Question about Nintendo Wii Console
Wii cursor Hi, I can only go pass the opening screen but no cursor appears. we have tried everything like checking the sensors, replacing new batteries of the controls but still no cursor appears. PLEASE HELP!
  • 1 more comment
  • Anonymous Aug 01, 2008
    my cursor won't show i can use the + and - and the home buttons. I've tried reseting and unplugging everything, also tried replacing batteries and cleaning sensors (remote and bar) still nothing even if i'm 2ft. or 8ft. away
  • Anonymous Sep 06, 2008
    My cursor won't show. I charged my wii remote and it still didn't work. What do I do.
  • slortmann Sep 06, 2008
    I have replaced the batteries, checked and cleaned all connections, tried sync button for 15 seconds and still no crosshairs! It was working perfectly fine 8hrs. ago too!
  • 4,402 Answers
Try to resync the remotes.
Posted on Jul 01, 2008
Cursor hand will not show up
Make sure you do not block either the sensor bar or the sensor on the wiimotes. Check all your connections in the back escpecially the sensor bar. If everything is all set you said it worked for your new wii system so im assuming your old one has issues. try all these out and tell me how it works out
May 25, 2009 | Nintendo Wii Console
Wii remotes want to point at a wall light
well if u keep them on the charger for to long u need to get new ones cuz it will shorten the batteries on and on so buy new ones k!
Mar 25, 2009 | Nintendo Wii Remote Controller
Cusor wont appear on screen after setup
I had this problem too, and I found out what was wrong. I hope it's as easy of a fix for you as it was for me, the only thing is if the reason is the same. If your Wii sensor bar is not wireless, carefully check the wire for frays. Once I brought my Wii to my cousin's house and had the same problem you have. We did everything we could think of, then I checked the wire. It was frayed. I couldn't understand how it happened because we barely ever touched it, but we just replaced the Wii bar and everything was fine. Even if you can't see any frays on the outside of the wire, it's possible that the damage is on the inside of the wire. Try testing another wii bar on your system if this happens or if you don't find any visible frays. I hope this solves your problem. I know how frustrating this can be. Let me know if everything worked out!
Mar 11, 2009 | Nintendo Wii Console
Cursor will not appear on screen
make sure your sensor bar is connected to the console! properly aligned in the centre of t.v! also reconect the controler by: open the sd flap on front, press red button, remove batt cover of remote and press the connect button! this will resync the remote! also check battery's!
Jan 04, 2009 | Nintendo Wii Console
Verify that the cable bar sensor is plugged into the back of the Wii console and that the sensor bar is properly aligned with the centre of your TV screen.
Check that the Wii remote is synchronized with the console using the POWER button on the remote control to turn on the Wii console. (The POWER button is the white button with the red symbol which is located in the upper left corner on the Wii remote.) If it does not work, try to synchronize the remote control, then turn the console and controls that respond correctly to commands.
Verify that the distance between the Wii remote and the TV display to be between 1 and 3 meters, that there are sources of intense light that can interfere with the proper functioning of the remote (read Guidelines game for Wii for more information ) And that the sensor bar is placed correctly (see Setting up the sensor bar). Avoid the presence of sources of infrared light as electric stoves, gas propane or kerosene, candles, fireplaces, stoves or other heat sources close to the console.
If the steps described above do not solve the problem, the sensor bar could have a problem. Read the following instructions:
On each side of the sensor bar are five infrared lights that located the position of the Wii remote. If these lights do not work, the cursor on the remote will not appear on the screen and you can not step through screens of settings. To see these lights, you must look on the LCD screen of a digital camera or a mobile phone. Verify that the sensor bar is connected and that the Wii console is turned on, and then framing the bar sensor so that it appears on LCD camera or cellphone. If you see five infrared lights on each side, the sensor bar works. Maybe you'll need to slightly adjust the position / tilt the camera or the telephone, but is rather easy to see these lights on the LCD screen
Jun 22, 2008 | Nintendo Wii Console
Wii console...cursor doesnt appear on the screen but everything is sychronised and buttons on remotes work?
In the Wii settings make sure that the sensor bar setting is correct wheather it is top or bottom of tv. Then make sure the sensor bar is as far font as you can get it to give clear line of sight to the controller.
Apr 28, 2008 | Video Game Consoles & Games
Wii broken?
replace the batteries, and or try a friends remote.
Dec 31, 2007 | Nintendo Wii Console
Wii Cursor Does Not Appear
I had the problem where the cursor worked on the main menu screen, but disappeared once you entered any of the channels or a game. For me the problem was a faulty sensor bar. You can check if your sensor bar is working by focussing a digital camera on the bar as if you were taking a picture of it. In the viewfinder you should see 5 blue lights illuminated on both ends of the sensor bar. For me, only one side was illuminated. The sensor bar had to be replaced.
Dec 26, 2007 | Nintendo Wii Console
Cursor does not appear
exchange it
    Cursor not appearing
    Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
  • Some games do not use the cursor feature of the Wii Remote; Make sure the game you are attempting to play uses the cursor by reading the game's instruction manual. You can also exit out of the game to return to the Channel Menu and use the Wii Remote to see the cursor. If the cursor still does not appear, continue with the steps below.
  • Trying to use multiple Wii Remotes in the Mii Channel or Photo Channel? These Channels only allow the Wii Remote designated as "Player 1" to function.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote.
  • Check the battery power level by turning off the Wii console, then opening the battery cover of the Wii Remote. Press and release the red "SYNC" button to check battery strength. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength. Our experience has shown that as your battery strength decreases to one (1) or less lights flashing, the cursor may not appear. For troubleshooting, if possible, try using fresh batteries so that all four lights illuminate. For guidelines on using batteries, please click here. If after inserting brand new batteries, you are still seeing less than all four LEDs flash, then your Wii Remote will need to be repaired. Please click here for repair information.
  • Is the Wii Remote properly synced?
    Press the POWER button on the Wii Remote to see if the Wii console powers on.
    • If it does, the Wii Remote is synced with the system. Please skip to the next section.
    • If the power doesn't come on, power on the system manually and try syncing the Wii Remote.
      • If the Wii Remote will not sync, there is likely a problem with the Wii Remote. Please click here for repair information.
      • If the Wii Remote will sync and the cursor still does not appear, try another Wii Remote if possible.
        • If at least one Wii Remote is working, there is likely a problem with the first Wii Remote and it will need to be repaired. Please click here for repair information.
        • If you have only one Wii Remote, or none that are working, please continue troubleshooting.
  • Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup).
  • Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
  • Check the button functionality, and that the Sensor Bar is operating correctly, by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side through the Wii Channel screens.
    • If you are able to scroll with the "+" and "-" buttons, but the cursor is not appearing, then there is likely a problem with the Sensor Bar. Please click here for additional Sensor Bar information.
    • If there is no response, there is likely a problem with the Wii Remote. Please click here for repair information.
Dec 11, 2007 | Nintendo Wii Console
Wii remote controll
Buy a new sensor bar. None of my 5 Wii remotes had a cursor on screen so I bought a new sensor bar and it worked fine.
Nov 12, 2007 | Nintendo NES Remote Control
Nintendo Wii Console Logo
161 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
