Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Just was given a sony tinitron ( Mng 2001, Chassis BA5, Model KV-32F512) from a friend. It worked at his house but can't even get a picture at mine.All I want to do is watch movies, not get hooked up to cable. I have cable run between VCR and TV. No picture at all. No remote either Why?
SOURCE:
  • 308 Answers
SOURCE: Sony FD Trinition WEGA KV-32fs120 32" (no picture)
If the standby light is blinking 5 times then repeating, it is likely a problem in your picture tube or related circuitry. Other possibilities include the "Jungle" IC which takes care of the video, chroma and deflection processes and is a bear to replace. Either way, it could be an expensive repair.
Posted on Feb 11, 2007
premtech
  • 934 Answers
SOURCE: Sony KV-32XBR400 television
Four blinks would normally indicate a yoke winding that was shorting intermittently, 5 blinks something on the "D" board in overvoltage condition and 6 blinks commonly Ic6501 is failing...
To have all of these blink codes happening could be signal derived, thereby not affecting dvd play. Could be smps related or possibly regulation. My first guess would be the "D" board...
Is there a cheap and quick fix, yes and no... This isn't one you'll be able test out or you wouldn't be asking the question. But a shop should be able to determine the problem and repair for less than half the cost of a new Tv in it's comparable class..
Hope this helps!
Bill
Posted on Nov 20, 2007
SOURCE: Sony KV-30HS420 turns off all by itself
This is less a solution than a work-around, but it does work for me, and it is free or low-cost.
I have had the same problem on the same Sony (model KV-30HS420),picture fading out to green then black, then turning off by itself,after which sometimes the light blinks 6 times, other times it blinks 7times. This started about four years after I bought it, which is not adecent lifetime for a CRT TV. It would happen anytime from 2 or 3 timesan hour to 30 to 40 times an hour. After getting absolutely nowherewith Sony, which was completely unresponsive and unhelpful, and which refusedto stand by their product or provide any useful information, I wasgetting ready to buy a new LCD TV, any brand but Sony (never buyanything from them again), when on a whim I decided to try one last stopgap solution.
I put a fan up against the side of the TV, blowing into the vents. Ithas been 3 days now, and not once has the fading and shutting downoccurred. So it looks like the fading out and shutting down wassomehow related to heat, and the ventilation seems to have solved it. I don't know why it should be a problem now, when it was not the first fewyears. It is also a mystery why Sony has not been able to figure thisout, since it is clear from online postings that many people have thisproblem with this model. Give this a try and see if it solves theproblem for you.
Posted on Feb 10, 2009
  • 5909 Answers
SOURCE: For my Sony Trinitron TV,
The
Posted on Sep 10, 2010
gopakumarg43
  • 76060 Answers
SOURCE: I have the 2000 Sony
Hello
To turn the PIP feature ON and OFF press the button marked PIP on the remote contro. Each press will get it vanished and reappear. OK.
Posted on May 08, 2011
The colour of our sony tinitron color tv model no.kv-xf21m83 has got fading (Red colour disappeared )and the indicator flashes red a number of times between 3 second intervals and the est is sparking
hi
this sounds as if the tube (crt) as a intermittant short in the red gun , try tapping the neck of the tube very softly with a screw driver handle, this just might just clear the fault
regards windyhouse
Apr 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Hi just been given a sony 50" tv but is not working how do i tell what model it is
Using a good light source, check for model information molded into the plastic rear housing. You may have to illuminate at an angle to see it clearly. Often, it is near the power cord entrance.
Dec 09, 2008 | Sony KV-32S45 32" TV
SONY WEGA PROBLEM
That doesn't make sense. When you state that the TV comes on 5 minutes later, doo you mean that you get sound right away but hte picture comes on later? If so, a :power board" won't help. Please update this so we can narrow down the problem and get you a solution.
Thanks,
Dan
Aug 20, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY WEGA KV-32XL90E
Hiii...
what chassis your tv set ?
Thank's
[Vrya]
Jan 23, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Power not turning on
Power supply failure! Requires several steps==
1)Pull main board & power supply board
2)Check horiz output xistor = shorted? Replace w/ first quality
3)Carefully solder horiz drive circuitry from HDT to base of o/p
4)On power board--replace shorted converter transistors 2SC4834 and R607 .1 ohm 1/2 watt fusible
5)reassemble.     Let me know how it goes.....T.
Oct 22, 2007 | Sony KV-36FS16 36" TV
Sony 35inch Trinitron Color TV
Hi. I dont recognise that model number. Take a look at the rear of set & see if there is a chassis number eg AE1. AE1A, AE1B, AE1C, AE2, AE2A, AE5, AE3B, BE2, BE2A,BE3, DE1, F1, FX, These are some of the common older chassis. You say led flashes does it flash 2, 3, 4, 5, times etc then pause then repeat ?
Sep 23, 2007 | Sony KV-35V36 35" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
62 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
