Question about iRiver T20 MP3 Player
IRIVER PROBLEM SHOWS usb connect
My iriver t20 only shows usb connect whatever button i press there is no change on the screen.
  • 8,596 Answers
When it is plugged into pc, that is all you will see. If this is happening while disconnected from pc, then reset the player to get past this stage.
Posted on Jul 05, 2008
My iRiver does not connect to my PC but shows the unit is charging
Press Play to make it connected.
You can also turn USB Charging off via a long press of the NAVI button to get to the menu then it's under control
Jan 21, 2015 | iRiver H340 MP3 Player
How to fix iriver E10 it says on the screen is emergency usb
  1. If your PC does recognize the iRiver as a USB device/drive, there is an issue with the Hard Drive.
  2. If your computer doesn't recognize the iRiver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
  3. Turn the lock off and connect it to the usb port and press the reset button (small hole in lower left of unit, use a small object like a paperclip. The screen should change eventually to the "USB connected" screen. Disconnect the USB at the PC to get the "Ok to disconnect" message. Pull out the usb cable and hold down the "off" button. Eventually the unit will turn off. Turn it on and then off to verify it is working.
If nothing works, your iRiver needs to be returned to the manufacturer.
Feb 22, 2011 | iRiver E10 Digital Media Player
Iriver t20
I had the same problem. I reinstall windows media player 11 and now the system recognize my iriver T20!!! When reinstalling WMP 11 i had T20 in the USB Port!
Angel Greece
Nov 06, 2008 | iRiver T20 MP3 Player
Iriver H320
there is a setting somewhere that stops it charging when you connect it to a usb port on the computer.
May 08, 2008 | iRiver H320 MP3 Player
IRIVER PLUS 3 MEDIA TRANSFER SCREEN
My understanding, as a new user, is that IRiver plus 3 only communicates with the player via UMS mode, which is not the default. Windows Explorer and Windows Media Player only communicate through MTP mode. If you change from MTP (the default) to UMS, it will reformat the player and delete all your files.
In other words, do not use iriver plus 3 unless that is the only software that you want to use. Boing back to MTP mode after a sync or download will then delete all THOSE files you just downloaded.
I just say NO to Plus 3.
Good luck.
Dec 30, 2007 | iRiver Clix Digital Media Player
Conectivity
All the info/manuals/drivers/upgrades for the iRiver T20 can be found here:
http://www.iriver.com/product/p_detail.asp?pidx=71
Dec 21, 2007 | iRiver T20 MP3 Player
File check error in
my iriver t20 shows on display "file check error" and all my folder are disappeared.please help me to solve the problem. thanks for your assistant.
Dec 14, 2007 | iRiver T20 MP3 Player
Iriver t20 problem
have you tried hitting the reset button when it hangs? You need to use a pin to do so, there's a small hole on the end of the player.
Nov 30, 2007 | iRiver T20 MP3 Player
Iriver T20 not recognized
Try this: disconnect the player from the computer, turn it off Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Nov 16, 2007 | iRiver T20 MP3 Player
Iriver T20 USB went DEAD
Aug 15, 2007 | iRiver T20 MP3 Player
iRiver T20 MP3 Player Logo
206 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
