Question about Rowenta Professional DE880 Iron
Iron not staying on
My iron will not stay on, one slight move of the iron it shuts off, (light goes off and the iron basically shuts off) one more move of the iron or the cord it goes back on. Very frustrating as these irons are expensive and I would expect better performance from them as I bought my iron a short time ago, perhaps one year. Unfortunatley I am trying to find my bill of sale, hopefully where I bought it from will help me to fix or replace. Sometimes it does not matter if one spends a lot or less on an item, next time I will buy a cheaper item and if it breaks it breaks at least it was not expensive and can afford to buy cheaper than expensive in the long run.
  • Teresawhite1 May 17, 2009
    New Friend:
  • 18 Answers
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Posted on Mar 06, 2009
Shark g1468 auto shut off (iron won't come/stay on)
First let me say I HATE AUTO SHUT OFF!!! It sounds like it has wore out. the computer part that tells it when to shut off it not working. It would be cheaper to buy a new one vs fixing yours. If I were you, find an older iron that has LOTS of steam vents and NO AUTO SHUTOFF at your local goodwill, thrift store or garage sale.
Jan 06, 2014 | Shark Euro Pro GI468-FS Rapido...
My steamer steams and then shuts off and it takes another two minutes to steam again....what is wrong?
the power light stays on but steam only comes out for 30 second.and it takes few minutes to steam again.
Oct 21, 2012 | Rowenta Commercial Garment Steamer - White
The auto shut off on my new iron has stopped it from heating... is there a reset option? or do I need to purchase a new iron?... The auto shut off light flashes when first plugged in, then stays off......
it has a adjusment try to adjust by rotate it to clockwise it is located inside of your iron use a screw driver to adjust then observe unit. if not u purchase new unit.
Feb 17, 2011 | Philips Irons
I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Feb 07, 2010 | Rowenta Effective DX1700 Iron with Auto...
I simply cant get the iron to stay on. It shuts off
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jan 23, 2010 | Euro-Pro Shark GI490 Iron
Red light keeps blinking and iron shuts off
Sounds as if the cable may be damaged or a loose connection. May be cheaper to buy a new one from wallmart or similar store.
Jul 31, 2009 | Rowenta Effective DX1900 Iron with Auto...
Iron won't heat up!!!
A lot of rowenta irons have a safety or auto shutoff built in them that fails. The only way I have found to fix them is to disassemble it and permanently connect the switch then it works fine, just does not auto shut off.
Jan 14, 2009 | Rowenta Power Duo Iron
I'm having a problem with the auto shut off of my sunbeam 421A series iron. The iron works great until the auto shut off comes on and the red light starts blinking. I understand that the iron should...
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Sep 21, 2008 | Sunbeam 4214 Iron
On off light never shuts off
Clarification: When you "switch off" the unit, does the light stay on, but the steamer itself shut off (cools off to no steam)? If this is the case, only the LED does not light (which will not affect actual performance, other than being a "false" indicator driving some users crazy) like an Engine light that stays on in your car. It is likely a bad connection rather than a bad LED (Light Emitting Diode indicator). If the steamer portion is powered on all the time regardless of the switch position, try turning the temperature settings all the way down on the base and iron before unplugging unit to prevent the arcing (sparks) from damaging the input AC plug.
Solution: you will need a small Security Torx Bit/Driver to take unit far enough apart to inspect, troubleshoot and determine cause. You will also need an analog or digital multi-meter to check the unplugged unit' switch using self-powered ohm-out (continuity check) function, testing forward & reverse diode for lo & hi resistance reading respectively, (if you use the Rx1 range, the diode will glow slightly in one direction if it is good & you use an old analog meter). If you are so inclined or know somebody into electronics to do this, you can get these tools at Harbor Freight for $10-$20, good luck and keep in touch.
Apr 26, 2008 | Rowenta DG5030 Iron
Tefal 400 iron auto shut-off light stays on
TEFAL B.800
AUTO LIGHT ON,BUT NOT TEMP LIGHT.NOT HEATING UP.HAD BEEN USING BUT UNPLUGED WHILE I GOT MOE IRIONING.
Jan 31, 2008 | Irons
Rowenta Professional DE880 Iron Logo
522 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
