I am experiencing the above problem recently. Can you assist me in thru the same. I have googled a lot but could not find a solution to overcome the situation.
OS - WINDOWS 2003 STANDARD EXIDITON
CPU HP PROLIANAT ML150
HD MAXTOR 6L080 MO SCSI
Some common reasons for a delayed-write failure are:
1. Problems with a device driver, especially a SCSI or RAID device driver.
Some RAID device drivers are known to issue spurious "Delayed Write
Failed". Most manufacturers have been
alerted to this, so check to make sure the disk drivers are up-to-date.
2. Cabling problems. A faulty or broken cable
-- especially for an external USB or Firewire enclosure—can generate
this error. It can also happen if the cable is too long, or if it is
hooked up through a hub that isn't up to spec. Another possible culprit
is if you have a UDMA drive that requires an 80-pin cable, and you are
using a 40-pin cable.
3. SCSI termination errors. This has become less likely with the advent of self-terminating SCSI hardware, but it shouldn't be counted out.
4. Media errors. This is the worst possible
scenario -- essentially, drive failure. If you can garner statistics on
the drive via SMART (such as SMART & Simple (http://www.beyondlogic.org/solutions/smart/smart.html), you may be able to determine if there's a mechanical failure in the offing. Gibson Research's SpinRite tool (http://grc.com/) is also useful for assessing media errors, but be warned: It may take a long time to do a thorough test.
5. BIOS settings on the computer are forcing faster UDMA modes than the drive controller can handle.
This is unlikely, especially with newer hardware (which can support
UDMA far more flexibly), but it can usually be fixed with a BIOS
upgrade, or by resetting the BIOS entries for the hard drives to
auto-detect settings. Devices set to UDMA Mode 6 that produce this
error, for instance, might need to be set to Mode 5.
6. Controller issues. I've observed that USB
controllers that contend strongly with other hardware can produce this
error. In systems that have both "long" and "short" PCI slots (i.e.,
64-bit and 32-bit), try moving the USB controller to the long slot.
Older PCI cards will not fit in such a slot.
7. Memory parity issues. If the problem
appears after installing new memory, the memory in question may be
faulty or not of the correct type for the motherboard in question.
(This may go hand-in-hand with other problems such as random lockups,
too.)
8. The LargeSystemCache Registry tweak and ATI video adapters.
One peculiar set of circumstances that has been observed on multiple
machines with ATI video adapters and more than 512MB of memory involves
the LargeSystemCache Registry setting, a DWORD entry found in HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession
ManagerMemory Management.
This setting governs the amount of memory set aside by the system for
certain kernel processes. If it's set to 1 (which allegedly improves
performance on systems with more than 512MB of memory), it can cause
data corruption on some systems, and produce the "Delayed Write Failed"
error. Try resetting it to 0 if it's been set.
My ML110 G4 powers down automatically. We have checked all the usual culprits for power management...
(More)
My ML110 G4 powers down automatically. We have checked all the usual culprits for power management to no avail. Someone has suggested that it is because it is not set up as a domain controller, which I dont understand as we are not hosting on this server. The server is simply used, or will be when I sort this out, to network 4 workstations and allow file sharing. At the moment the server is not part of the network and is shutting down from the desktop with no app running.
Upgraded from window 2000 to windows 2003, according to hp documentation. Now continuous loop reboot...
(More)
Upgraded from window 2000 to windows 2003, according to hp documentation. Now continuous loop reboot on windows 2003.
