Question about Microwave Ovens
Danby DMW162BL-OTR not cooking after loud popping sound
This above stove unit stopped cooking after a load pop sound that was so strong it dislogged one of the metal racks. All functions appear to work ... but it does not cook. I read somewhere that these units had faulty capacitors. Any ideas? The unit wasn't used very much before it broke and has been out of service for a couple years ... is it worth trying to get it repaired? Thanks
  • Microwave Ovens Master
  • 9,098 Answers
I would say the high voltage diode blew.
I would check their Web site for links about parts, spares, or service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 04, 2008
I removed the bolts for my Danby OTR microwave. Dmw162w-otr. The microwave does not move. Are there any other bolts or is there anything I am missing before I can remove the microwave?
In a normal installation, there is a plate that mounts to the wall and bolts come down through the cabinet. Once the bolts are removed from the cabinet above mic, the mic should hindge forward. It takes two people to handle. How ever, in some cases an installation guy will add screws into the side of the unit. So look for some screws to the right and left of mic. Good luck!
Jan 29, 2016 | Danby Microwave Ovens
it is toast,replace unit
Apr 18, 2017 | Maytag Microwave Ovens
I have a Frigidaire over the stove microwave that pops/arcs
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
Dec 15, 2009 | Frigidaire GLMV169D Microwave Oven
Yesterday while using the stove top to cook some chili the lights under the microwave blew out with a loud "pop". It tripped the breaker switch so I reset it and everything works like it should except the...
Well I'm reaching here---if the bulb did not fracture/break then it sounds like a capacitor popped--check your owners manual for reset button but I don't think there is one for the lighting---In addition if you can see the circuit board--look for burn spot or wet spot. GL
Sep 18, 2017 | Kenmore 80412 Microwave Oven
My goldstar above the stove microwave popped and now won't heat. Everything else on the unit still works. Is this a problem that can be repaired? Thanks.
Did it make a loud pop like a firecracker?
Sounds like the High Voltage Diode shorted out and it probably is making a low or loud growling noise now..... ???
Sep 11, 2009 | Microwave Ovens
If it was in cook mode then a loud pop and it died, it sounds like the High Voltage Capacitor shorted, blowing the line fuse. You need an ohm meter to go through the high voltage section to check everything before you replace the fuse (which will blow again immediately).
BE CAREFULL!!!!! If you take the cover off, be sure to short across the terminals on the high voltage capacitor just in case.
Sep 09, 2009 | Sharp R-3H88 Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave made loud popping sound and now does not heat.
Try this
Probably a high voltage diode popped because contaminated grease eventually built up and made a path for a high voltsge arc to occur.. To confirm,take the outer cover off the microwave and discharge the high voltage capacitor by shorting its terminals. Then pull the plug off the magnetron side and place it near the magnetron socket. Now turn the microwave on and push the connector on the magnetron with a chopstick or a long insulated screwdriver. If no arc when you do this this confirms a bad diode.
please rate my suggestion..
Apr 13, 2009 | Kenmore 62702 Microwave Oven
Microwave made a loud pop,won't heat,sounds like it's only on half power, makes a low intermittent hum
This is almost certainly a blown high voltage diode.
Please reply back with your brand and model number so we can help you.
May 31, 2008 | Microwave Ovens
LED displays ''STAGE'' after magnetron replacement on DANBY DMW162W-OTR
What does the service center have to say about this?
Or did you do it yourself?
Dec 01, 2007 | Danby DMW139 Microwave Oven
Microwave Ovens Logo
126 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
