Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
Modifying the DC18RA from 110V to 220v
Hi MarkDay
I want to replace the stock transformer in the 110V DC18RA, in order for i to work with 220V. Can you help me find where in europe I can get the transformer needed in order to do this?
  • 2 more comments
  • Anonymous Oct 04, 2008
    charger dc18ra transform from 110v to 220 v
  • Anonymous Oct 22, 2008
    i have exactly the same problem - is there a
    "cheap" workaround?
  • Anonymous Nov 10, 2008
    Same here!
  • tsmyles Mar 26, 2009
    So, since it appears that the DC18RA has a switching supply that simply has a few components only rated for 120 volts, has anyone tried using it on 120 volts AFTER the component change?
    Theoretically it shouldn't make a difference; right?
  • 3 Answers
Hi there the solution for how to mod a DC18RA charger can be found here. The "how to" comes with pictures and descriptions and it should be easy to follow, and best of all it works :)
Posted on Nov 11, 2008
I tried changing the capacitors, but the MOSFET blew instead.  Turns out that the MOSFETs in the 110V model has about half the voltage rating of the one in the 220V model.
The MOSFET is expensive, so you're better off buying a 220/110V transformer or a 220V charger.
Posted on Nov 06, 2009
  • 66 Answers
Hi all,
I added another HowTo page for modding the DC18RA from 110V to 220V , you can find it here
Have fun and good luck
Posted on Jan 10, 2009
  • 313 Answers
Don't replace the transformer in ur charger.just get a step up transformer like 110v to 220volts with plug in receptacle.
Posted on Aug 21, 2008
  • Leslie du Plessis
    Leslie du Plessis May 03, 2017
    I tried this but it does not work. I'm guessing that the Wattage on the step up adapter has to be higher than the 70W on mine?
I tried this solution. I found out the capacitor has to be bigger. 220uF did not do the job, replaced with 500uF and then it worked :-)
Posted on Dec 30, 2008
Hello! My BOSE (max 300w) have in 110V, and I need for 220V BILLION 261278-102 REV.07 E2-86RTF-NS1-0289 A92TS-196B-1 R152D 07'23 Where can I order a suitable transformer for 220V? How to chenge...
there are suitable converters in the market from 220v to 110v.
google in your area to find an electronic store that provides this type of converters.
second choice .
if you know someone that winds electrical transformers or motors .you can ask him to modify your transformer its easy done .
number of wire turns and diameter.... turns *2 and diameter 1/2.
for an example: 410 turns for 110v it will be 820 turns and 1/2 diameter of the wire, that will fit exactly the transformer size.
Good luck
Apr 11, 2015 | Bose Audio Players & Recorders
Makita Dc18rc from 110v to 220v
Did Someone Succeeded to Change the DC18RC from 110v to 220v ??
What are the component that should be replaced ??
Where can i get them ?
Thx ,
May 17, 2013 | Drills
If I would buy a Onkyo TX-NR616 in the US (110V) and take it Europe (220V), wouldn't it be a solution to simply exchange the power transformer for a 220v one?
An stepdown transformer is needed should you buy in US and use it Europe
However, if your on a technical side , trace the primary windings , and check
There are European versions which are already 220V, no need to convert.
Source : page EN 99 of the Onkyo TX NR616
Sep 24, 2012 | Onkyo Tx-nr616 7.2 Thx Certified Network...
Modifying the DC18RA from 220V to 110V. how?
Really, this is not something that can be changed easily, just buy a 110 charger...
Mar 14, 2011 | Makita 18V LXT Lithium - Ion Cordless...
I just bought a computer speaker but it's 110v and my computer is 220v. can i plug the speaker to the computer without damaging the speakers?
Hi ,
If it says it needs a AC 110V connection , you will fry at least the sub . Don't do it ! Connect the device to an AC 220 / 110 V transformer you can find on the net or in all specialized retail shops .
Best regards
Feb 03, 2011 | Bose Companion 5 Multimedia Speaker System...
Hi, Toroidal transformer in Sakura AV-200T input is 220v I need 110v Thanks
Hello shole135, Hi, you need a 110v to 220v step-up transformer with 200 watts power specification. you can visit your local hardware store and find one. Don't replace the toroidal transformer.
Dec 02, 2010 | Audio Players & Recorders
What is the specific power transformer (internal) i need to switch my logitech 230 speakers from 220v to 110v?
If the speakers are wanting 220V, will they work, at a diminished level, if you only supply 110V ?
Otherwise, you need a "step-up" transformer, which takes 110V input, and produces 220V as output.
Do the speakers have a "110V/220V" switch on them????
Apr 05, 2010 | Logitech X-230 Computer Speakers
MAKITACHARGER 220v to 110v problem after using of right converter
hi all,
I added another HowTo page for moding the DC18RA from 110V to 220V , you can find it here
Jan 07, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
The 110v transformer was inserted into 220v socket!
You have damaged the system beyond economical repair. There are so many components inside that have fried that it is impossible to repair. Sorry. That's what happens when you overvolt an electronic circuit.
Nov 23, 2008 | Summer Infant Additonal Camera for Video...
DC18RA from 110v to 220v
The varistor you have to change is the one that runs parallel on the current after the fuse, in my case it was easy to find as it was the one with the plastic hood on it.
I'm going to update the webpage with some new pictures that I hope would hetp to clarify it.
Nov 16, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
9,517 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
