Sony KV29C3A 100Hz
Hi Kalm!!
I can unplugged from main my TV and waiting some time and then try to measure something,could be the problem some component belong to this circuit like resistors,capacitors?or is the transformer it self?
  • 63 Answers
It's almost certainly the transformer itself but with the fault you are getting it wouldn't be something that can be measured with a meter.
Regards
Andy
Posted on Jun 27, 2008
My sony trinitron KV29F1U has an Av1 sign all the time on the screen
The input selector section has some fault. Just try to unplug the TV from AC mains socket, wait for some time, replaug it and see. If this do not help you, the tV need service.
Apr 30, 2012 | Sony Televison & Video
Sony KV29C3A 100Hz
This will almost certainly be a problem with the Line output transformer, sometimes known as the flyback transformer. It will need to be repaired by a qualified technician I'm affraid as there are dangerous voltages on this part even with the set unplugged from the mains.
Sorry for the bad news.
Andy
Jun 26, 2008 | Sony Televison & Video
TV won't power up after surge
Try this: unplug the set and wait about 10 or 20 minutes. This is to make sure that the main power supply filter caps completely discharge. Look on the power supply board, close to where the AC cord attaches to the board. Look for a white resistor labeled "0.1 OHM" (the symbol for OHM, like an upside-down U) and measure it with your ohm meter. If it is open then your switching transistors in the main power supply are most certainly shorted. Older sets had 2 separate transistors on little heat sinks labeled "C4834", then they switched to 2 transistors in one package labeled "MX0841" or "MX0842", and then some sets went to two separate MOSFET transistors. Measure those parts and post your results and we will guide you from there.
Aug 08, 2007 | Sony KV-35S42 35" TV
Our Sony TV was turned off this morning. Now when we try to turn the TV on the standby button is flashing and we get no power to the TV. Our remote also is not working on the TV. Is there a reset button...
Sorry,there are no resetting button,unplugging,waiting for a period of times,ruplugging tv it back that is ur reset back to the factory setting.Tv have the same problems,not working.The power supply board have problems,it dying.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 07, 2010 | Sony KDL32EX500 32 in. TV
I have a Sony KDL32D300 Digital 100HZ Lcd Tv that I bought 3 years ago for around £800. The television no longer displays a picture, just a series of vertical coloured lines that cover the entire...
Unfortunately the vertical colored lines usually indicates the lcd panel is faulty. Replacing that part is usually more expensive than just replacing the TV. If you want to try a fix there is a multi wired cable that plugs into the panel. there is a slim chance that reseatting cable on both ends could help.
Sep 13, 2010 | Sony Televison & Video
Sony KP-FX43M31
On the Sony FX43 100Hz 43-inch rear projection TV, three flashes indicates an Over Voltage Protection problem, occurring in one of the power supply circuits T603 or R672.
The fix will most likely cost more than the set is worth second-hand, I'm afraid.
Jun 28, 2008 | Sony KP-51WS510 51" Rear Projection...
Auto off
possible cause is one or more imperfect contacts on the main board
May 27, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony KV32hs510 - Won't come on flashing light - 6 or 7 times
hi there, you have the hardware prob., at the power supply section., test the bleeder resistor which is 100 kilo ohms or higher, do some check up and test. ty
Feb 16, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv cycling on and off
Phillip you have a problem in the main power supply or in the High voltage shutdown circuit. Now the longer you wait to have this fixed the more its gonna cost ya Unless your a tech then get a schematic and measure the voltage on the hv shutdown pin on the video junglke ic when the set shuts down If the voltage at the time of the shutdown sodent spike up then you know your problem is in the power supply. Good luck
May 27, 2006 | Sony Grand WEGA KDF-50WE655 50" Rear...
Samsung Flat screen 100hz tv - no power
My samsung flat screen tv have sound coming out but no display...anyway to check/help...
May 01, 2006 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
