Question about Cameras
Memry card error
My Cannon is less then a year old and it's now saying I have a memry card error the card was locked but I fixed that and I have tried 2 different cards still the same thing
please help before my sons summer is over
  • CameraR
    CameraR May 11, 2010
    What model of Canon camera do you have?
  • Cameras Master
  • 4,738 Answers
I asked the above because some model's of older Canon cameras (such as the S400) would be repaired for free by Canon with this error.
But just noticed that you said the camera was new. If it's less than a year old Canon will repair it for free under the camera's warranty. They're very quick about it too, and usually include free shipping. Call 1-800-OK-CANON.
Posted on Jun 27, 2008
My cannon reads card is locked, but the card is not locked. How do I get the camera to read the card correctly?
The card might be bad. Try a different/new memory card and see if you get the same message.
Jan 29, 2013 | Cannon Cameras
Cannon s2 digital camera used. i inserted a new memory card and have an error showing memory card error. card not locked!
trying removing it and unlocking it with the unlock button.. they some times lock them selves when you slide them in the slot.. go slow and straight.. this sometime fixes the problem... Good Luck.. T.
Jun 21, 2011 | Canon Cameras
I got a new 4gb memory card for my cannon ixy 800is camera but it says memory card error.the make of the card is apacer. Do you have any suggestions on how i can fix this. I have not tried to clean the...
A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 10, 2010 | Canon PowerShot SD700 IS Digital ELPH /...
My cannon a 530 says that it has a memmory card error, and it shows memmory card locked momentarally at bottom of screen, i tried to unlock with the slide on the card itself, but that did not help. i put a...
No that's not likely the problem. The new card is probably the issue, especially if it is 4GB or higher. There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 28, 2010 | Canon PowerShot A530 Digital Camera
We have a cannon a2000is. After replacing the batteries and printing the pictures off the memory card the camera will not come back on. The screen says Cannon and the indicator light blinks for aprox 20...
It sounds like a low power startup. Are you sure the batteries that you are installing are good? If they're Dollar Store "Super Heavy Duty" batteries, that's likely your problem (shelf life has been exceeded).
Recommend trying to start the camera with premium alkaline, or best yet, rechargeable batteries (they have the most power, and save you money too!). If the above doesn't work, recommend contacting Canon, especially if your camera is less than a year old. The camera in that case would be eligible for warranty repair.
Oct 15, 2010 | Cameras
I have 1gb m2 memry card for about a year it
this happens dude.
try to format it using a memory card reader on a computer, sometimes the card get corrupt
format it, it shld work fine, u can copy ur data also on the computer for a backup.
Nov 02, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
Canon camera won't accept SD memory card
It's a good bet that anything 4GB or greater is a SDHC card (look on the card, see if SDHC is written there). Your A530 was designed before the new SDHC format came out. Sorry, but your camera will not recognize this type of card. Recommend instead that you get a 2GB standard SD card. They're relatively inexpensive these days.
Jun 07, 2009 | Canon PowerShot A530 Digital Camera
Error when turned on, "Memory card error"
if it is an SD or SDC card the check the cord for a lock on the upper left side. This will prevent a lot of functions.
Jan 15, 2009 | Cameras
Card locked
Dear codger19:
If your camera gives you "card locked" error messages with several cards and you KNOW that the cards are indeed not locked via the sliding lock mechanism, then your camera needs to be sent in for service as it has developed and electrical communications problem within the memory card control function.
I would first however try a hard reset by resetting your camera to the default settings, removing the battery and memory card for two minutes, and then replacing them. Retest the cards for the error message. If it still occurs then call 1-800-828-8080 for your options.
Hope this helps.
Sincerely,
HeavyDLB
May 31, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Cameras Logo
57 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
