Question about HP LaserJet 3050 All-In-One Printer
Display Board problem
Printer has not been functioning due to display board problem
  • 2,785 Answers
Plz send it for servicing
Posted on Jun 27, 2008
316080102 dim
Oven control board is not working # 316080102. You would need to get it repaired as it is no longer available for purchase.
I would recommend a fast, easy and affordable vendor named Partsimple has high level of expertise in control board repairing. many vendors do purchase from them then sell as if their own product.
I have also attached a direct link for reference.
Frigidaire Kenmore Tappan Range Control Board Repair Service 316080102
Jan 27, 2014 | Ovens
Samsung rs261mdpn
Replacing the main control doesn't fix anything on the display they have separate functions. You need the bom number to find the display board it should end in /xaa or something like that
Nov 06, 2013 | Refrigerators
Error code 55.4k
This error 55.4k appeared in printer hp color laserjet 5550. The following trouble shooting did. Orignally my printer fault is display blank.Then i replace dc board with formatter board. blank is gone dueto new ram.Machine display showed the memory process. but immediatly the error 55.4k appeared on display.The reason for this error is, communication failure between formatter and dc board.The dc board which i was replaced by old type one.Then i found exact same dc board, replaced. Error was gone.Machine came to normal status , working fine.
Oct 01, 2013 | HP LaserJet 5550dtn Printer
Defects on displaying functions
This is due to fault on the display , problems with the main board processor , linking cord to the display unit. Also check for moisture to the board.
Feb 01, 2013 | Washing Machines
Nn2555 display weak
In many cases , cockroaches are found to habit within specially when not used and can spoil the main board, panel display and connectors. Remove the front panel and board and confirm and if so you need to wash the board and reset. Also it can be due to failure of the display or drive from the board
Jan 30, 2013 | Microwave Ovens
Hp psc 2410 printer nothing on display. display or driver board ? All other functions seem to work fine. How can I isolate the problem ??
Fist step: Check display connecting cable both ends, if found damage replace it..
Second step: Replace display..
Third step: Formatter..
Oct 29, 2011 | HP PSC 2410 All-In-One InkJet Printer
Hi, the receiver has no sound when it turned on and the display is off as well, although the functions as output, channel selector are working. Appreciate your input for the problem.
SONY STR db840
No display:
broken trace on "Digital board" ,feeding 32v from "DC board" to "Display board"
solution: make new jumper btw. "CNS2" and "CNP4" on "Digital board"
Now display OK again : )
Sep 26, 2010 | Sony STR-DB840 Receiver
F7 shows on display and display getting dimmer over months
Dim display is TOTALLY independent of F7 error.
The display will dim as the display board capacitors wear out - due to the heat. Replace the capacitors on the display board (see my other posts) and your be able to see the F7 error code as bright as can be!
Jul 16, 2009 | Thermador SC302T Electric Double Oven
Diamonds on the T522 LCD
do you get 5 beeps when the printer powers up? three things can cause this the control panel, the logic board and the engine board if you have replaced the logic board the engine board is the problem change that and your problem should go away
Dec 18, 2008 | Lexmark T522 Laser Printer
Need Repair for OL-3000
All programing functions are controlled on the main (stationary) board. All display functions are controlled on the Rotor (spinning board.) Here are some steps to take if you are having display problems. Remove the three mounting screws that hold the rotor to the motor shaft. The LED display board is attached perpendicular to the rotor board and is soldered to the rotor board. Over time, the connections break due to the centrifugal force of the spinning rotor. CAREFULLY, with a low amp solder iron and a fine tip, re-heat the board to the display. That should solve the problem. If you were a bit sloppy with the solder, remove the solder with a fine wick and try again!
Sep 16, 2008 | Wave Industries OLY-OL3000 Globe Phone
HP LaserJet 3050 All-In-One Printer Logo
24 people viewed this question
Ben Johnson
