Help can you tell me what an ethanet adaptor is so i can go online
An Ethernet adapter is a network card adapter that allows you to connect another computer that also has an Ethernet adapter using a network cable to transfer files and allow remote access to the second computer. It is also used to plug in from a cable modem to allow you Internet access through you provider. You might already have one built in to your computer. Look for a small connector that resembles a telephone connector but it is a little bit bigger in size which is typically located on the back of the computer. Hope this helps.
Posted on Jun 28, 2008
Hello, my name is Susi & I live in the UK. At Christmas 17 years ago I bought a Maisto Santa's Carousel Park. But 12 years ago I lost the adaptor that came with it. I asked ppl & tried other adaptors but...
Maplins sell an adapter that has multi-voltage settings and a whole array of connectors, I'm sure they have what you require. Check online, they have a questions part too that is usually very helpful. Find an adapter on the site and you can ask a ? about it... and get an answer too ! .... Good luck... Red.
Dec 03, 2014 | Computers & Internet
Automatic updates/ network adaptor goes missing / magically returns after system restore
Where is the Network Adapter originating from? Windows? If the Update is a Windows update, Hide the update. It may be an error, it's happen to me on a HP Network Adapter, When I installed it the Ethernet Adapter would not work, I rolled-back the driver on the Ethernet Adapter and it worked perfectly. I "Hide" the Windows update in Windows Updates.
Feb 23, 2013 | Broadcom NetLink Gigabit Ethernet
Can not connect to internet via either wireless or Ethanet
just ping ip address if it give timeout thn check lancard or company
Feb 14, 2011 | Acer Aspire X3400 PC Desktop
I've misplaced my adaptor. Could you tell me me
your adapter can be purchased from any electronic stores such as futureshop and staples. or you can order them online
Jul 26, 2010 | Mintek MDP-1750 DVD Player
I can't get it to charge
This is typically caused by one of two issues:
  1. (Most likely) The battery has failed and needs to be replaced. If the battery is older than a year and seen heavy use or been plugged in to the charger for long periods of time, this is likely the problem. Verify that the power adaptor is not bad (below) and purchase a new battery from a local retailer or online.
  2. The power adaptor is bad. Plug in your power adaptor and verify that the power LED is lit. If it is not, then it is bad and will need to be replaced or alternately, you can purchase an inexpensive external battery charger. They are available online or often from your local retailer.
A couple good sources for batteries/chargers:
Hope this helps.
Dec 12, 2009 | Sony Handycam DCR-PC9E Mini DV Digital...
My DS keeps freezing when I play my DS games can you help me?
Is this when you use a flash card adaptor or when you use normal ds cardridges?
Be clear on what you are exactly doing and using.
When you're using a flash card adaptor, update the firmware on the flash card.
If it's the ds it self that is failing, contact Nintendo and tell them exactly what you are doing and how long it takes the DS to crash.
Note use original nintendo cardridges and
don't tell them when your using a flash card adaptor, they then won't help you because it's
then your own fault and they can take actions
on you because you'r then using iligal software!
Aug 30, 2009 | Nintendo DS Console
200MBPS Advent powerline adaptors dropping connection
It is normally reccommended that the adaptor goes straight into the socket so check the faulty one to see if it does rather than being plugged into a power strip.
Hope this helps
Aug 25, 2009 | Wavetek Acterna LT 8155T (LT8155T) Network...
Correct Cassette Adaptor
This is likely a firmware\software issue
you need to have a specific version of EPROM FLASH ROM programmed files..
Sep 19, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Buffalo router-WYR-GR4
you need to access your router's setup page in order to get the wep key. follow the steps below
- open a web browser and type on the address bar. the default username is "root" and leave the password blank
- you will be prompted with your router's page, go to the wireless settings
- then go to wireless security, there you will find your wep key or the encryption that you needed to connect wirelessly
hope this'll help and just ask me if you have other concern
Jul 17, 2008 | Buffalo Technology WHR-G54S Wireless...
Minolta DYNAX 500si
the T-adaptor for celestron is 1/14 inches. go to------- for anything in scopes & acc.
May 08, 2008 | Minolta Maxxum 500si 35mm SLR Camera
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
