Question about Acer Computers & Internet
How do i use my second hard drive on my computer?
  • Oliver Nitch-Smith May 11, 2010
    Need more info on whether the drive is actually connected to your computer.
    If it is, can you see it when you go to 'My Computer'
    If you can, what happens when you click on it
    Also what Operating System ie, Windoes 2000/XP/Vista etc
    Problem Solver:
  • 4 Answers
Youre first hard drive is a primary master,,and the other one use the secondary master..remember same ide cable..and always check the jumper setting of youre two hard rives!?!?! because if not change the setting's youre pc is not boot or start window's
Posted on Jun 27, 2008
How to set a toshiba hard drive to slave?
Power off the Toshiba laptop. Remove the power cord and the battery.
Turn the laptop upside down and remove the panel where the hard drive goes with a screwdriver.
Depending on the model of Toshiba laptop being worked on, this may include the entire bottom panel, a panel covering both hard drive slots or a panel covering the empty second slave hard drive slot.
Install the second hard drive by inserting it into the open slot.
Replace the opened cover.
Replace the battery and power cord.
Turn on the computer.
The second hard drive is automatically configured as the slave drive.
Depending on the operating system and previous status of the slave hard drive, it may need to be partitioned or formatted before being used by the operating system.
hope this helps
Sep 13, 2012 | Toshiba Computers & Internet
Hard disk is not running frm last boot
- This means that your operating system may have collapsed and needs repair.
- To repair, enslave your hard drive to another machine by:
- Make sure the second computer has a good operating system.
- Remove the hard disk from your computer.
- Remove CD/DVD Rom from the second computer and fix your hard disk on
that drive.
- Start the computer.It will display that you're running on two drives.[Unix]
- Press F1 to save changes and continue.
- The machine notes one drive needs repair and starts the repair process.
- After it has completed and opened your system, turn it off and remove the
hard disk.
- Fix it on the first machine and start it.
- If this fails,you may need to format the hard disk.
Sep 11, 2011 | Maxtor (6L250S0-20PK) (6L250S020PK) 250 GB...
I have a WD800JD hard drive which was on my old computer in which I want to recover data to my new computer. I have installed it in the computer with the one ribbon (only one available). The master has...
Hello Joe,
Please visit the link provided below :,95/c/123/session/L3RpbWUvMTMxMzU4ODkxOS9zaWQvN1JOSzdNQms%3D
Aug 17, 2011 | Western Digital Caviar SE WD800JD SATA...
Bios setup does not show sata HD windos xp find them
I have had problems like this many times with some of my IBM machines. What i find most often the reason the bios will not recognize them is because the hard drive has gone bad.
Troubleshooting 1. Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from motherboard and hard drive. Unplug power cable from hard drive.
Plug the sata cable back into the motherboard and into the hard drive. Plug the power cable back into the hard drive. Plug the power cable back into the computer.
Boot computer and enter bios(by pressing F8, Enter, Del ect..) Does the hard drive show in there now?
2. If you have another hard drive.
Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from hard drive. Unplug power cable from hard drive.
Plug the sata cable into the second hard drive. Plug the power cable into the second hard drive. Plug the power cable back into the computer.
Boot up the computer and enter the bios. Does this hard drive show in the bios? If so then i would say that your original hard drive has gone bad.
Apr 20, 2011 | Abit AV8 Motherboard
Acer Aspire 5100 will not boot
Two possible Solutions:
1) The Hard Drive has come unseated - Disconnect the Power and REMOVE all connections, Close the Screen & Turn your Laptop Upside Down and Remove the Battery, Locate the Hard Drive Access Panel and Remove the Screws from the Panel, Remove the Panel, Remove the Hard Drive. Carefully Replace the Hard Drive, Replace the Panel and Reconnect the Battery & Power Supply. See if the Computer will Start
2) The Operating System is Damaged OR the Hard Drive is Dead - You will need to slave Your Hard Dive into a Second Computer and Backup ALL you Personal Data OR RISK loosing it. If the Second Computer can NOT read the Drive, the Hard Drive is Dead (A Computer Repair Company may be Able to Help)
Once your Data is Safe, you can try to Repair the OS by Booting your Computer with the Drive in it. Begin pressing F12 or F10 at bootup (Once a Second). You will be presented with an Options Page for:
System Restore (FIX WINDOWS)
System Recovery (Wipes your Computer and Retores the Factory Software)
Hope this Helps!
Dec 22, 2009 | Acer Aspire5100 Notebook
Disk management does not see working hard drive
Are the Hard drives setup as master & slave ? (plastic jumper on Hard drive at cable)..... is the Hard drives connected on separate ide cables... if they are ide drives ?
Mar 30, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
2nd Hard drive not recognized
If your using IDE hard drives i would try to put them both on the same cable on the primary IDE controller. Then set you main hard drives jumpers and the second hard drive to cable select not slave. Try to boot if the boot fails your goiong to need a Windows 98 boot floppy with FDISK. You need to start up the 98 boot disk with out CD support then when it reaches a command prompt start fdisk. ONce fdisk is up format and partition the second drive. Now it should work. :) Check that the harddrive is detected in the BIOS, it may have become disconnected, it should also be the master drive on the primary IDE. If the drive is not detected in BIOS there is little chance of it working
Thank you....
Jan 29, 2009 | IBM ThinkPad X31 2672 Notebook
Adding second hard internal hard drive
Sure it will, put the jumper setting on the hdd to cable select mode.
Sep 01, 2008 | Dell Dimension 2300 PC Desktop
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
