I need to log in to my router to turn on my DHCP so my xbox live will work how do i do this
  • Dave Rojas
    Dave Rojas May 11, 2010
    What Brand of router is it? There should also be a model number on the bottom. This info is needed to guide you through getting you on Xbox Live and pwning some noobs.
It is a D-link 604
Posted on Jun 27, 2008
Will not assign IP address
Steps for these found on http://support.xbox.com/en-US/xbox-live/connecting/error-cant-obtain-ip-address-router-modem-978976 and include
1. Restart modem and router2. Check wireless password3. Configure IP settings manually 4. Set an alternate MAC Address5. Turn on DHCP.6. Bypass router entirely and connect instead to the modem using a wired connection
Aug 09, 2012 | D-Link DGL-4500 Wireless Router
I have been trying to connect to Xbox Live through my Xbox 360 wireless network adapter and when I try to connect it simply says that the WEP key or WPA passphrase is incorrect, when it is indeed the right...
If you are getting an error that the WEP or WPA key is wrong, it's most likely NOT a DHCP issue. If you are 101% sure you are typing in the key correctly with no errors, there is a slight possibility that your router got reset somehow. (Did someone press its reset button?) If so, then the key stored in the router was wiped out, and of course, it wouldn't match now! If you don't know how to log into your router's config page and have no manual, try going to their website. Manufacturers post free PDF's of their manuals to download. You can also try shutting off the security temporarily (turn off WEP/WPA) and see if it connects then. Then re-enable it with a new passphrase. Hope this helps a little!
May 03, 2011 | Computers & Internet
I put the settings to factory on accident and now i can connect my xbox 360 on wireless connection?
1. Turn the modem off, and then turn it back on. Then turn the router power off, and then turn it back on. This is also known as power cycling the modem and the router.
Power cycle the modem first, and then power cycle the router. To power cycle these devices, you should follow your manufacturer’s specific instructions. Here are some general steps: a. Remove the power supply from your device.
b. Leave the device unplugged for 15 to 30 seconds.
c. Reattach the power supply to the modem by following the device manufacturer’s instructions.
d. Wait several minutes for the device to start and to establish a connection with your broadband provider.
e. Verify that the modem shows the appropriate power and Internet connection indicator lights by following the manufacturer’s instructions.
2. If power cycling your modem and router does not resolve the problem, try connecting the Xbox 360 console to Xbox LIVE by using the modem only. This eliminates any configuration problems on the router. If this setup works without the router, there is probably a configuration issue with the router. See the manufacturer’s documentation that is included with the router or contact the technical support group for the router.
3. Verify that your router's Dynamic Host Configuration Protocol (DHCP) service has been enabled. DHCP enables the router to assign IP addresses to the computers and consoles on your network when you go online. If you need help with this, see the manufacturer’s documentation that is included with the router or contact the technical support group for the router.
4. If you manually entered an IP address, gateway, subnet mask and/or DNS servers in the Network Settings area of the Xbox Dashboard , verify that it they are correct. At this point, you can also set your IP settings to Automatic. To do this, follow these steps:a. Move to the System area.
b. Select Network Settings.
c. Select Automatic.
5. If your ISP requires Point-to-Point Protocol over Ethernet (PPPoE) settings, try connecting to only the modem after you enter these settings in the Network Settings area of the Xbox Dashboard. Network Settings area of the Xbox Dashboard.
Note Some ISPs may require Point-to-Point Protocol over Ethernet (http://www.xbox.com/en-US/support/connecttolive/xbox360/resources/glossary.htm#ethernet) (PPPoE) settings, This means that you may need settings such as a username and password in order to gain access to your ISP’s network. If you are unsure whether you have to enter these settings, please contact your ISP support group. At this point, if you can connect directly to the modem, see your router documentation to configure the PPPoE settings correctly on the router.
6. If you are receiving an IP conflict error in the More Info section of the Xbox Dashboard, turn off all devices on the network. Try to connect to Xbox LIVE with only the modem and Xbox 360 console connected.
If this works, there may be a configuration issue on the router’s Dynamic Host Configuration Protocol (DHCP) server. DHCP enables the router to assign temporary IP addresses to the computers on your network when you go online. If you need help with understanding DHCP or the configuration, see the manufacturer’s documentation that is included with the router
Aug 13, 2010 | Computers & Internet
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
Change NAT to open
You should first reserve an IP address for your Xbox in your router DHCP server settings. If it is not possible to make a reservation, you should assign a static IP to your Xbox and excluse that address from the router DHCP server.
Then, you should set DMZ to point to the IP address you just reserve for your Xbox.
You should be set!
Please do not forget to rate the quality of my support in FixYa.com. ;)
Mar 27, 2009 | D-Link DSL-G604T Wireless Router
Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Mar 02, 2009 | NetGear DG834G Router
Xbox 360
Either the network connection between the 360 and router is not working correctly, or your router is not configured properly for DHCP.
DHCP (Dynamic Host Configuration Protocol) is a protocol that automatically assigns a network address (and some other settings) to your computer....or Xbox in this case. It works like this....when your Xbox connects to the network, it sends out a broadcast packet on the network that looks for a DHCP server. If a DHCP server is present, it responds. Next the Xbox requests its network address and other settings from the DHCP server. Your WGR614 router has a DHCP server function built in, but it may not be enabled. Try reconfiguring the router using the Netgear "Smart Wizard" installation CD and be sure to enable the DHCP capability, if asked.
Jan 10, 2008 | NetGear WGR614 Wireless Router
Xbox live
Hi you will need to either do the following:
1. extend the dhcp leasing function within the router by increasing the time for the lease, usually this is in minutes
2. manually assign the ip address so ud ont have this problem ever again
3. renew the ip address via xbox 360
4. it could just mean the xbox live server is temp down.
good luck
smeags.
Jan 07, 2008 | Microsoft Xbox 360 Console
Xbox live
THINGS TO TRY loadTOCNode(1, 'whattotry'); Direct connection with a modem only loadTOCNode(3, 'whattotry'); 1. If you are connecting to Xbox Live by using a modem that is connected directly into your broadband socket, your IP address settings are obtained from your ISP. Set your IP address in Network Settings to Automatic. 2. If you use a static IP address that you obtained from your ISP, you must manually enter this address in the Dashboard. Contact your ISP for their static IP address if you do not know it. If the IP is not static, continue with the rest of the troubleshooting. 3. Power cycle the modem. 4. If your ISP requires PPPoE settings, verify that you have entered them correctly. 5. If your ISP does not use PPPoE authentication, do not use these fields in the Dashboard. Shared connection with a modem and a router loadTOCNode(3, 'whattotry'); 1. Power cycle both the modem and the router. 2. Try connecting the Xbox 360 console to Xbox Live by using the modem only. This eliminates any configuration problems on the router. • If this setup works without the router, there is a configuration issue with the router. See the router's documentation or contact the technical support group. 3. Verify that your router's DHCP service has been enabled. See the router's documentation or contact the technical support group. 4. The IP address that you entered in the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If your ISP requires PPPoE settings, try to connect with only the modem after you enter the PPPoE settings in Network Settings. • If you can connect, see your router documentation to configure the PPPoE settings correctly on the router. 6. If you are receiving an IP conflict error in the More Info section, turn off all the devices on the network. Try to connect with only the modem and Xbox 360 console connected. • If this works, there is a configuration issue on the routers DHCP server. See the router's documentation or contact the technical support group. Shared connection with a gateway device (combined modem and router) loadTOCNode(3, 'whattotry'); 1. Make sure that the device is turned on. 2. Verify that there is activity with the blinking lights sequence WAN, ADSL, and Internet connected power. Note These names will vary from model to model. 3. Power cycle the gateway device. 4. The IP address that you entered in to the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If you are receiving an IP conflict error in the More Info section, turn off all the other devices on the network. Try to connect with only the Xbox 360 console on the network. • If this test works, there is a configuration issue on the gateway DHCP server. See the router's documentation or contact the technical support group. Shared connection with Microsoft Windows Internet Connection Sharing loadTOCNode(3, 'whattotry'); 1. Verify that you can browse the Internet. If you cannot browse the Internet, Internet Connection Sharing is not configured correctly. 2. Power cycle the modem. If the modem does not have an on and off switch, unplug the modem from the power outlet. You cannot follow this step if you are using a USB modem. Instead, go to the next step. You must follow this step if you are switching the modem between the Xbox 360 console and a computer. 3. On the computer, click Start, click Run, type ncpa.cpl, and then click OK. 4. On the View menu, click Tiles. 5. If the connection is listed as Firewalled, the firewall may have to be configured. See your firewall documentation. 6. Enter manual settings in the Dashboard for IP address, subnet mask, DNS address and gateway: • IP Address : 192.168.0.2 • Subnet mask : 255.255.255.0 • Default Gateway : 192.168.0.1 • DNS server (Primary): 192.168.0.1 • DNS server (Secondary): 192.168.0.1If none of this works you might be banned. If you modded your xbox360 or for downloading game saves from the internet to boost you gamer score. You might be banned!
Oct 14, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
