Question about SanDisk Sansa e250 MP3 Player
Refresh database did you ever get the player to work or did it end up being a fatal crash
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 03, 2008
On the intro screen it freezez and eventually goes to the next screen and says refreshing database but it dosent refresh
This seems to happen when the database gets corrupted.
1. Turn off the player.
2. Plug the usb cable to the computer, don't plug it to the player.
3. Slide the lock switch to the right, you will see an orange strip.
4. Hold the menu button to start the player. Don't release it yet. Wait until a shutdown message appears and the player goes off again.
5. Plug the usb cable to the player end. The player should go on again. The player should mount as a disk on your computer. Find this disk and back up its contents.
6. Format the player, as explained elsewhere.
7. Disconnect the usb cable. This time the database should refresh properly. Once this is done, slide the the lock switch to the left and turn off the player.
8. Turn the player back on. It should work, but you will have to load your stuff again.
9. Redo steps 1 to 5, except that now should copy your music, videos, etc, back into the player.
10. Repeat step 7.
11. Turn the player back on. It should work again.
Dec 10, 2009 | SanDisk Sansa e250 MP3 Player
"Refresh Database" never ends!
If you try to load too many songs onto the player initially, it may take up to an hour to get past Refresh database. Unfortunately, if you shut the player off while it is refreshing, it will more than likely ruin your player. Run the Sansa Recovery Tool or Update the Firmware on your Player as a workaround. Make sure the hold/lock switch isn't activated, just as a safeguard.
-Tha Mp3 Doctor
Mar 17, 2009 | SanDisk Sansa e250 MP3 Player
Frozen while on the refresh database screen
Try holding the power button for about 15-20 seconds. This usally shuts the whole thing down.
It may refresh the database as normal next time.
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Help i can't open my sansa E200
Go to the place where you bought your Sansa E200 and ask them to have the firmware reinstalled. Most mp3/mp4 players crashes its firmware when you are working on something and the battery goes down. There is nothing wrong with your gadget's harware, just a software issue.. that's all.
A Simple Thank You is Good enough
Feb 15, 2008 | SanDisk Sansa e200 MP3 Player
Refresh database
refresh db can take up to 2 minutes,  leave several (+/- 5) megabytes of space for the e250 to work in.
Oct 22, 2007 | SanDisk Sansa e250 MP3 Player
Refreshing database - Everytime
there nothing wrong its jsut the way the mp3 player refreshes the play lists mine does it too
Feb 06, 2007 | SanDisk Sansa e260 MP3 Player
"refresh database failed" how do I do a database refresh?
i have the same problem ... refresh database fail .. i can put songs on the player but it doesn't show them or play them :-( HELP!!!!
Nov 15, 2006 | SanDisk Sansa e260 MP3 Player
Refresh database looping
This may not work for everyone - but try inserting a TransFlash (also called Micro SD)card in the microSD slot, and power on. It may then correctly refresh its database. It worked in my case, with firmware ver11.
Aug 11, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
16 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
