Question about Continental Fish File Refrigerator - 1 Row
Heater/ Air Conditioner Blower Motor
The cabin blower quit working in my !995 Lincoln Continental. I was told by the dealer that it sounded like it might be the resistor. I obtained one, and installed it, but it didn't fix the problem. If I run a hot wire direct to the motor, it comes on and works fine. What other parts could it be?
The car has the climate control panel on the dash that supposedly sets the cabin temperature at exactly the temperature you have set it to.
Any help in this would be appreciated.
Thanks
  • 4,369 Answers
You should relist under lincoln continental, not refrigerators. If you have electronic temp control, you should not have a resister. You should have a bower motor speed controller.
here's info for 1996 system. I don't have 1995, sorry.
A/C Blower Motor Speed Control
The A/C blower motor speed control (19E624) is located under the A/C evaporator housing, to the left of the blower motor (18527).
  • The function of the A/C blower motor speed control is to convert low power signals from the EATC control assembly to a high current, variable ground feed for the blower motor.
  • A/C blower motor speed is infinitely variable and is controlled by the electronic control assembly software and A/C electronic door actuator motor position.
  • A delay function provides a gradual increase or decrease in blower motor speed under all conditions.
Heater/ Air Conditioner Blower Motor - aa1dc43.gif
Blower Speed Override Thumbwheel
Rotate the blower speed override thumbwheel more than 10 degrees to turn OFF the AUTOMATIC blower indicator and provide manual control of the A/C blower motor speed.
  • The display will show FAN and a fan symbol.
  • Rotating the wheel fully down against its lower stop locks the blower motor (18527) at its lowest speed.
  • Rotating the wheel fully up against the stop, locks the blower motor at its highest speed.
Press the AUTOMATIC button to resume automatic A/C blower motor control and remove the FAN and fan symbol from the display window.
Posted on May 22, 2009
  • gerry bissi May 22, 2009
    check fuse #1 40 Amp in power distribution box (under Hood I believe). Confirm in owner manual.
    Check fuse # 9, 40 amp.
    Check blower motor relay, in power distribution box under hood.
My heater blower only works on top two numbers but don't work on 1 & 2 do you know what the problem is ?
The most common cause of a heater and air conditioner blower not working on a car is a faulty blower motor. Without the blower motor, the system is unable to push air through the vents inside the vehicle.
Kamagra Kaufen http://kamagra-billig.com/
Oct 03, 2016 | Cars & Trucks
Need to get my wifes car heater blower working again.
CHECK THE BLOWER MOTOR RESISTOR ON THE EVAP BOX. MOST LIKELY IT IS BAD. AFTER YOU REPLACE IT THROW AWAY THE 2 SPEED SWITCH AND RESTORE WIRING BACK THE WAY IT SHOULD BE.
Dec 15, 2014 | 1997 Lincoln Continental
Navigator motor blower low hum
If it sounds like an electric motor hum, it could be the blower motor.
You might check the cabin air filter to make sure it is not blocked.
Sep 14, 2012 | 2010 Lincoln Navigator
I have a 2004 Honda Accord and the heater and air conditioner blower motor does not work. Have checked the fuses and they are all fine and have checked the cabin filter and it is alright. What else can I...
CHECK BLOWER MOTOR RELAY. HOT WIRE BLOWER MOTOR.IF BLOWER MOTOR WORKS, PROBLEM IN THE BLOWER CONTROL SWITCH OR FAULTY RELAY.IF BLOWER MOTOR DONT WORK WHEN HOT WIRED.BLOWER MOTOR FAULTY.
May 30, 2011 | 2004 Honda Accord
The a/c unit works but the blower fan won't come on to blow out the cold air. What is wrong? How can I fix it?
CHECK BLOWER MOTOR FUSE OR RELAY.IF BOTH IS GOOD BLOWER MOTOR FAULTY.HOTWIRE BLOWER MOTOR TO SEE IF IT RUNS IF NO REPLACE IF RUN YES CONTROL SWITCH COULD BE BAD OR BLOWER MOTOR GETTING POOR GROUND.
Aug 03, 2010 | 2000 Lincoln Continental
The front heater/air conditioner blower stopped
First check the voltage at the front blower moter. If it has voltage then it may just need a new motor.
May 17, 2010 | 2001 Dodge Grand Caravan
I have a 2003 Pontiac Grand Am. The heat doesn't work. The blower does not blow any air. What's wrong? Blower motor? heater core? what might it be?
Sounds like the blower motor may have died. There should be some sound coming from motor even if there is no heat. So most likely the motor has died.
Dec 15, 2009 | 2001 Lincoln Town Car
Kia Rio - Heater not working fan works but noise coming from fan.
open glove box and make sure that none of the papers from that can get down to blower motor
Jan 17, 2009 | 1998 GMC Sierra
2000 Town Car AC Blower working off and on
You are going to have to replace the Auto climate control assembly in the dash.
Jul 08, 2008 | 2000 Lincoln Continental
Refrigerators Logo
334 people viewed this question
Top Continental Refrigerators Experts
John Tripp
John Tripp
Tom Chichester
Are you a Continental Refrigerator Expert? Answer questions, earn points and help others
