Breville BES400 Espresso Machine
Problem for Breville BES400 Espresso Machine
Can you help us.
By dssaw on Jun 27, 2008
Our machine is only 1 year and 5 days old. It sounds as though the pump has broken down, there dosn't seem to be any pressure, there is no water coming through at all.
Same Problem
Apr 27, 2009
-   how did you fix it? I also have no water coming through but the steam works. -   hbdryburgh
Dec 29, 2008
-   I have the same problem, no water. -   Guest
Oct 22, 2008
-   I have steam, but no water comes through the filter. It's not packed too tightly and I have the machine primed. Any ideas?-   Guest
Jul 26, 2008
-   I just bought a new machine. There's no water come from the filter. The steam seems to work though.-   ana_leung
Solution #1
posted on Jun 29, 2008
Somewhat Helpful)
dssaw
Rank: Apprentice
Rating: 75%, 1 votes
IT TURNED OUT TO BE AN AIR BLOCKAGE BETWEEN THE TANK AND THE PUMP
I THINK!
Was this helpful?
Yes
No
Solution #2
posted on Oct 17, 2009
Not Rated)
Patat0four
Rank: Guide
Rating: 100%, 2 votes
Be carefull, defective or cheap grinder can produce lots of dust in your coffee, hence blocking the tiny space in the extraction cartridge after a while. If water goes out without the handle in place, it's not a pump problem. It happened to me, I had to clean the extraction catridge thouroughly. I couldn't acheive anything with the needles, the extent of the mess was too great, it was like ciment in there. I had to go to an extreme mesure, only do that if everything else fail.
Remove the extraction catridge from the handle and put it in your oven, yes the OVEN. Do a auto-cleanup cycle with your oven (yeah, you need your oven to do this, if not, ask a friend who have one !) this will reduce any coffee dust into hashes, it may discolor the cartridge a little bit, but this is only cosmetic. Run a cycle without coffee to get rid of the hashes and voilà !
Good Luck
JF
nermal_@hotmail.com
Was this helpful?
Yes
No
Popular Solutions for Breville BES400 Espresso
Questions and Unsolved Problems for Breville BES400 Espresso
Do you recommend Breville BES400 Espresso Machine?
Answer
Answer
I just purchased Breville BES400 Espresso and it doesn't have any intructions. I purchased the last... (More)
Answer
Whenever the machine is plugged in it starts to pump water into the catch pan. If it is switched to... (More)
Answer
My Breville machine pumps water out of the reservoir and into the catch pan, or to whatever position... (More)
Answer
Breville espresso maker. The water will not come out even when filter is removed. We want to open it... (More)
Answer
I bought a Breville Espresso Machine model CM2,need assistance how to operate it Gary
Describe your Coffee and Espresso... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
in , CA
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
