Question about Pentax Optio M20 Digital Camera
Turning it off
So how did you get it turned off. i just did the same thing and it will not turn off..........
  • 797 Answers
If you are talking about turning off the camera, it should shut down by touching the same button which you turned it on with.
You can remove the battery and see if the camera will then reset itself and retract the lens.
If the lens will not retract, you have a lens problem.
Posted on Jul 19, 2008
When I turn on trips our electricity safety switch.
try a different outlet .ifit does it there also , I would replace it with a new unit
Nov 07, 2015 | Nespresso 3194-Us-Re Aeroccino and Milk...
All of a sudden, when we send things from computer to printer, it does not print. We have tried everything. Documents just stack up in the que
via direct cable or wi-fi network? Single printer or multiple printers?
If on a wi-fi network, try doing these 3 things: turn off your computer, turn off your printer, and turn off your router. wait 60 seconds or more.
Then turn on your computer, turn on your router, turn on your printer.
Send document to printer
Mar 06, 2015 | Office Equipment & Supplies
Left turn signal light dont turn of
I had a problem with an old car one time where the blinker lever thing would turn on only to one position and not either return to neutral(off) or turn to opposite way. I was told to take off the steering wheel (mark alignment notches on shaft and steering wheel thing that goes on shaft)and look at the turn signal mechanism inside to see what makes it go off:found a broken "turn off" piece of plastic that sticks out to make signal go off when you turn the wheel the opposite way or for when you turn the lever/signal to neutral/off position. It was hell remembering how I took things off;I took a picture before and during the surgery...ha,ha. Good luck!!
Jan 29, 2013 | 2001 Mercedes-Benz E-Class
What's your problem?philips mx 5000d turn on, flash the word protect and turn off
My system has been doing the same thing. I found that if you remove a speaker or two the try again it may work.but if not turn it on and as soon as you here it quickly turn it down,also you may have some crossed wires if so replace them and your system may not have anough output for your speakers.one more thing you might want to try is getting some thicker speaker wire. i hope this helps you and ide like to here how things turned out E MAIL jconthegobikeshop@Gmail.com
Sep 16, 2012 | Philips MX5000D System
Why does my Yamaha receiver control the power for all my components - when I turn off the receiver all my components turn off (or won't turn on when the receiver is off)?
This will happen when connection setup is through HDMI cables between all components. Turning off one thing will turn off all connected things in that setup.
This is not problem, in fact it is feature because HDMI cable has control signals as well including video and audio signals.
Hope these info will help you.
Let me know if connection setup is different or I missed any thing.
Thanks.
Dec 29, 2010 | Yamaha RXV367 Receiver
Desktop PC turns off everytime it is turned on
Ok, let's try to eleimate some things. When it shuts off do you here a click first? This may indicate the hard drive is going bad. How long does it take to shut off if it was the first time in the morning that you turned it on? How long before the second time? Etc? What we're trying to determine here is is this heat related? If so then the power supply or mother board could be the culprit. If you turn it on (first thing in the morning) and immediately go into Safe mode (F8) how long does it take to shut off? If you turn it on (first thing in the morning) and immediately go into BIOS or Setup, how long does it take to shut off? If you press Start, Control Panel, Administrative Tools, Event Viewer and System. Do you see itms that have a red X through them? Email me back and we'll continue with your results.
Apr 01, 2009 | Foxconn 661FXME Motherboard
I was driving home, then the car started to bog down
try putting a wrench on the lowest pulley the belts go around. thats the harmonic balancer pulley. try to turn the pulley which in turn should turn the engine over if its not frozen due to running an engine with no oil pressure.
Apr 01, 2009 | 2002 Pontiac Firebird
Vizio 42 LCD turns on but no picture or sound
32 in vizio turns on but but no picture only blue screen and cant turn channels up or down
Mar 11, 2009 | Vizio L32 32 in. LCD HDTV
I need help!
your main-board needs to be reflash or replaced
Mar 14, 2008 | Nokia 6133 Cellular Phone
Pentax Optio M20 Digital Camera Logo
99 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
