Question about Intel Motherboard
Wont boot the fan and hard drive seems to have started nothing comes on the screen i have tried with 3 screens and 3 vga cables. there are no beeps which would suggest that it is not even reaching bios stage unsure where to start
Check all connections. If you connect your pc to the mains supply and the fans run straight awayeven before turning on the computer switch ( and no beeps, no video). Well this could indicate a dead CPU. I have experienced this on 2 systems. I replaced the CPU and the motherboard and ram were OK .The CPU was totally dead and ended up in the bin!
Posted on Jun 27, 2008
    Problem Solver:
  • 7 Answers
Make sure you are connected to the right vga output if you have a graphics card installed
    President:
  • 357 Answers
Hi there
You should first check if your fan at the back is running, if it is then the problem could be your motherboard, i also have the same problem with one of my computers but as soon as i put a new motherboard in, it worked fine. If the fan at the back isn't running, you could have already burnt out your HDD or your motherboard. I will suggest that you try a new motherboard and if that is not the problem, try a new HDD.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Blank screen
Did it boot all the way? Do you hear the fan running, disk drive spinning? If it sounds like it booted but the display is black, try this:
When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 14, 2012 | Computers & Internet
No display after reboot windows
If it seems like your system is running whereas you hear fans running, hear the hard drive running, see lights, heard the hard drive click during bootup, but there is nothing on the lcd screen then try the following:
1) Try hooking a external monitor to your laptop. It can be any type of monitor even one of the old style fat crt monitors as long as it has a vga cable to connect to the laptop. There is a sequence of keys you might have to hit to get the display to show on the external. Most times you hit the FN (Function key) and hold it while you hit the corresponding F1 thru F12 key that is for display. Usually the correct key will say CRT/LCD or it might have a display icon on it. If the image displays on the external monitor that means the video card is good.
2). Remove the external monitor and reboot the computer again. Now when it is done booting take a flashlight an shine it on the lcd screen. You are looking to see if you can faintly see the icons on the screen. If they are there but barely visible then the LCD Inverter is bad. The LCD Inverter is located at the bottom of the lcd screen just above the keyboard and the Strip around the lcd screen covers it. You'll have to take the lcd apart to get to it.
3) If you don't see anything when you shine a flashlight on the desktop, then the lcd screen has to be replaced. However, sometimes the cable on the back of the lcd screen has come aloose or just needs reseating, so unplug the cable and put it back then see if it shows an image.
Read Below if it is not booting at all when you press the power button.
Laptops don't boot for the following reasons: 1) Bad Power Cord. 2) Bad DC Power Jack where the power cord plugs into the laptop. 3) Static Charge Buildup. 4) Bad Motherboard.
The above 4 reasons are when you press the power button and absolutely nothing happens. You hear no fans running, no disk drive running, no one time clicking sound on the CD Drive and No light for a second or two when the CD drives click. In the case of a motherboard issue sometimes you will hear beep sounds or see blinking lights. Those beep sounds and blinking lights tells the technician what is going on with your motherboard and why it will not boot. If you see the blinking lights or hear beeps count them.
So you have a power light which means your power cord and dc power jack is good. So lets see if you have a static charge buildup.
Remove the Power Cord and the Battery from the laptop, then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back into the laptop, but leave the battery out. Press the power button to see if it boots. If it does you had a Static Charge Buildup and it's ok to put your battery back in. If it does not you more than likely have an issue with your motherboard.
Mar 23, 2012 | Computers & Internet
How to solve problem after reboot my notebook dell no displaY
Mar 23, 2012 | ASUS Eee Computers & Internet
Want boot up. Whern you push the power on button, one light on the CPU comes on and all fans come on. There is one beep when you push the button. The CD drive has power. The moniter does not come up. I...
it means machine working fine but display problem check it your RAM check with a soft cloth may monitor is also avilable or check behind the VGA cable proper connect it or not
Sep 23, 2011 | ASUS P4P800-VM Motherboard
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
Toshiba laptop a215-s5824 screen wont come on every thing else seems ok fan go's on hard drive clicking away but nothing on screen!
Connect an external VGA monitor to the VGA output - if you get video, your display have either a bad inverter or the backlight is out.
Oct 28, 2010 | Computers & Internet
Acer Aspire 5315 won't boot, black screen
I had the same symptoms on friends laptop. She had nothing to lose so gave me carte blanc.
Took out battery (to eliminate as problem) plugged in power, and powered up
Power light OK, HD flashed, CD flashed, then black screen. Powered down.
Did the following:
1) took cover off of fan/circuit board (see http://www.insidemylaptop.com/ for details). (4 screws)
2) take out fan (3 screws) and find huge amount of gunk on cooling fins at fan disch. Blew out with compressed air. Also cleaned fan blades.(reboot shows didn't fix.)
3) Repeated step 2, Pulled out memory sticks and cleaned terminals by rubbing with lint free cloth. Replaced memory sticks.
4) System boots normally. Replaced battery. Boots normally.
DAMN I'M GOOD!
Jan 05, 2009 | Dell Latitude D600 Notebook
Screen wont come on
If you don't hear any beeps and your laptop is connected to the charger then most likely the motherboard or vga chipset has failed.
Mar 23, 2008 | HP Compaq nc6000 Notebook
Compaq presario 5000 startup problem
Firstly the keyboard does blink, but do you hear 2 beeps one then another a few seconds later, if not memory or graphics fault. Are you able to start in safe mode(press F8 when pc is booting up)when menu comes up highlight 'Start windows with last known good configuration' then press enter and it should re boot. The graphics card(if it's not onboard)may need to be removed and re seated, also the memory. Also check hard disk drive ide and power cable.
Jan 15, 2007 | Compaq Presario 5000 PC Desktop
Intel Motherboard Logo
63 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
