Question about Sub-Zero Bottom Freezer Refrigerator
Model 550 Refrigerator constantly running. Had a Subzero repairman in and he said the evaporator coil is leaking and the refrigerator compressor is running constantly to keep up to temperature. I have it set at 5 and the temperature is 38 degrees. I decided to turn the freezer control to off (to make sure that compressor was not running) so I could move the refrigerator control warmer to see if it cycled off. When I turned the freezer off, the entire unit went silent; it apparently was the freezer compressor that was running constantly. He said he checked the freon level in the refrigerator section and it was showing 4 (lbs?) and it should be around 15. Now I'm questioning his diagnosis. He was quoting a total of $400.00 in repairs (it is still under warranty) Could it be something simpler? Any ideas?
    Guru:
  • 462 Answers
If its as warm as you say and the refrigerant is R134A his estimate of the pressure (4# is low for 38'F) is correct.
As for the leak I can only assume he sees something to make him believe its the evaporator.
As to the warranty (if its under 1 year it should all be covered. If its 2-5th year just the compressor is covered on some manufacturers others its the sealed system meaning leaks also).
And as far as $400.00? That's not out of line from my experience (limited by 30 years of doing this) I believe from what you have said about this fellow he knows his stuff and what it costs him to do business and that he will be around to perform your next service you need also. A rare thing to see these days. Even with hard times everywhere a business still has to make a profit and cover over head. Unless your AIG, GM, or Chrysler.
Posted on Apr 14, 2009
4 Suggested Answers
JJDown75
  • 8 Answers
SOURCE: Hi...need help...subzero 550
Make sure the condensor is clean, blow some Air though the Condensor to make sure good Air flow towards Compressors. also, you might have a bad defrost timer or Freezer Control... worst case you might have a bad Compressor... hope I can help....
Posted on Apr 15, 2008
SOURCE: Subzero Model 550, freezer not working properly
Blow out the condenser with an air compressor. Make sure the evaporator coil is not frosted up, if so, the drawer may naot have been closed properly, or you may have a defrost problem, (timer, terminator, etc). Possible freon leak in the high side drain loop. Compressor may not be pumping efficiently, could have a bad condenser fan motor.
Posted on May 31, 2008
Krazytech
  • 725 Answers
SOURCE: SubZero 550 Refrigerator Coils Freezing
defrost problem ... do you have frost or ice?
Posted on Aug 25, 2008
How do I turn off and reset side-by-side Subzero fridge, to vacuum condenser?
Usually vacuum condenser light is on, not because of condenser coils dirty, but low on refrigerant unit, so compressor is running longer then usually. You can shut your subzero off at breaker box, if light will keep coming on in day or two, you will need to call service to replace evaporator. Most likely evaporator in Fresh food section has leak(at list its most common place). Check this video I made, even if Your Sub Zero sideXside it still will look the same about changing evaporator. Hope that was helpful.
Feb 20, 2015 | Sub-Zero Refrigerators
Refrigerator and freezer not cooling
Hi Kirk Huggins - Do you hear the compressor running? The compressor is constantly meant to go on and off frequently to keep unit at a constant temperature. If you do not, the refrigerator could possibly have a coolant leak or an issue with the internal sealed system including a faulty compressor or evaporate fan. Contact a professional to accurately pinpoint any potentially more serious issues and to assist with the repairs.
Jan 27, 2013 | Frigidaire FRS26R4A Side by Side...
Why is my evaporator, refrigerator and freezer not getting cold with the compressor running and what type of refrigerant does it use?
Your system uses R-134a refrigerant.
If the compressor is running but it's not cooling, you probably have a refrigerant leak or possibly a restriction in your evaporator.
Unfortunately, refrigerant leaks are not DIY friendly, so my advise would be to call a competent repairman.
Sep 28, 2010 | Randell 20072SC R-134a Refrigerator
My Subzero Condenser fan runs constantly - but coils are clean
If it is similar to mine at home (Model 550) the condensor fan is designed to run continuously, even when both the freezer and refrigerator are shut off. There is no control or switch in the fan circuit, so it just runs whenever the fridge is plugged in to the wall. It uses about 56 watts.
Oct 19, 2009 | Sub-Zero 611 / O Bottom Freezer...
We have been getting service code 50 for our SubZero -- it;s a 690 model fridge/freezer. I cleaned everything however over last three weeks the error repeats. I reset the board by pulling power from the...
Error code 50 means excessive refrierator section compressor run. Possible causes include: dirty condenser, stopped condenser motor, faulty termistor or an evaporator refrigerant leak. If it is a refrigerant leak it usually shows up as frost or water driplets half way down on the back wall. Clear codes by holding the alarm button in for 15 seconds.
Aug 26, 2009 | Sub-Zero 632 / S
Sudden loss of refrigeration
why does it need to be replaced but in south afrika it costs r400.00 and labour r400.00 total cost r 800.00 but what is the problem maybe i can assist
Jun 17, 2009 | Sub-Zero 690 Side by Side Refrigerator
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
May 28, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero 611 Refrigerator not cooling, freezer fine
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Mar 12, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero Bottom Freezer Refrigerator Logo
511 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
