Question about Olympus SP-510 UZ Digital Camera
Memory Card Door Sensor
I recently had some trouble when getting my memory card stuck in the slot. In the process of getting it out I must have broke something. Whenever I turn the camera on it just has a blue error screen saying close card cover. The camera will not go to any other screen even though the door/cover is closed. So I carefully took it apart and notice that right where the plastic piece from the door/cover enters in to the camera. there are 2 small holes where some piece of small metal or something was. I have read a couple opinions online and one states that I should find 4 square areas with solder and solder a piece of wire horizantally within them? Is there any thing that you guys could suggest, and if not would be able to help me out in locating the square areas? Anykind of help you can send this way would be much appreciated.
  • 48 Answers
The 4 square areas will most likely be behind the the memorycard slot or behind the actual lense you will have to solder it if the wiring has been broken off.
Posted on Jun 27, 2008
Displays memory card error. Card locked. I have tried several different cards that are not locked and it displays the same.
Look at the card where the lock tab is, Now look in the slot on the camera where that card goes, Check for a tab on the camera that hits the tab on the card. If it is missing, stuck or broken you get that error. This is tricky because the slot has a little door on it that has to be held open on some models, also you need a light. You may be able to use a sewing needle or eyeglass screwdriver to probe the locking tab sensor.
Feb 01, 2016 | Cameras
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
How do I transfer photo's from my PC to the memory card in my Panasonic DMC-TZ8
The photo processing shop most likely will have trouble downloading the photos from your camera/memory card.
I suggest you purchase an USB memory stick and copy the photos to this USB memory stick and then take the USB memory stick to the photo processing shop.
Jun 17, 2012 | Panasonic Lumix DMC-ZS5 / DMC-TZ8 Digital...
Fuji finepix s700 camera error message protected card. After making sure sd card in unlocked. I still get this message. I had trouble getting out a sd card,i feel a piece of the sd card broke in the...
Take a small flash light and see if there is a part of a memory card in there, if there is cleaning it out would solve the problem. Also make sure you're putting the memory card in the right way. I've you've done that and it's still giving you problems try going into the menu's and formatting the memory card in the camera.
May 10, 2011 | Fuji FinePix S700 Digital Camera
When I put my memory card in my phone,and when I try to go to the camera it says''please insert memory card''.I know its not the memory card because I just bought a new one.It must be the phone.how do I...
To repair the memory card slot of your phone, you have to dismantle the phone first and get to the memory card slot or reader that is in the phone, then you replace it with a new one.
It is quite a fragile process therefore i will strongly advice you take proper caution in dismantling the phone.
First, turn off the phone, remove the battery cover, sim, and battery of the phone, get the appropriate screwdriver and unscrew the phone, carefully, remove the parts, then you will see the memory card slot, try to get the replacement parts down before starting the process.
After getting the memory card slot replaced, reverse the process of dismantling for reassembling the phone.
Good luck and take care
Oct 08, 2010 | Samsung Instinct Cell Phone
Memory Card Stuck in slot
Disassembly and repair isn't something for the faint of heart nor the inexperienced with tools. If you don't have the best buy extended warranty for this device and since it's been over a year, your options are slim.
It is possible to repair the spring mechanism on these devices, but you'll need some fine tiped screwdrivers bowls for parts, a good memory for where parts came from to be put back, annd a lot of patience.
The spring is a leaf spring on the bottom of the card slot and the retention clip is on the right about half-way into the card slot.
I wish you the best of luck with your repair.
Mar 07, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
Misc card stuck in slot, how do i get it out ?
1. Shut Down The laptop
2. Remove the laptop Battery ( Close the Lid , turn the laptop Up side down, search for a battery Lock tab, move it to Unlock position, You can see a Lock/Unlock mark on the Laptop cover, this will eject the battery from the slot.
3. Get a tweezers carefully pullout the memory card from the card slot, utmost care should be taken not to damage the card slot contacts
4. After taking out the card put back the battery make sure that it is in the locked position
5. Start the computer , try out the system
6. Verify the memory Card reader functionality using a proper card as per the maker guidelines
Jan 31, 2010 | Toshiba Satellite Pro A210-EZ2203X...
Memory card stuck in the SD slot
ohh
its a viurs.if is it nt detect virus gard
try to make externel memory card reder and dnt open.1st activate ur hiden fils and folders and go to memericad rigcht clik explor and del all hiden files specialy aoutorun.inf file del. and copy ur doc to pc then good for format ur memory card. tnx
Sep 13, 2009 | Canon PIXMA MP970 InkJet Printer
Door to my memory card slot broke off
If your handset is in warrenty period you can contact you service provider or you can go to the nearest service center.
Sep 09, 2009 | RIM BlackBerry Pearl 8100
Nokia N70 wont acknowledge memory card?
Note: This device uses a Reduced Size Dual Voltage
(1.8/3V) MultiMediaCard (RS-MMC). To ensure
interoperability, use only dual voltage RS-MMCs. Check
the compatibility of an RS-MMC with its manufacturer or
provider.
Use only compatible Reduced Size MultiMediaCards
(RS-MMC) with this device. Other memory cards, such as
Secure Digital (SD) cards, do not fit in the memory card
slot and are not compatible with this device. Using an
incompatible memory card may damage the memory card
as well as the device, and data stored on the incompatible
card may be corrupted.
You cannot use the memory
card if the door of the
memory card slot is open.
Format a memory card
When a memory card is reformatted, all data on the card
is permanently lost.
Some memory cards are supplied preformatted and others
require formatting. Consult your retailer to find out if you
must format the memory card before you can use it.
To format a memory card, select Options > Format mem.
card
. Select Yes to confirm. When formatting is complete,
enter a name for the memory card, and select OK.
Apr 03, 2008 | Nokia N70 Cellular Phone
Olympus SP-510 UZ Digital Camera Logo
90 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
