Question about HP Computers & Internet
Windows error My son turned the computer off without shutting down first. When we tried to boot up the computer again, it gave us an error message. We could either choose: safe mode, start windows normally, last known configurastion, safe mode with networking, or safe mode with command prompt. We tried all of them and windows will not boot back up. Do you have any suggestions? The desk top is an HP Pavilion a1123c
  • Anonymous Mar 31, 2014
    Tried all advice I can find on internet but safe mode is on , can't turn off uninstalled the game my son tried to install but still on?
  • 77 Answers
First, make sure there are no discs in any of the drives as this could disrupt the boot process. Prior to seeing the HP screen you should get a prompt as to press F10 to go into system setup. Once in system setup choose the option to go to system restore or system recovery. From there you should be able to restore your computer to a sytem restore point that was set up with a checkpoint at set intervals by Windows XP. If that is unsuccessful you may have to utilize your recovery discs.
Good Luck.
Posted on Jun 27, 2008
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
How do I stop my laptop from reboot loop?
Just insert a windows CD and repair your OS. Your problem will be solved while preserving all your files and folders! Good luck
Jun 14, 2013 | Acer Aspire 7520-5185 Laptop
Boot Error Shutting Down Sony NWD-B103F
Contact Sony Tech support via email. they should be able to help. it is free I think.
Jul 14, 2017 | Audio Players & Recorders
My HP e9120f gave me the following error message the other day. "reboot and select proper boot device..." My first thought was my hard drive was bad. I could turn off the computer and after a...
You might have another part that has gone bad. Check the RAM and see if it gives you any problems.
There is a program call mem test that you can burn to a CD and test your memory. But if your no longer able to get to the bios:
you def had a hardware problem.
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
Sep 28, 2009 | Dell Vostro 1700 Notebook
Computer boots up then shows windows 98 scrren
you may face either harddisk failure, a driver problem or virus infection:
tools: original win98-cd (or a bootable image
version of it), antivir-software on cd!
- please check whether it is possible to boot from win98-cd, with cd-rom support, not from harddisk.
(such option should be availabe after bios-load is over)
if not:
leave the setup process without fully installing
(press F3 button when asked for repair or install option)
in both cases :
type at the dos-prompt:
(command for changing to harddisk, windows-folder, booting windows from harddisk, but without loading all the drivers as usually)
win98 should come up in protected mode or give error messages.
- access cd-drive and execute vir-scan.
- delete and/or repair infected files
- turn down, attempt to reboot from hd
- if still impossible reboot from win98-cd,
run repair of installation and try once again
standard boot
problem solved? if not, take down error messages consult fixya again!
Jun 13, 2009 | Dell XPS M140 Notebook
Computer will not boot up
need to reinstall windows it is corrupted
Mar 27, 2009 | Dell Dimension 2400 PC Desktop
On shutting down my laptop it gave the message, "installing 1 of 1" do not turn off your computer. It did not turn off all night. I turned it off by using the on/off button then shut it down...
When you start your laptop, press F8. You will get a menu (Normal boot, Reboot...). Choose Last good known configuration (something like that).
Aug 20, 2008 | Acer Computers & Internet
Siren Edge 4 gig Boot error,
Siren's software support is bad, but you can call them: 254.224.0222
Sometimes reformatting a player can cause key system files to be lost - this particular mp3 player does not have a recovery tool or a firmware upgrade that I know of, so you can try the Windows Recovery Method: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Let me know how it turns out.
Jun 13, 2008 | Siren Edge MP3 Player
Computers & Internet Logo
100 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
