Question about GE Profile JTP56 Electric Double Oven
Problem Code F2
I have a GE in wall oven with problem code F2 I put in a new control panel and still am getting F2
  • 1 more comment
  • greengrl92 Oct 20, 2008
    I have the same problem...we turn on the self-cleaning thingy and then all we hear for the nxt 3 hrs is this REALLY annoying beeping that goes on and off about every 3 seconds...we think that 3 hrs is about the time that the oven cools down and thats why it eventually stops beeping, but we're not sure...we just keep hitting the "clear/off" v\button, but you can imagine how trying that gets...HELP!!!!
  • Kenneth19948 Jan 24, 2009
    after 2 hours of self cleaning the f2 light comes on and it beeps. Constantly hit the clear pad. Do I need to throw the circuit breaker and wait for it to cool down?
  • madhug Feb 03, 2009
    I had f2 problem for long time and kept beeping all the time, now the oven doesn't work at all
  • 3,230 Answers
The F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
How to remove and replace the temperature sensor. In most GE ovens, when you open the door, you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left. It's about six inches long and a bit more than 1/8" in diameter, held in place with two screws.
Turn off the circuit breaker (built-in ovens) or unplug the range before attempting the replacement.
The replacement sensor will come with instructions, but basically it's a matter of removing the sensor, pulling out the wires to where they are connected and disconnecting them. You may have to snip. The replacement sensor will come with high-temp wire nuts to hold the new connection. Polarity doesn't matter; it's a straight resistance thermocouple. Hook it up, be sure you poke the connections back far enough so that they're on the other side of the thermal insulation and not resting against the back of the oven.
If you continue getting the F2 error after replacing the sensor, then the problem is likely in the control module - this is the circuit board behind the keypad and clock.
You'll need to remove the decorative bezel to get behind the control panel. Remove screws and set off parts in order - it's not complicated. Once the bezel is off there are two more screws that hold the panel in place. Then you can lift the panel up about a half inch and pivot it forward toward you. You'll see a bunch of wires going to a circuit board.
On the panel you will notice some black plastic boxes that say "Potter & Brumfield" on them. These are relays. Check the relays - slide the black plastic cover straight up to expose the coil and the contacts. The coil, when energized, closes the contacts - look at all the relays. You can manually close the contacts with your finger (be gentle). If the contacts of one of them are stuck, they might be welded together. You can fix the problem by prying apart the welded contacts gently with a knife blade. Take some time to gently polish the relay contacts with a folded bit of fine grain sandpaper - this will get some more life out of them. Be gentle and careful - the relays aren't complicated but if you bend the contact or rip it out, you'll have to replace the controller, which will set you back a couple hundred dollars. If you unstick and burnish the relays, they will probably eventually weld together again as the rough spot will spark, but when you burnish them with sandpaper they should be good for some more life before they need to be replaced.
If the problem isn't the temp sensor or welded relay contacts then the problem is obviously somewhere else, but temp sensor and relay contacts will account for the lion's share of F2 errors.
Once again, be safe, be careful, be gentle. Ovens are not very complicated and they're tough, but always exercise care. Always disconnect electricity before messing with them.
good luck....
Posted on Jun 28, 2009
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
May 26, 2010 | Ovens
My oven gets a F2 code
F2 means usually, that the board detected that it's too hot.
You either need a new control board or a temp. sensor.
ge oven repair orange county, ca
Feb 06, 2010 | GE JTP45 Electric Double Oven
F2 Failure Code after cleaning cycle on GE Double
f-2 is usually a runaway oven temp which most of the time means a bad oven sensor.try replacing this first.
Jan 16, 2010 | GE Ovens
Whirlpool RBD245PDS15 Electrical wall double oven beeped .-... and showed F2 E6 code. Now it is dead other than interior light. No power surge, was not in use at the time. What is the code and how do I...
You to acces the electronic control and
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Jan 06, 2010 | Whirlpool RBS245PDS Electric Single Oven
Ge profile wall oven - f7 but I fix with eraser trick - now the clock can't be reset and the 4 does not always work on the keypad
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Aug 28, 2009 | GE Profile Advantium 30" Built-In Single...
GE ModelJTP14 oven, after 30 minutes at 350, the oven flashed a F2 code. Cooled and restarted the oven at 350, after 26 minutes it flashed F3. I have been remodeling and have taken the oven out of the...
check the codes for your particular model..they are included witht he wiring diagram that came with your oven. F2 likely means your control board (ERC) has an issue. I can't vouch for accuracy but here's another location with fault code listings Range / Stove / Oven Fault Codes
You can try turning the circuit breaker off that feeds power to your oven ( in your house electrical panel) that might work. If it does not, unfortunately it might be indicating a need to replace the control board... good luck!
Jul 13, 2009 | GE JTP15 Electric Single Oven
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
When cooking will get an occasional f2 or f5 error code
HI, This seems to be another ERC issue. the temperature sensory circuit is malfunctioning. the oven will not operate while this condition exist within the ERC. This malfunction will allow your oven to over heat and may cause a fire. The second issue will be that the relay drive circuit is malfunctioning as well. If you cant cancel the error code and continue with normal usage, you will have to replace the ERC once more.
Please rate and god bless:)
Apr 05, 2009 | GE 24" Built-In Single Gas Wall Oven
F2 error code
Intermittents are a real problem. My first guess: look around for a corroded or damaged electrical feed. Could be electrical noise from that. Not sure what No other possiblities other than a bad panel. I don't know what F2 is.
Dec 06, 2007 | GE JGRS14 Gas Single Oven
GE Profile JTP56 Electric Double Oven Logo
358 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
