Lg wi fi
I cannot use wifi on my lg laptop since my purchase,i have downloaded drivers from website but all in vain what to do next
in device manager it doesnot show wifi 802.. there is device conflict problem
pls guide.
deepak
  • deepak44
    deepak44 Jun 28, 2008
    what is wireless module? on the box its written wi fi 802 lan like
  • 77 Answers
Did your laptop definitely come with a wireless module inside? Sometimes manufacturers will use the same chasis for the cheaper laptop with no WIFi so you will see the wifi switch and indicator light but there is no module inside
Posted on Jun 27, 2008
Wi-Fi stopped working on my Gateway NV77H19u. I can connect to the Wi-FI from a different laptop. Is there an external switch on the NV77H19u to use Wi-Fi?
Your Gateway either has corrupt drivers or has forgotten your WiFi.
Go into your device manager and remove the WiFi device. Then have your computer search for any hardware changes. It will find your wifi device and reload drivers. If this does not work, you have a bad wifi card.
Semper Fi,
Z
Jan 31, 2018 | Gateway Computers & Internet
My Dell inspiron won't recognize wifi
Hi Mike,
There is a possibility that the Wi-Fi may not have been enabled so please let me know the system model so that I can let you know what needs to be done. You may also send me the system service tag so that if Wi-Fi is already enabled then I can check and provide the right Wi-Fi driver.
Thanks & Regards,
Kiran K
#IworkforDell
Dec 26, 2014 | Dell Inspiron Computers & Internet
No Wi-Fi no light on button
If the button or on/off switch that is provided for the WiFi (may have a line with three curved lines coming off of it as a symbol for the button) is toggled or enabled and the wifi won't turn on, then there is a good chance that the driver for the wifi isn't loaded.
You can tell if the driver is missing by opening the Control Panel, opening System, opening Device Manager and looking for a Network Adapter category. Expand the Network Adapter category by clicking the plus sign and look for a WiFi adapter in there. If it has a yellow exclamation point ! on it then there is a problem with the network card and it needs to be reinstalled. If there isn't a WiFi or Wireless Network adapter in there, chances are it is found under a category called "Other Devices" and it still needs to be reinstalled.
To install it, you will probably have to delete the device out of the device manager (highlight it and press the delete key on the keyboard) and then plug your laptop into wired network connection (usually your router or internet service modem will have a network port that you can plug into directly with an ethernet cable). You'll go to the manufacturer's website, click on support and search for drivers for your laptop. Be sure to go to the network section and download and install the network driver for your system.
For your particular model, you can start here: HP Pavilion zd8000 CTO Notebook PC Drivers
Apr 20, 2014 | HP Pavilion zd8000 Notebook
The wi fi was remove after re formatting the laptop
To reinstall or update follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window and checkis there any thing is in yellow color or yellow question Mark). If not,
• Select "Network Adapters">
• Expand "+" symbol> (check the WiFi adapter is not in Questioned Mark (?)symbol with yellow color). If yes, need to install the drivers.
Right click on adapter (it displayed as unknown) > select update drivers, and specify the path.. to install..
Download the drivers from Website or if you have Motherboard CD, > insert the motherboad CD, browse>select WiFi driverfrom CD or downloaded path > install. After completion, restart computer andcheck.
Jan 19, 2011 | Computers & Internet
Dear sir, i can not see the wireless icon on my laptop
do you have the drivers for your wifi card installed properly. if not then go to manufactures website and download driver software for your wifi unit, are you using xp or vista? find device manager and see interfering hardware.
Dec 02, 2010 | Dell Vostro 1500 Notebook
Does ThinkPad R51 2887-MQ5 support wi fi? how to enable wi fi?
YES ThinkPad R51 2887-MQ5 supports wi fi .
For that make sure wireless network adapter driver installed in laptop.
For that right click on my computer icon thne click on proeprty then hardware ->device manager.
It shows all driver in list.
Make sure wireless driver is there and Enable to.
Make sure WI-FI switch is turned on in laptop.
Then right click on my network places and then click on proeprty you can see your wireless network adapter there then right click on it then click on "view available networks".Then connecrt.
If you need driver for your laptop you can download from below link.
click here
Let me know if you need more assistance.Thanks.
Nov 08, 2009 | IBM ThinkPad R51 Notebook
Wireless no longer works
1st Solution:
Check if the wi-fi card is properly installed under Device Manager. Go to Start then look for Control Panel on the right pane. Under Control Panel look for System and Maintenance and then click on Device Manager. Now under Device Manager look for Network Adapters and collapse or click the arrow next to it. Check if your wi-fi adapter is installed(10/100 or 10/1000 is your LAN adapter, wi-fi adapters usually indicates something like 802.11x(could be agn or g or b) or the word "wireless". If you don't see anything I mentioned above that means your computer is unable to detect any wi-fi adapters installed. Know if you found a wi-fi adapter but there is a yellow exclamation or question mark, all you have to do is re-install the drivers for your wi-fi adapter(you can download the drivers on the Compaq website for free.)
2nd Solution:
Check if the wi-fi is disabled or stopped, if you have a bulit in wi-fi adapter on your laptop they have a wi-fi switch on the side or near the function keys(F1, F2, F3 up to F12). Wi-fi button/switch will have a logo or marking of an antenna that has waves coming out of it and there is a LED light that will indicate if its on or off(for Comapaq laptops it's either a blue button at the front, near the function keys or at the front panel on the buttom edge.
If both fails then you may need to contact Compaq for further assistance.
Hope this will help you fixin the wi-fi problems on your laptop.
Regards
Nov 23, 2008 | Compaq Presario Notebook
Lg wi fi
how about in device manager (right click on my computer, go to properties then hardware, then device manager) under network adapters, is there a wireless adapter?
Jun 28, 2008 | Computers & Internet
Lg wi fi fd series
you download the driver and installed but, are you sure that your wifi is turn on... make it sure that wifi is on..
Jun 27, 2008 | LG X-Note LM50 Notebook
Problems with wifi lan configurantion.
hmmm... is the wireless card listed in the device manager at all? even as a yellow question mark?
do you have a USB wifi adapter you can test on this computer?
Mar 29, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
