Question about T-Mobile Computers & Internet
I have an T-Mobile MDA. I haven't used it for over 6 months, went to charge it last night. plugged in the charger and the blue power light came on, went to menu screen. Left the MDA charging upon returning to it about an hour later the MDA would not turn on. No power light and no sign of any life. What could be the problem? Regards Dave
Wonderful you just saved me throwing away a working charger and possibly the whole phone. Many thanks
Posted on Jul 18, 2009
Your first bet is to remove the battery and hold down the power button for 10 seconds, then replace the battery and try to turn it on.
Sorry I'm not more familiar with the model of phone you're talking about but this has worked for my old PDA's when they won't power-cycle correctly.
Posted on Jun 27, 2008
I haven't used this camcorder in a couple of months (bought new in January). When I went to charge it last night, neither the mains charger or USB lead will charge it. Does it just need a new...
The battery should be good if it was bought in January, with that said nothing is nperfect or lasts forever, there are always issues with some things. If all your connections from the charger or USB are good and tight and the cables are good, the either the battery is bad or the plug in on the camera is bad, or the battery nmay be installed incorrectly. That is about all there can be .
Jun 03, 2011 | Cameras
Had new batteries and a service 6 months ago. Has now been left standing for a couple of months. I charged it up last night, but nothing. The charger appears to be working, lights working. Any ideas
Yes your batteries have dropped below 9 vlt each and they wont chage using your charger. Yuo must take a car battery charger and charge each battery up to at least 11vlts for your charger to charge! This ought to work if batteries have only been sitting a couple of mths . When using a car charger set charge at 6-10 amps for about 45mins to 1hr then hook up chair charger and you should be ok
Feb 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
My T-Mobile MDA won't turn on or take a charge, battery was low
I had the same problem, but got the idea to "jump start" the battery from Googling the problem. At night, I had turned off my MDA to charge the battery and then in the morning, couldn't revive it. I removed the battery from my MDA, and determined which battery terminal was positive (far end of one side) and negative (far end of the other side) by using a multi-meter. BTW: Battery was still @ 3.5V (okay…battery was still alive, if just barely). Then, I found a 5V DC charger (5W Max output = ~1A) from my bluetooth headset. I used one wire (CAT5E) and connected it to the negative side of the adapter (outer sleeve - again, verified by multi-meter) and another wire to connect to the positive tip of the adapter. I had to strip about 1/2-inch of the insulation off of the wire on the DC adapter side, and about 1/8-inch of the wire on the battery side. Plugged in the 5V DC charger and then I touched the negative wire to the negative battery terminal and held it there, while I touched the positive wire to the positive battery terminal for about 30-45 seconds. Put the battery back in the MDA, started it up, and now it's charging on the regular MDA AC Charger that came with the phone. Problem solved.
Apr 07, 2009 | T-Mobile MDA
T-Mobile MDA won't hold a charge
if you insurance on your phone I recommend using it, I had a MDA for a couple years and had about every problem in the book, but not that one. It sounds like you've done everything possible, the only other thing i could think of is a hard-reset. Anything beyond that would tinkering with the internal hardware.
I think you can get a MDA pretty cheap on ebay these days
Jul 19, 2008 | T-Mobile MDA
MDA will not charge
dear there is some problems in the pins of ur MDA...squeeze them with something...then it will work...
Jun 22, 2008 | T-Mobile MDA
MDA will not power up.
another this to try is get a new battery.
mine had the same problem i would try to charge and nothing and it would turn on for about 30 seconds then turn off and i tried putting it on a charger within those 30 seconds but it wouldnt take a charge.
i got a new battery theat had some charge in it and it worked great! alot of the time thats all you need it a new battery
Mar 15, 2008 | T-Mobile MDA
Broken USB Port on T-Mobile MDA
My daughter's MDA had the same problem. I just opened the phone and soldered the legs on the corners back to the board. You have to bend the pins on the back of the plug down to make contact with the board, before you solder. Place plug back down and line it up with contacts. If done right should work as normal. Hope that helps
Jan 16, 2008 | T-Mobile MDA
Help ASAP my MDA wont turn on
it might take a while tfor the light to come on . leaving it on all night should not hurt it. try charging it again
Nov 06, 2007 | T-Mobile MDA
T-Moblie MDA Dead
I did the same thing, Blue Bay Electronics had a seven day warranty just long enough to fool me into giving a good report. Anyway look for a repair center and spend another 100.00. Good luck
Oct 07, 2007 | T-Mobile MDA
My MDA won't turn on even when its on the charger.
THE SCREEN AND LIGHTS HAVE BLOWN YOU NEED NEW PHONE
Apr 11, 2007 | T-Mobile MDA
Computers & Internet Logo
191 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
