The power light keeps flashing orange - Computers & Internet
  • 1 more comment
  • rahulras1993 Oct 01, 2008
    I had the same problem when I tried to put extra ram into the pc. Well this is what I did firstly i replaced the battery inside you know for the clock etc. , secondly I removed the ram and switched the pc on worked fine then i switched it off and then put the other ram in and it worked fine. Also my case wasnt closed well its very loose so I just slammed it in the orange light stopped flashing and it worked try it :)
  • vanbuksy Feb 16, 2009
    I am having this issue with my presario. When I try to turn on my laptop I get the battery light flashing orange, when I try to turn it on, the power button also flashes orange too.
  • Anonymous Mar 13, 2009
    ******* pissing me off
    power button keeps flashing orange
I had my Optiplex GX520 at work shut down abruptly every time I turned it on it in the morning. This would always happen within the first 30 minutes. I would then get the flashing amber light. After starting the PC again, it would stay on all day (over 8 hours) without shutting down again. I found that the power supply was over-heating.
Two things need to be done. First, in order to get the amber light to stop flashing, un-plug the computer from the wall for 30 seconds then plug it back in. OR hold down the power button for 10 seconds or so. The light should stop flashing. Then press the power button again and the PC should start.
But why did it abruptly shut down in the first place? The power supply has a fan-speed-control circuit in it to keep it running slow and quiet when the power supply is cool. It gives the power supply lower voltage when the power supply is cold and higher voltage as the power supply gets warmer. This circuit either is not working correctly or the fan getting sticky over the years and needing more voltage to get it moving when it is cold. I found that the fan was not starting at all and causing the power supply to over-heat.
To keep the fan moving at full speed, I cut the wire to it and wired it to the +12v output directly. Not the fan goes at full speed all the time. And yes, it is nosier. But at work it doesn’t matter.
The best solution would be to just get another power supply from Dell if possible. Or buy a +12v, 70mm fan from Digi-Key and replace the original.
Posted on Jan 23, 2009
    Problem Solver:
  • 10 Answers
Do a power drain-take off the power cord from the back of pc and hold the supply button for 60 sec while pc is off...check..
Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating...check..
Posted on Jun 27, 2008
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Orange ink light keeps flashing
HP Desk Jet 940c orange light flashing
Oct 01, 2014 | HP DeskJet 940c InkJet Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Hp 845c orange light keeps flashing
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
Mar 09, 2009 | HP DeskJet 845c Printer
Orange light is flashing
Unplug the power cord for 10 seconds
Feb 05, 2009 | HP LaserJet 1020 Printer
Flashing orange light
Power edge system are having two power input check the cables from the power outlet may be one is in contact otherwise one of your power supply gone means not working. Check the wires first then the power supply units
Nov 26, 2007 | Dell PowerEdge 1800 Server
Computers & Internet Logo
4,817 people viewed this question
David Payne
David Payne
