Hi, I am looking for a logic board for an NEC 42" Plasma, Model PX42VM3G/S if anyone can assist. I am not sure what the part number is, I am also looking for a parts list for it.
No thanks, I will use my own endeavours rather than having to pay as this issue is not so much a need of advice as just finding a part. Thanks anyway, I shall keep your address for future use when required.
Thanks
Peter
Posted on Jun 28, 2008
When we connect the power, the green light "
Hi Bruno,
First of all thank you for posting your question here at Fixya.
I'm assuming here that your TV's model number at the rear panel is MX-50HPT51.
My first advice is to unplug the unit from the outlet (AC source) for at least 1 hour to drain any voltages from the boards and to reset itself and then plug it back in and check if the symptoms still persist.
If the symptoms remain the same, this is an indication that the logic control board of your unit gone to malfunction. It is located at the center inside the set. See sample picture of logic board used for Maxent plasma TV at the end of this solution.
Please note that this is not your actual logic control board, it is used for another model no. I've attached it to give you an idea what it's gonna looks like. I've checked my link online for your logic control board but they are currently out-of-stock. I would advice you to contact your local Maxent sevice center to obtain the board.
Also, don't forget to check if your unit is under warranty/extended warranty period, avail it because the manufacturer will fix it for free. Opening the rear panel will void the warranty.
Please let me know if you need further assistance.
Hope I helped you.
Rating and feedback are highly appreciated.
Good luck and take care!
Kind Regards,
Jazz Electronics
Dec 15, 2011 | Maxent MX-50HPT51 50 in. Plasma TV
Hi, Approximately eighteen months ago, I purchased a 42 inch plasma Panasonic television model number: TH-42pz77u) but Saturday night, the television turn off and have five blinking red lights. Then we...
The 5 blinks on the LED means that the main logic D board is defective and will need to be replace to fix the TV.
Check this site to find replacement parts to fix your plasma if you intend to DIY.
Let me know if you need further assistance.
Jan 15, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Left half of screen has vertical color bars of different colors
Hi
This will be your screen controller board that has failed also known as the ldv's board, With the back removed from your TV it will sit below your power supply and be connected via a ribbon cable to your Y Sustain board on the left.
Remove it and take the part number of the board then Google or Ebay for a replacement.
Take a look at the below link so you know what you are looking for.
Hope this helps
http://cgi.ebay.co.uk/LG-42-Plasma-Tv-part-LOGIC-CONTROL-Board-EAX36952701_W0QQitemZ350341474285QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item5191faa7ed
Apr 21, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Hi. When I switch on my NEC 42" Plasma (PX-42VM3A), the on light changes from red to green but then nothing happens. I have box-loads of spare parts but would appreciate any assistance in pointing me in...
CHECK FUSE AT Y-SUSTAINER PCB. IF BLOWN, DO NOT REPLACE IT! LOOK AT SCAN CONVERTORS BOARDS. THEY ARE CONNECTED BETWEEN Y-SUS AND PLUGS FROM DISPLAY(LEFT SIDE WITH FACE DOWN, BACK OPEN). SCENARIO: SCANS GOT BURNED(LOOK FOR A SIGNS AT THOSE LONG BOARDS: UPPER&LOWER).FIND ANY IMPERFECTIONS: REPLACE ALL 3 BOARDS: Y-SUS, UP/LOW SCANS.LAST THING: IF FUSE IS OK, CHECK POWER SUPPLY FOR BLOATED CAPACITORS(BIGGEST BOARD IN A MIDDLE OF THE SET) SAME SERVICE POSITION.
GOOD LUCK,
LET ME KNOW HOW TI GOES.
ALEX'S TV?PHILADELPHIA, PA.
Apr 06, 2010 | NEC PX-42VM3A 42 in. EDTV-Ready Plasma...
NEC PXT-42SV1B Plasma has picture 10 seconds
you may check thew board here a web page where they sell boards
http://www.discount-merchant.com/
Said
Dec 18, 2009 | NEC PXT-42SX1B 42 in. Plasma TV
No video but audio is fine on Sanyo 42" DP42746 TV
If you unplugged the Ysus board, then you need to replace the Ysus board, or both sustain boards. This is the part: The part is often available on Ebay, or from manufacturer. Look also at Vance baldwin or Partstore. To do a good job the Sustain boards should be tested by a tech , following service manual. It is almost for sure sustain board by the way.
Oct 12, 2009 | Sanyo DP42746 42 in. Plasma Television
Power supply issues
hi there, i recommend replacing the entire board. once you have a short like this, the micro board itself will become useless. the thin micro circuitry has become separated within the layers, preventing a closed current transfer. its best to order a new canvas so to speak.
Mar 11, 2009 | NEC PX-42VP4PA 42 in. EDTV-Ready Plasma...
NEC power supply unit
I have most NEC plasma boards and know the procedure to determine which board is bad.
Aug 26, 2008 | NEC PlasmaSync 50MP1 50 in. Television
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Electro Med Services...
