Question about Canon Rebel XT / EOS 350D Digital Camera
After taking one photo, camera display blinks and can't turn off or take more pics
I turn on my camera, take a photo. No problem. But then the red battery light flashes and the top display blinks and flashes and I can't take any more photos, or access anything else. Even when I turn off the camera, the red light down the bottom is still flashing.
    Problem Solver:
  • 8 Answers
TIggertigger, allthough batteries have improved alot they still eventualy die, by the sounds of this proublem the battery has died for what ever reasen, try getting a new battery. If this does not help try a filmwere upgrade, for insturctions on how to do this please contact canon.
Posted on Jul 06, 2008
What does the blinking red light mean on a Nikon Coolpix Camera mean?
That is not enough information. In general when you take a TIMER photo... Say you select I want to take a photo after 10 seconds. When you press the shutter and LED may blink during the 10 seconds. The rate of blinking changes right before it takes a photo..
Aug 02, 2014 | Nikon COOLPIX Cameras
When i hit "print" the
Does the red light blink or stay on sterady?
Issue: The Compact Photo printer power button is blinking red.
Solution: Turn the Compact Photo printer off, then back on again.
"Paper Jam" appears on the digital camera LCD Turn the printer off and disconnect the power cord from the printer. Then reconnect the power cord and power on the printer. If the printer fails to eject the paper, the printer may require service. Contact the Canon Customer Support help desk for assistance.
When you power down I would recommend also unplugging the printer from the power supply (wall outlet). Let it rest 5 - 10 minutes and then plug back in.
The manual says a blinking red power light indicates a problem in the printer, but the only solution provided it to turn off and on.
If there are no paper jams, and no other error messages hoepfully a completr power down will clear the error.
Issue: Printer's power button lights red without the camera's LCD monitor displaying any error message.
There is a malfunction in the printer.
Remove the paper from the paper-handling slot and take up any slack in the ink sheet. Turn the printe's power off and turn it on again.
If none of this helps I would check to see if my driver is current:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/selphy_cp510#DriversAndSoftware
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Canon Selphy CP510 Thermal Photo Printer
Pentax Optio S10 cannot take photos in flash mode
HI there check the battery first. Red light blinking in working mode when the battery not having enough power for flashing. So i suggest you charged the battery fully or if its old then replaced it. Thnaks.
Apr 04, 2010 | Pentax Optio S10 Digital Camera
Brand new canon slr camera. can't see a live pic on led
Canon 350D can only take picture it does not take video. On screen of course you can play the photos you have taken. But that is all.
Feb 28, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I try to turn on camera and first I get green light then red blin
i try to turn the camera...but it seems that hangup,,,,the lights green it blinks blinks,,,,and theres a circle on scren.....i have lotsof pic there that is very important for school...was it gone?waht can i do so that my pic wont lost?pls help..
Apr 10, 2009 | Cameras
How do you activate red eye reduction in the 5900?
To take photos with red eye reduction requires your flash to firerapidly before snapping the pic. Make sure camera is in record mode pres the 4 way switch with the lightning sign on it. The flash modes will pop up. select red eye flash.
To fix red-eye after a photo is taken. Bring up the photo in playback mode and press menu button. Red eye reduction should be available as one of the menu items. Otherwise, display the pic, press OK button in center and if you like the fixed picture then select yes to store it.
Jan 12, 2009 | Nikon Coolpix 5900 Digital Camera
Unable to view pics
Copy the existing photos on to your PC, switch off the camera. Remove the SD card and format the SD-card using a SD-card reader, this will clear all the card contents. Now try using it in your Camera again. Ideally, you should be able to save photos on this SD card. Other way would be to insert another SD card into your camera and click photos and check whether those photos are being saved into the SD card(this can be done using display option in your digicam.)
Dec 17, 2008 | HP Photosmart E327 Digital Camera
Charger blinks red and does not charge
This maybe a solution. I had the same issue just now. Pulled battery, put back in, placed on dock, and still blinking red. So I removed the camera from the dock, pulled battery, put same old battery back in, placed on the dock and turned the mode switch on right away before it started blinkin red. It seems to be charging now with one bar and has not gone blinking red for 15 minutes.
I was outside with the camera in 10 degree weather taking pics of my dogs but had been inside for 20 minutes before placing it on the doc. I think something may have happened with the charging circuit and turning it on right away with it on the doc may have reset the charging. Try it. Hope it works for you.
Oct 23, 2008 | Kodak EasyShare DX6490 Digital Camera
Red verticle lines
the redish hue usually mean that the camera doesn't have enough light to take a good quality pic. If daytime pictures taken outside still look the same take it back or get a new camera.
Aug 06, 2008 | Kodak Easyshare M753 Digital Camera
Optio 33LF LCD problem
This often indicates a card error. Transfer all your images then format the card in the camera. If you still have the problem, try a different card. If you still have the problem then looks like you will have to send it in for repair.
Sep 08, 2005 | Pentax Optio 33LF Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
150 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
