Question about Philips 55PP9401 55" Rear Projection Television
Alignment Skues downward
  • Philips Master
  • 3,459 Answers
This is a common problem with older Philip Magnavox projection sets. Over time one of the IC chips on the main power board begins to fail. You can find replacment chips and repair instructions on www.magnavoxhelp.com.
Posted on Jun 29, 2008
ASUS MINI LAPTOP RAM CHANGING METHOD
Basically one removes the underside cover to access the memory modules. Then remove the modules by releasing/uncliping them at each side.
They will pop right out. Now align the cutouts and insert the modules pushing them downwards into position.
Take care!
damnor01
Sep 11, 2012 | Acer Aspire Computers & Internet
Water dripping out of Mr. Slim on indoor unit.
Reason for water leaking.
1. Filter block. 2. Cooling coil block. 3. Alignment of indoor a/c unit is sloping downwards. 4. Drain pan block. It's advisable to service your unit first.
Jul 02, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
How to remove front panel top loader
What you do is align a thin blade putty knifes with the edge of the lidand find the clips. Press downward to release the front panel.themobilian_1855.jpg
Training manual
Mar 12, 2011 | Hotpoint VBXR1090B Top Load Washer
Rear motion sensor buzzer stays on. 2003 f350 crew cab diesel
If the rear sensor stays on, you could have a miss aligned sensor. Check to make sure it is not pointed downward.
Jan 09, 2011 | 2003 Ford F350 Super Duty DRW SuperCab
HP D135 printed lines are angled slightly downwards left-to-right
twobells i have almost the same problem with the hp photosmart c4599 i have had no luck either
Jan 01, 2009 | HP OfficeJet D135 All-In-One InkJet...
Steering wheel facing downward after Rack and Pinion replacement
make sure the wheels are straight take off the steering wheel and put it back on straight then report the mechanic to the motor traders association how a mechanic returns your car like that i dont know glenn.........
Dec 13, 2008 | 1995 Toyota Corolla
Inconsistent pointing
Something similar happened to me when I had done a quick align. I asked the scope to go to the moon, which was obviously visible above the horizon but it pointed downwards. I found out that I had entered the date (month day year) in the wrong order (day month year - as is common in Sweden). Just a long shot...
/Fourier
May 15, 2008 | Celestron Advanced C9 1/4-S 11045 (555 x...
Convergence
Replace convergence IC's.
RE-check alignment
Oct 23, 2007 | Hitachi 46F500 46" Rear Projection...
Toshiba 42H82 convergence problem
Replace STK convergence IC's w/OEM or better parts.Senior tech soldering ability needed. Ex==Steel jumper wires feeding b+ to conv. IC's need resolder to prevent call-back.Also, best re-alignment done in service mode==consult service literature.
Sep 19, 2007 | Toshiba 42H83 42" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
