If you go to your menu there should be a place for you to "copy"...place your card into your camera and then go to that and copy, it should put them onto your memory card
I dont think you can...you will need to plug the cam into your computer and get them off...to a folder on compy ,then put the card back in and save from you computer folder found under My Computer then removable storage devices (the one that matches you cam)
May I suggest you remove this particular instance, save your work, shut down Quicken. Restart the program and put the transaction in again. Sometimes I have success toing it this way.
I've learned from a Mitsu tech that there is indeed NO easy (nor logical & user-friendly) way to UN-memorize a QV channel.
However there IS a work-around to accomplish that so that the QV will revert back to its Factory Setting of "Last Channel Recall."
Using the Mitsu remote control:
1. Poke the Menu button.
2. On the Menu, select the "Add/Delete Channels."
3. Select the Antenna (A or B or whichever) and select the channel which was memorized in QV.
4. When that memorized channel number appears, select "Delete."
5. Poke the Menu button again to exit.
The QV memorized channel number is now gone, restoring the QV function to "Last Channel Recall."
NOTE: If that particular deleted memorized channel was also included among the SQV (Super Quick View) channels, it can then be added back into SQV using the Menu and SQV option.
Hope the above helps those who have encountered the same issue.
DWL
