Question about Logitech ChillStream Game Pad
Logitech chillstream doesn't work for fifa08
I installed fifa 08,the gamepad doesn't work at all.When i try calibrating,it can be detected.Can you please post me a solution.
  • Anonymous Oct 10, 2008
    I have the same problem
The game your contoller won't work on is set for PS2 you could get a adapter for PS2 to PC if you own 1. The controller you got is set for XBOX confiq but works well on "games for windows games", Hope this helps!
Posted on Mar 23, 2009
I installed the driver from this site.http://xbcd360guide.50webs.com/download.html
Posted on Jun 30, 2008
How can i play fifa 08 without the original cd or even not using a cd,i installed the game but when i tried to start the game it asks for cd,i tried one thing i copied the fifa 08 folder to a blank dv
hi there.
How do I play FIFA 08 without inserting the CD
Just copy the content of fifa 08 cd in a folder and then mount the folder using daemon tool, this will create a virtual cd drive that will act as an illusion.
download crack
>paste in directory and replace the original .exe file
>run game :D
or try this youtube link.
how to play fifa 08 without cd 100 working
or this one.
How to play fifa08 without cd
what ever you do,do so at your own risk.
Apr 21, 2012 | EA Sports Video Game Consoles & Games
My fifa 08 has been fully installed but its asking for the original cd......please help
First make sure the correct cd is in the drive alot of times these sports games come with 2 disks.
Secondly if you are still having problems go to this link and download the software as its on the website it will let you play the game with no cd so you should not have a problem anymore http://m0001.gamecopyworld.com/games/pc_fifa_2008.shtml#FIFA 08 Patch #2 [MULTI3] No-DVD/Fixed EXE 2
Feb 28, 2011 | EA Sports FIFA Soccer 2008 for Windows
Hello sir, i was playing fifa 08 in my pc for long days.But now a days as soos as try to load the game PC will be automatically shut down and closed.Please help me to fix it.
There may be 2 reasons..
1. Installation problem.. Try uninstalling the game and reinstall again..
2. Your game require a graphic card. make sure your pc is having one. and make sure your pc meet all the minimum requirements to play the fifa 08 game..
Here are the minimum system requirements for running FIFA 08:
  • Operating Systems: Windows XP SP2, Windows 2000 SP4 or Windows Vista (Windows 95, Windows 98, Windows ME and Windows NT 4.0 are not supported)
  • Processor: 1.3 GHz
  • RAM: 512 MB
  • Video Card: DirectX 9.0c Compatible 3D accelerated 64 MB video card or equivalent . Here’s the list of supported chipsets
Jun 30, 2010 | Sony PlayStation 2 (PS2) Console
All controls on my gamepad are not working
Hi, To jungle into FIFA 10, you must ( I use the PS commands ) - Stop the player by pushing R1 one time ( sprint button ) - Then push L2 - R2 at the same time once, the player start to make the first jungle, - Keep pushing L2 - R2 to jungle, you must do it in rythme, ( L2 is left foot / R2 is right foot ) Thanks and have a nice day ! J -
Apr 13, 2010 | Logitech Dual Action for Pc (963292-0403:)...
Viberation problem in fifa 08
wellcome,in the settings of the mode of downloading have been off not to viberate after downloading.
Jul 27, 2009 | Logitech Rumblepad 2 Vibration Feedback...
I have fifa o8. After installation it says'' insert fifa 08 cd''
a lot of PC games need the CD in to run. leave the CDrom in the drive when starting to play.
Jun 12, 2009 | EA Sports FIFA Soccer 2008 for Windows
Problem with file when I update
i had the same problem but for fifa 08 and i think the problem is that the game is not original. the files of the non original game are a little bit different.
Apr 02, 2009 | EA Sports FIFA Soccer 2008 for Windows
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
Not working help
joypad doesn`t work well ob fifa 09
Jan 19, 2008 | Saitek ST290 Joystick
Logitech ChillStream Game Pad Logo
635 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
