Question about Panasonic PT-47WX49 47" Rear Projection Television
Please help... The red crosses refuse to move left or right, both. They move up and down just fine.  Is there an easy test I can perform to see if it is in fact the resistor?  How difficult is the resistor relacement as compared to the IC replacement? Will I need to solder etc...?
  • Panasonic Master
  • 8,617 Answers
Yes you will need to solder in the resistors. How you check them is by unsoldering one side of the resistor and lifting it out of circuit and checking it for resistance. Ifd its open you will get no reading. If it reads less or more than 5 % of its rating it will need to be changed as well as it can weaken the Ics and they can end up failing if a weak resistor is left in circuit.
Posted on Jun 27, 2008
Cross Fingers I need assistance and description. Hard (10) Level 25
Sorry that I dont have pictures...but if you take the piece in the middle and move it all the way down into the black section up against the left side. Then take the piece on the right and move it into the black section against the right side. Then take the piece that you moved to the left in the black section and move it to where the piece on the right side started and then the right side piece should also be moved directly under that first piece. This will allow the large piece to slide down into the black section. From there it should be fairly easy to finish.
Aug 04, 2011 | Mobigame Cross Fingers Free
I have a ultrascan hd the convergance is off i dont have an owners manuel it tells me to use a curser what do i do to get the red blue right ?
The cursor probably is just a cross in the center of your TV screen whichever color your setting will be a color cross that you want to move by using the up, down, left, right, buttons on your remote. You want to move your color cross over the top of the center cross until it looks like one cross. Generalized setting instructions can be found here.http://www.ehow.com/how_2034880_perform-convergence--tv.html
If this helps let me know with a vote.
Mar 04, 2010 | Televison & Video
Puzzles 130 Too Many Queens 5 --- 132 Princess's Escape
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
Mar 09, 2009 | Nintendo Professor Layton & the Curious...
65 jvc iart model 65wp74 ,have a convergence problem,how do i get front panel off and where is circuit board located.Thanks
you need original jvc remote for this to work. Do not open anything until you. Go to menu on your remote find convergence and press the volume button to the right go to manual and press right again. you should see a bunch of rectangles, now you should also see a set of red cross heirs press the #2 to move cross heirs up and eight to move down numbers 4 and 6 will move left and right and 5 will place the cross heirs back to the center once you have chosen the selected section to adjust line up the magenta with the other colors using the channel and volume buttons these move the lines up down left to right adjust all lines until they are white. i do not know how to switch from magenta to green or blue but this should get you started on the right track with out having to replace anything. good luck! if you figure out how to switch from maqgent to green or blue please post it so that I may adjust mine as well tahnks
Feb 23, 2009 | JVC AV-65WP74 Rear Projection Television
Looks 3d
Dec 26, 2008 | JVC AV-65WP74 Rear Projection Television
Blurry shadows in red and teal.
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Picture look double and the colors red come out the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Sep 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Re:hello again
resistor replacement is very easy compared to IC replacement. You have to unsolder one side of the resitor and lift that side out of circuit in order to test it properly and if it doesnt measure its open and will need to be replaced or if it reads more thatn 5% of the rated resistance it will also have to be removed as the resistors are all 5% tolerance or less in convergence circuits
Jun 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Hello Again
Its possible one of the resistors were weak from the other ICs. Which way does the red refuse to move as that can help you pin point which resistor you should check
Jun 02, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergance problem
Your convergence IC's are bad and maybe a few of the supply resistors. Not an expensive repair but definantly something you would want a technician to do for you. Hope this helps.
Mar 23, 2008 | JVC AV-48WP30 48" Rear Projection...
TZ-55V61 Convergence
Do you still need assistance?? The convergence IC's are always
on the largest heatsinks in set......have you replaced??....T.
Aug 22, 2006 | Toshiba TZ55V61 55" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
18 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
