A master switch may be at falt, but try you may want to check power gets to window motors, remove door panels and use your test lite activate switch and see if lites Ok then needs a window motor if no your master switch is bad..
Very rarely on this year you may also found broken wires between drivers door and vehicle, where harness pass from door to inside car, disconet harnes from inside left kick panel and pull it out towars door pull black rubber boot back remove electrical tape and check all wires if any open or split repair and rechek al over. good luck
Before you replace anything, inspect the connector pins in both the driver's door switch and the passenger door switch. If you don't find any problem with these connector pins, replace the driver's door control switch.
