Question about NAD C542 CD Player
NAD C542 CD PLAYER
DRAWER MECH REPLACEMENT
  • dtaylor91 May 11, 2010
    Do you have the drawer mechanism to replace the current one with? Will you be replacing just the drawer mechanism, or the laser and laser mechanism as well?
    Also, if your trouble is simply the door not opening and closing, it may just need a new drive belt for the mechanism.
    Problem Solver:
  • 5 Answers
Maybe it is just the belt for the tray motor.
Posted on Dec 01, 2009
Player will not play a loaded CD and No CD message comes up Also CD drawer opens and shuts on it`s own !!!
the tray opening by itself could be a faulty limit switch on the tray mechanism
the switch tells the system if the tray has reached the open or closed position.
if it closes then opens itself then this is the most likely
check that first
could be closing then opening without actually loading due to the switch
you will need to open it up to find the switches
usually at the bottom front were the tray goes in
darren
May 28, 2011 | NAD C542 CD Player
I get a no disc message even though there is a disc in the machine.
Hello
there are two option of such fault
1. lens is dusty, clean the lens using moist cloth/cotton 2. lens got bad need replacement
third option is CD is faulty/scratch
hope it helps. do rate if so
Dec 12, 2010 | NAD C542 CD Player
Vfl display not working
no display could be a problem with the inverter circuit that drives the display
usually a transistor goes bad around the display area
check the board for dry solder joints as well
sme CD players have an option to switch off the display, check its not turned off
usually a button on the unit or the remote
darren
Nov 26, 2010 | NAD C542 CD Player
My NAD cd player CD slot goes in and then opens...it does not retain the CD inside to play...
Hello
This fault is due to loose tray loading belt or weak loading motor. You just change the loading belt with same type. Never use a belt more than tight. Use the same size. If belt changing does not help, replace the loading motor. OK.
Nov 21, 2010 | NAD C542 CD Player
Pressing the 'open' button on my NAD C542 CD Player no longer opens the disk drawer. Any suggestions to fix this would be appreciated. Regards Michael
G'Day Michael,
Having fixed thousands of CD players in my career, and also being a NAD Authorised service guy from 1989 till recent times, I can comment with some authority to your situation, and correct some of the ill found assumptions given to you already.
This unit uses a KSS213c transport. Very common and used in many machines, also relatively reliable.
The drawer load motor is not shown above. Is will be mounted on the black plastic load assembly. The drive belt/motor for it will be under the tray runners.
If you do not hear the motor run, then it WILL NOT be a broken or failing belt. However, this is the most common problem with this style of transport. I would be checking anyway to see, the load motors do free run fairly quiet with no drive belt connected. Wind the tray assembly out by hand by kicking the gears over to open the draw to see the belt/motor
Because you cannot get it to work from the remote, AND you have "open" indicator on the front panel, it WILL NOT be a faulty front panel button(never seen one fail ever!)
I have never replaced a load motor to a Sony transport. Spindle motors can be a problem, but they never stop working altogether.
I would be checking the tray mechanics, a jam caused by something fouling the gears may cause a fail. Tap the front of the draw as you press eject to see if you can encourage it to work.
Sometimes, small nylon drive pinions can split, the excessive gap in the gears caused by the split causing a bind. Check also for blown pico fuses in the servo drive stage. This will cause no drive to the load motor.
If you cannot pin down the source of the problem, the player IS welll worth repair. These machines sound great and would have cost you a few bucks to begin with. If you need help locating an expert NAD authorised repair guy I can help.
Happy to discuss any of this further with you. As previously direct your comment to me by name. Cheers
regards
robotek
Aug 03, 2010 | NAD C542 CD Player
How do I clean the lens? CD lends cleaner only provides temporary relief from fuzzy sound.
hi,
remove the cover, remove the spindle cover of cd player inside, thier you can see a little glas object
clean it with coton sticks and liquid that you use to clean the windows.
move over the lens gently once wet and once dry
now you lens is clean
thats all
greetings
cis
Feb 16, 2010 | NAD C542 CD Player
Disk drawer will not open
A small motor turns a belt, which then drives the gear that operates the drawer. Over time this belt stretches or breaks, and the drawer doesn't open. Replacing the belt cures the problem.
I've looked at the couple of belt catalogs I have, and nothing for NAD is listed. You'll need to measure the old belt circumference and thickness. Almost all of these are square belts, usually in the range of 2.5 to 3.5 inches circumference. If you're measuring the old belt, take off 10 to 15% since it has stretched.
A local electronic service shop may have a suitable replacement. Otherwise there are many sources online (MCM Electronics is one I deal with frequently here in the US). In a pinch, you can even use a small rubber band until you find the right replacement.
Hope this has helped. Thanks for using Fixya!
Feb 12, 2010 | NAD C542 CD Player
NAD CD player C 542
SORRY but you need to get this to your dealer,don,t think anything is stuck in there just a faulty drawer mecanisim.
hope this helps.
CABLE GUY.
Aug 04, 2008 | NAD C542 CD Player
Nad plays for a minute or so...
First thing to do is to check all your new caps and their polarities.
Capital98
Dec 19, 2007 | NAD C542 CD Player
Nad C542 Troubleshooting
found same problem with mine, solution .. place clean paper over the optic, then a magnet, leave for a few seconds, the build up of static causes a magnetic field in the optic preventing it tracking, have cured a few other brands with this as well .. shows manufactures are putting inferior parts in to their players, hope this helps !!
Mar 20, 2007 | NAD C542 CD Player
NAD C542 CD Player Logo
269 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
