Question about Acer Aspire 5102WLMi Notebook
Screen goes pink
The screen on my laptop goes reddish pink after a while, black text with white halo is unreadable on a strong pink background. When I minimize, pink streaks on the desktop disappears, but when I revert (maximize) it is back to pink after a white background.
Any solution?
b
  • brenglis Jul 14, 2008
    I have the exact same problem, i am going to check the wiring before I go insane. The computer is only a year old and I have put it on an external moitor and it does the same thing on the external. Let you know what I come up with.
  • Anonymous Mar 27, 2014
    It is a tablet.
    the reading background is a charcoal gray...I want it back to white. How do I change this.?
  • 41 Answers
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen or its connection cable.
Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge, ON THE LEFT.
In case the problem is not the cable you might have to get a new LCD. You can have replacement parts and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
Posted on Jul 06, 2008
Tip
TOSHIBA DVD REGION FREE HACK METHOD.
1. Power on.
2. Open tray.
3. Push the info on remote once (with supplied remote). You will see numbers.
4. Press 9 for multi-region. Keep trying until you see the number 9 appear in upper left corner.
5. Power off.
Power on.
on May 21, 2012 | Toshiba Televison & Video
,my pc screen is pink
Symptoms line up with video card going out, or more likely screen going out. if you turn off the computer and turn it back on if its immediatly reddish/ pink tint then its your screen. Can be a bit expensive to fix. also could be as simple as the ribbon cable inside became loose, test this theory by lightly shaking the laptop. if the screen goes from good color and back to pinkish then that is your issue and you will need a repair shop if you are not comftable with opening up your machine! Good luck to you
Aug 30, 2012 | Computers & Internet
The picture keeps turning pink off and on lately...is it the bulb and can we replace it?
I have a suggestion: when it goes pink go to a black and white channel and examine the screen: if reddish you may be able to adjust the red screen control to correct this.
I can tell you how to do that and please let me know what you find before you rate this information.
SD TECH
Aug 29, 2011 | Hitachi 46F500 46" Rear Projection...
My Acer AL1717 Screen has turned Blue......I just want to know how to Turn it back to normal colour.....Anyone can Help??
hi,
reset your monitor color setting by the following setting
Press the menu button
Select Reset
press enter
this will reset the monitors color setting to factory default
ok
Jan 19, 2011 | Acer AL1717 17" LCD Monitor
I have a Phillips Magnavox HD Tv Rear Projection Television and the picture looks greenish and reddish and is blurry on the text of the screen? please help.
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
A reddish cloudy swirl sweeps across part of my screen.
IF you are seeing a red or pink large oval area in the middle of the screen, I can tell you what the problem is.
It is not the lamp.
Let me know if you need more information--please confirm you have the red or pink oval.
SD TECH
Jan 09, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Screen Goes Black When Game Is Inserted
Your laser could be bad, that is my idea for the situation. Your laser probably loads to a certain point and then just stops for some reason. You can try adjusting the potentiometers up 10 percent if your technologically advanced or try and replace the whole laser/drive.
Nov 21, 2008 | Microsoft Xbox 360 Console
White objects (especially text) on a black background produce a white halo effect around the white lettering. When playing a PS3 game I noticed that the blue color appeared black, as though I had no blue...
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Aug 27, 2008 | Philips 9P6040C 60" Rear Projection...
Poor registration on Xante CL30 HSE
Make sure the drums are properly seated in their cradels, and if posible, avoid designing with white small text in heavy solid areas that are made up of process colours. For reverse type in a black background, use spot color black rather than rich black. Other than than printing on a not as heavy card, that is about all you can do.
Aug 19, 2007 | Xante CL30 HSE Laser Printer
Acer Aspire 5102WLMi Notebook Logo
1,175 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
