or an "anti surge lead" was I googled these and found that they are apparently terms for Power Company Main lines and RFI EMF Surge Protector Power Conditioners in European Lingo. Never the less thank you very much, you have saved me a trip to the Pioneer repair shop and for less than a hundred dollars I now have no problem with my unit. It now opperates flawlessly in every way.
    Andrew
  • atgjdr Jun 28, 2008
    I had thought that your suggestion had fixed my problem. The reason is because it worked for a whole day without missbehaving. The very next day it failed repeatedly. So the RFI, EMF Surge Protection didn't work. Pioneer has told me that I can bring it in under warranty so I think I will unless you think that filtering each and every component going into the unit will fix the problem or if you have another idea that may fix the problem. I have about $80.00 into trying to not bring it in to Pioneer Authorized Service, but still would rather not if I don't have to.
    Thanks;
    Andrew
  • 63 Answers
It could be mains spikes, interference on the power supply from another device.
Try plugging the unit into an RFI suppression anti surge lead and see if that helps.
Regards
Andy
Posted on Jun 27, 2008
  • Andrew Real Jun 28, 2008
    If Pioneer will take a look under warranty I would suggest you take them up on it to be sure.
    You could also try running that unit on the Power Conditioner with nothing else connected to it, just to rule out your other products.
    Regards
    Andy
Pioneer vsx-32 won't turn on with remote
Hi, since both remotes suddenly fail, I am assuming the problem is more than likely with the received rather than the remotes.
If you do wish to check your remotes, then point your mobile phone camera at the remote's Infrared lens and press one the remote's buttons. Your mobile phone camera is able to detect Infrared light and in case you remotes are working properly, you should see light coming out of your remote's Infrared lens.
Make sure that no direct sun light is on your receiver because that can effectively block out the signals from your remote controls.
Try the following method to reset your receiver. Unplug your receiver mains cable from the mains wall socket; power your receiver on by pushing the on/off button (nothing will happen obviously) and leave it like that for say 30 minutes. By that time all capacitors in your receiver will have discharged. Plug your received mains cable in the mains wall socket.Push the receiver's on/off button and see if it know responds to your remote controls.
If the problem still persists, you may have a failed Infrared receiver LED. That component can be found inside your receiver. It will take some basic elelectronics skills to get this component replaced. A service manual can help you. You can download it for free from this website: http://elektrotanya.com/pioneer_vsx-32_33.pdf/download.html
Good luck.
Jan 20, 2013 | Pioneer Elite VSX-32
I have a pioneer vsx d608 and the remote works only for the power and muting. I pushed some buttons on the face of the receiver and the all functions worked with the remote (not sure why). I turned it off...
I'm pretty sure the front face buttons have nothing to do with the intermittent success or failure of the remote to work - unless by some chance a given momentary control is 'stuck' on.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 20, 2011 | Pioneer VSX-D608 Receiver
I have a VSX-1015-TX ,I powered it on but have no control from either the remote or the receiver itself,changed remote batteries,unplugged/replugged in receiver still no control,the receiver works as all...
to complete reset, it need pressing couple buttons by combination. if all buttons mulfunction, no way to do this function. does unit have front panel display?
Mar 19, 2011 | Pioneer VSX-1015 Receiver
I need Pioneer AXd7248 remote control manual that I can download.
I have your solution! We were having trouble with this too. As you may have known, the Pioneer AXD7248 came with a receiver, the Pioneer VSX-D409 / VSX-D509S. If you look up the manual for the receiver, you will find how to program the remote on page 23 of the manual and the codes starting on page 53.For the convenience of everyone else who googled AXD7248, here's a direct link to the page to download the manual: http://www.retrevo.com/support/Pioneer-VSX-D509S-Receivers-manual/id/385ci970/t/2/
Jun 25, 2009 | Televison & Video
I have a pioneer vsx3700s receiver,can you tell me where i can find a schematic or repair manual for it?
www.stereomanuals.com
G12 price code = $21.00 + $2.00 shipping
Pioneer VSX-3700S AV Receiver Service Manual = G12
COMMENT: (1990) Also VSX-3600, VSX-3900S, VSX-3800, VSX-411S, VSX-401. (IMPORTANT NOTE) Circuit Diagrams and PCB Pattern Layouts (and Exploded View, Parts List) only, balance (if any) of manual on (1) (not included) microfiche card. There are some separate manuals which are almost entirely for the Remote Controls: for VSX-411S and VSX-401, see VSX-411S. for VSX-3900S and VSX-3800, see VSX-3900S.
STOCK# = PIOVSX3700S-SM
DESCRIPTION: 56 total pages (18 intentionally blank), constructed as the original including (almost entirely) 11in x 17in folded /trimmed pullout pages, card stock covers, neatly assembled with 5 staples and fiber reinforced taped spine. Models covered: VSX-3700S, VSX-3600, VSX-3900S, VSX-3800, VSX-411S, VSX-401. Overall quality is Very Good.
Feb 24, 2009 | Pioneer Audio Players & Recorders
URC3220 remote problem
i have a sanyo tv i need the codes to program it and directions with the allforone...urc3220 remote ty ron t.
Apr 27, 2008 | One For All URC4110 Remote Control
Pioneer Elite VSX-94THX USB problem
There is probably no files on the usb that are recognised. Just a guess check the compatible formats
Dec 29, 2007 | Pioneer Elite VSX-9100TX Receiver
Remote code for Pioneer VSX-50 A/V receiver.
Here are the codes for your receiver:
Pioneer 31023, 30014, 30244, 30150, 30630, 30080,
30531, 31384
Here is a link to your manual:
http://www.directtv-advisor.com/support-...
Oct 13, 2007 | One For All URC-3021 Remote Control
Pioneer Elite VSX-9100TX Receiver Logo
116 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
