Question about HP Color LaserJet 2600n Printer
Hp 3800dtn standard top bin full remove paper error
We just picked up this printer and right off the bat this is the error we are getting. No matter if there is paper or not in the tray.I looked to see if anything in and around the tray area was broken or stuck. Also looked around the paper exit area , but maybe I don't know exactly what to look at. Any help would be greatly appreciated.
thanks
Aaron I replased a leaver on the right side of the printer ( don't now iet's description). the i got an error 59.co ande had toe alin the gears. Got that out of the way. But now is gives me this standard top bin full remove paper error.
Plz help.
thanx
  • sani191 Jul 15, 2008
    my printer got the problem.. "standart top bin full" when i open the cover.. i didn't see the paper.. how to solve this problem. can u help me
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Top bin full error is hte lever sensor where you see the paper coming out, the lever is stuck in the up position.
It's used to tell you to remove the paper from the exit because it's too full.( Too many copies on the top)
Posted on Jul 21, 2008
Standard top bin full?
I suggest you remove any sheets of paper from top tray then lift up and release a black plastic flap found under a plastic overhang on paper exit tray. This lever (If its not broken/missing), should be free and should drop down(under its own weight) freely. If not then it will involve using the manual to remove the top cover and find where lever is jamming (usually jumped out of a guide bearing.)
regards
carmike
Feb 17, 2014 | HP LaserJet 5200tn Printer
where paper comes out on top, on right hand side is a plastic lever that is normally resting down. If it gets stuck in the up position, or the bin is full it will give you the error
Part number is RC1-7460-000CN, bin full flag
Nov 16, 2013 | HP LaserJet 5200tn Printer
Hp 5550n error - standard output bin full please remove all paper from bin
After print paper reaches upper bin, you can observe a flag moving while paper coming out. once this flag is stopped moving printer treates bin full..check the flag is moving freely. open top cover clean this sensor.
Sep 21, 2011 | HP Hewlett Packard LaserJet 5550n Printer
When i on the printer then "standard top bin full
Just check at upside where paper iscoming out after print, there you can see the two black flips to monitor the paper out position, this flag sensor got dusty this error apprears, remove back cover, you can observe left side this sensor, just clean it..
Aug 25, 2011 | HP LaserJet P3005 Printer
Issues with HP Laserjet P3005n
That means that the output tray is filled to capacity, or one of the students broke the "bin full flag" at the top of the printer.
Feb 24, 2010 | HP Hewlett Packard LaserJet P3005n Printer
Standard top bin full remove all paper from bin
Check the sensor flag where the paper exits the printer and make sure it is not stuck in the "up" position. This is a small black plactic flap right in the center of where the paper exits. When this flap is up it tells the printer that this area is full. HP says to "flip" the sensor flag up and down to make sure it is not stuck.
Good Luck
Nov 25, 2009 | HP LaserJet P3005 Printer
Standard top bin full remove paper
Greets!
Firstly, is the exit bin full of paper? If it is, just remove it.
If not, then it's going to be a sensor that recognizes the paper amounts in the exit tray. Check for broken plastics and possibly stuck plastic flaps in the exit tray.
If it's neither of those, try turn it off, unplug, then reverse.
Other than that, if no go, then it's an internal sensor issue. At that point, probably the best bet is to replace as repair costs would outweight a new unit cost most likely.
Feb 26, 2009 | HP LaserJet P3005 Printer
Standard top bin full error in hp 5200 tn laserjet printer
i have hp 5200 printer
printer shows message top bin full
and not prints what slution of this error
Aug 28, 2008 | HP LaserJet 2420 Printer
Maybe your paper sensor flag is stuck or broken if you pull the tray out of the machine there should be a little black plastic sensor flag hanging from the top middle of the slot where you pulled the tray out from if its stuck up or broken the tray will always sense its full of paper.
Jun 20, 2008 | HP LaserJet 3800dtn Printer
Hi there is seems that the machine thinks there is too much paper at the paper printout exit. If there are printouts on the top of the printer remove them and the printer will start printing or the error message will go away. If there is nothing on top of the printer then where the paper comes out after it has printed you will see a black plastic lever type it is more likely to be in the up position without breaking it if it hasn't already been broken move it so it is in the down position it is on a hinge so be careful and it should sit at an angle. Once this has been done the printer will reset the message itself.
Hope this is help you oh if the arm is broken it will need replacing (just the arm)
Thanks J
Jan 12, 2008 | HP LaserJet 2420 Printer
HP Color LaserJet 2600n Printer Logo
1,645 people viewed this question
Seeker5211
Seeker5211
