Question about Apple iPod nano
IPOD NANO 1st Gen. 2GB HANGED
I had connected my iPOD NANO 2GB to the system as it was on HOLD and unable to recognised by the system and after removing from HOLD its not working and not comming out from Hold mode and light is continuously ON.
Not able to use it..Plz Help me out...
[email protected]
  • Anonymous Jul 02, 2008
    4 Gb my ipod is hanged.there are solve this problem?
  • 33 Answers
THIS WILL SOLVE YOUR PROBLEM!
1.Turn on HOLD then switch it off
2. Press and hold the "Play/Pause" Button and the Center button at the same time until it resets the iPod.
This should reset your iPod and fix your hung (frozen) iPod!!!
Posted on Jul 30, 2008
SOURCE:
My nano apple ipod is hanged
Reset iPod nano (if it isn’t responding) Slide the Hold switch to HOLD and back again. Press the Menu and Center buttons at the same time for about 6 seconds, until the Apple logo appears.
Mar 07, 2010 | Apple iPod nano
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
I charged my 4gb nano 3rd gen ipod, but it won,t
slide the hold switch on and off a couple of times...then press and hold menu and center buttons till an apple logo comes on screen...connect to system and restore with itunes.
Sep 10, 2009 | Apple iPod nano
New Ipod Nano 4th Gen 16GB has went blank and will not turn on
HI there,
worst case scenario is that a circuit has broken inside. But your ipod will be under warrenty for a year from purchase.
Otherwise, leave the ipod to charge for a long time. Just leave it connected directly to the computer USB port despite not having any change in appearance. Also, don't connect it via a usb hub or through your keyboard. You will need to plug it into your computer directly.
You can also try entering DFU mode. Here is a great step by step guide to do that. http://iphonefreakz.com/beginners-guide/howto-dfu-mode/
Then restore the ipod and update the firmware. Make sure you have the latest version of itunes installed. By checking through software update.
I hope this helps,
Nathan.
Apr 14, 2009 | Apple iPod nano 4th Generation
My Computer and iTunes does not recognize my iPod
Have you tried resetting it? Press the center (Select) button and the Menu button at the same time and hold for at least 10 seconds or until you see it reset.
hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Apple iPod nano
does other computers recognise your ipod - menial remedy but try resetting it hold down menu and play buttons till u see apple icon then connect........basic but maybe
Apr 19, 2008 | Apple iPod MA446LL/A MP3 Player
8gig 2nd gen ipod nano
Comon problem in the 1st and 2nd Gen Nano's, the only way to fix it is to buy a new hold switch and replace it (its actually quite and easy repair (just a small screw and a ribbon cable) if your feeling brave you can buy the hold switch here
(I just found it online, I don't represent the seller in any way)
http://www.welovemacs.com/8210458a.html
you can find a ton of you tube videos on how to take the nano apart without breaking it...its really not so bad
hope this helps!!
Feb 22, 2008 | Apple iPod nano 2nd Generation MP3 Player
Ipod 2gb hanged
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)ipodg1-2.gif ipodg3.gif
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Dec 19, 2007 | Apple iPod MA446LL/A MP3 Player
IPod Nano gen. 1 2gb.
hay im just posting this to get it out of the unsolved list lol
Oct 04, 2007 | Apple iPod nano
Apple iPod nano Logo
79 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Jeffrey Groves
Jeffrey Groves
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
